9 Pages V « < 6 7 8 9 >
> CUDA 911's 914 Thread ! ! !
Cuda911
post Aug 9 2014, 03:23 PM
Post #141
It's the original trim. It came off easily during the windshield replacement (I was a bit worried it would get bent).
I was wondering about the trim> When these cars were new, did it have an extreme mirror-like shine, or a more dulled finish like currently?
I'm pretty sure the wiper arms are correct. In fact, I replaced them with new ones a few weeks ago, and I studied the arms that were on the car before I replaced them the same way that the old ones were. Then, a week ago someone told me that they were on wrong (I assumed that the previous owner had them on wrong), so I just swapped them a few days ago to the current configuration.
It doesn't really drag on the trim, as it extends over the side, but not touching the trim. I asked another "914 guy" about that, and he said that's normal. I guess the older 911s use the same wiper arms and fit the same way (extending off the side a bit).
So, now I'm confused again. Are they on right?
post Aug 9 2014, 03:58 PM
Post #142
914-6 GT in waiting
Mine fit the same way.
Cuda911
post Aug 18 2014, 02:23 AM
Post #143
OK, so I think the wipers are on correctly.
Today I finished de-rustifying the trunk. There was some surface rust along the rear edge. Sanded it down to bare metal, treated the exposed metal with a rust converter as a precautionary measure, primed it, and painted it.
Also, detailed and polished the wiring harness in the trunk, and polished the muffler.
dlkawashima
post Aug 18 2014, 03:48 AM
Post #144
Looking good Mike! As a precaution, I recommend carrying your jack with the base nearest the corner of your trunk so as to prevent it from slicing into your carpet.
(IMG:http://www.914world.com/bbs2/uploads/post-6212-1154292375.jpg)
Cuda911
post Aug 18 2014, 10:34 AM
Post #145
Thanks for the tip, Dave!
After I took out the jack and tire iron, for the life of me I couldn't recall how they belonged back in the clips.
My tire iron still doesn't seem right to me.
dlkawashima
post Aug 18 2014, 12:44 PM
Post #146
QUOTE(Cuda911 @ Aug 18 2014, 09:34 AM) *
You're correct, the tire iron isn't original. An original "tire iron" actually consists of two parts: a socket and a tommy bar. See image below for reference:
Cuda911
post Aug 18 2014, 03:00 PM
Post #147
Ah, OK, that makes sense.
I've been looking all over for an original tool kit. I've found an original tow hook, but that's all.
What's the little wire clip-shaped tool for? Looks similar to the current center cap removal tool for other cars.
The black rubber band is to hold the rolled up tool kit together? Or to use as a fan belt?
Not a whole lot of fixin' to be done with that kit! Not even any pliers?
Does anyone have a tool kit they want to sell?
SKL1
post Aug 18 2014, 04:07 PM
Post #148
Boy Mike you're on the slippery slope aren't you??? (IMG:style_emoticons/default/smile.gif)
Cuda911
post Aug 18 2014, 05:06 PM
Post #149
Slipperier than a greased pig on ice.
This afternoon I cleaned up and polished the trunk latches.
post Aug 18 2014, 08:31 PM
Post #150
914-6 GT in waiting
the little u shaped wire is there to pull the large chrome covers off steel wheels.
Cuda911
post Aug 22 2014, 11:12 PM
Post #151
Thanks, Mepstein!... I figured it was a puller of some sort.
Today's project:
Replaced the outer door seal, the adjacent carpet strips, and put on the re-covered visors. Parts all from 914rubber.com. Great stuff, thanks Mark... much appreciated!!!
post Aug 23 2014, 08:01 AM
Post #152
914-6 GT in waiting
QUOTE(Cuda911 @ Aug 18 2014, 04:23 AM) *
Nice job!
post Sep 4 2014, 09:48 PM
Post #153
QUOTE(mepstein @ Aug 18 2014, 07:31 PM) *
Probably Porsche hub caps, too. I know that tool fits Karmann Ghia Hub caps, as well.
orthobiz
post Sep 5 2014, 04:43 AM
Post #154
QUOTE(KELTY360 @ Jul 10 2014, 11:45 PM) *
QUOTE(Eric_Shea @ Jul 10 2014, 07:15 PM) *
No. You've grown soft. (IMG:style_emoticons/default/wink.gif)
BTW, the wheels look great on your car. Glad they found a good home.
Actually, it's those HUBCAPS that make the car!
Paul
Cuda911
post Sep 5 2014, 11:08 AM
Post #155
^^^^ (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif)
Yep, I love the wheels and center caps, thanks, guys!! I think I have parts from maybe 10 other 914world members on my car now.
Interesting to see side-by-side pix of the car from the day I bought it vs now. Almost looks like two different cars:
Cuda911
post Sep 14 2014, 11:28 PM
Post #156
Today I replaced the dash bulbs with LEDs, since it is so hard to read the gauges at night.
The bulbs, designation BA7s-W, can be obtained from superbrightleds.com http://www.superbrightleds.com/cat/ba9s-ba7s/
A few tips for other newbies:
1. Take out the screws that hold the cluster face plate and pull out the plate. But, you won't be able to pull it out far enough because of the speedometer cable. So, lift the cable off of the clip in the footwell. This will give enough "play" in the cable to let you pull out the face plate far enough to access the back of the gauges.
2. Push each gauge out of the faceplate from behind.
3. OK, a total newbie error, but might as well pass it on... to get the old bulb out, push in and turn. Sheesh, busted the first bulb trying to pull it straight out. Duh!
4. The metal bulb housings ground to the gauge cases, so once you replace a bulb you need to hold the bulb housing against the gauge case to test it.
5. Do not drop a bulb into the housing by accident, or you will have to disconnect everything to get it back out. (Ask how I know)
6. Those spade connectors are brittle. One of them broke, so I had to splice in a new female side.
7. DO NOT Replace the alternator bulb with LED!!!. Your alternator will quit charging. Has something to do with how the current goes through the bulb.
Went for a drive tonight to see what difference it made. For the speedometer, makes a very significant improvement. Definitely worth it. For the tachometer, the left side is much brighter. Right side is still pretty dark. I'm wondering if one of the LEDs isn't working, so will take it apart again and check. Left gauge... parking brake warning light is much brighter. Fuel guage is still nearly unreadable at night (I think that has one of the tiny bulbs that is not the type that can be replaced with LED... I forgot..
Here's some pics and two videos. The first shows the OEM turn signal bulb, and the second shows it replaced with an LED.
https://www.youtube.com/watch?v=fSvEb_r7BXo
https://www.youtube.com/watch?v=5IphOdeOVTc
Cuda911
post Sep 29 2014, 10:00 PM
Post #157
My new cocomats from Cocomats.com showed up today. Very pleased with them. Excellent quality mats, and their customer service has been phenomenal.
They offer a zillion color combos, and I have a terrible time choosing colors. but, I think the red works very well for my car.
arkitect
post Sep 30 2014, 06:11 AM
Post #158
QUOTE(Cuda911 @ Sep 29 2014, 09:00 PM) *
Mike,
I like your selection of cars to drive, all porsche. New and now old. Your teener looks great.
Dave
Big Len
post Sep 30 2014, 09:25 AM
Post #159
Mats look great.
You might want to think about lowering your front end a bit. Unless every picture is taken on a hill pointing up, it looks a little high.
Cuda911
post Sep 30 2014, 11:24 AM
Post #160
Thanks, Arkitect. Yeah, I really like the Porsche line, in all of its forms.
Big Len, I guess the camera was tilted... dashed outside to take a few pix to post. Car is level.
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th December 2024 - 04:18 AM
