CUDA 911's 914 Thread ! ! ! |
Cuda911 |
Jun 13 2014, 10:29 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
I believe when the rear tits are mastectomized, it leaves a hole that requires welding shut?
Have any products been designed to snap into the resulting hole. What's the easiest way to get those off? I 100% agree, though.... the rear tits need to go. |
Mike Bellis |
Jun 13 2014, 10:32 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I believe when the rear tits are mastectomized, it leaves a hole that requires welding shut? Have any products been designed to snap into the resulting hole. What's the easiest way to get those off? I 100% agree, though.... the rear tits need to go. You can get a chrome carriage bolt and seal the hole without welding. http://www.boltdepot.com/Carriage_bolts_Ch...de_5_steel.aspx |
orthobiz |
Jun 13 2014, 10:54 AM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Cuda911 |
Jun 13 2014, 11:22 AM
Oh, it's just a very small hole when the tits are removed? I thought there was a big rectangle that needed a plate welded in.
I'll pull off the rings and see how it looks without 'em |
rhodyguy |
Jun 13 2014, 11:47 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
2 small holes for each tit. for a quick fix you can find plastic push in caps (in black) at your hardware store until you make a decision of the direction you want to take. for a resale value the bumper would be worth more with the holes left as they are. let the next owner fuss with the welding, grinding and repainting.
Tom |
Jun 13 2014, 12:15 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
CUDA911,
I read the whole thread, well skimmed thru kind of, and did not see any mention of this, however here goes. You have found a very nice car that so far is very original in style. This is becoming less and less seen as more and more guys modify their car a lot after buying them. You might give some thought to making modifications that are easily "undone" later as an original style car will bring more $$$ when you decide to move on. Original styled cars are becoming big attention getters at events also as guys who are reverting back to stock want to see how things were attached, etc. before folks started modifying them. Nice find!! and (IMG:style_emoticons/default/welcome.png) Tom |
Cuda911 |
Jun 13 2014, 06:38 PM
Hi Tom,
Thanks! Yes, I am going to keep all of my mods as "original" as possible, or as you say, make them easily reversible. I will save any parts I take off. One of the turn signal covers has some internal cracking due to age. I may get the clear/orange euro ones, but I will save the old ones. If I paint the bumper, that's easily reversible (it's not the original front one anyway). Since the Mahle wheels are correct for this car, I should have no problem swapping out the steelies. Even if I do the big bore pistons to increase displacement, I can't see that any future buyer will mind, since I can keep the stock fuel injection system in place. I was really happy to find a car that didn't have the injectors replaced with carbs. The "Porsche" stickers that I have ordered for the sides are period-correct, and easily removable. My original plan was to paint the car Bahia Red. In my, as of now, three days of ownership, the silver has grown on me. I would have preferred a more "interesting" color to start with, but I have decided to keep this one the OEM color. So yes, no crazy mods planned for this car! |
ripper911 |
Jun 13 2014, 07:03 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I was just telling a friend today that it felt like driving a go-cart! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/driving.gif) pure driving enjoyment, like no other car I've driven! With the cloth inserts in my seats it's a cross between sitting on an old couch floating down the road and a go kart with doors, depending on how you drive it. Your car is only a few hundred earlier than mine looking at the Vin, built in the same month. (IMG:style_emoticons/default/biggrin.gif) |
Cuda911 |
Jun 13 2014, 07:29 PM
"Your car is only a few hundred earlier than mine looking at the Vin, built in the same month."
Hey that's pretty cool! Another question for the group, regarding what gas grade to use. I think most say to just use 87. A mechanic told me to use 91, since it will run cooler. Opinions requested, please! |
Jun 13 2014, 10:44 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It won't necessarily run cooler on higher-octane fuel. It might, but it might not--the heat is not really related to the octane.
The car was built to run 87. You can try the higher-octane stuff and see if it makes any difference to you. --DD |
Cuda911 |
Jun 14 2014, 12:45 AM
OK< thanks, Dave. Everything I have ever read in my life seems to indicate that if a car was designed for 87 and runs fine on 87, then paying for higher octane is just a waste of $$.
I'm in the process of reading the owner's manual from cover to cover. Just saw the oddest thing.... I guess familiar to all of you, but I never heard of anything like this in my life: the windshield washer tank is pressurized from the spare tire!!! Wow! That is simultaneously crazy and sheer genius! I'm scheduled to take the car to my mechanic on Tuesday (June 17). I'm preparing a laundry list of items to check/fix: 1. Oil change. The oil in it looks new, but since I don't know when it was last changed, I will take care of doing that. 2. Minor transmission fluid leak. Hate spots on my driveway. 3. Minor oil weeping at rear main seal. Hate spots on my driveway. 4. Horn doesn't work. Of course, I can just use my finger to express displeasure whilst driving, but I'll see what's up with that horn. 5. General inspection. I didn't get a PPI, since I would have lost the car to another buyer if I did. I know the mechanic that did about $4,000 in repairs/servicing on it when it came out of storage in 2011, and he went through it in detail at that time. Today I went over and talked to him about the car and he gave it his "seal of approval". I'm guessing tranny needs to come out to fix that leak, so I guess that means a transmission fluid change, which is fine with me. Pic showing the leaks: Attached image(s) |
dlkawashima |
Jun 14 2014, 02:02 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I'm in the process of reading the owner's manual from cover to cover. Just saw the oddest thing.... I guess familiar to all of you, but I never heard of anything like this in my life: the windshield washer tank is pressurized from the spare tire!!! Wow! That is simultaneously crazy and sheer genius! The pressurized windshield washer system is notorious for leaking ... especially around the steering column, so keep an eye out for that. 4. Horn doesn't work. Of course, I can just use my finger to express displeasure whilst driving, but I'll see what's up with that horn. Twist off the horn pad (counter clockwise) and see if the wire from the steering wheel is connected to it. It's not uncommon for there to be a problem with that connection causing the horn to honk when turning the wheel, or, worst case, an "always on" condition. |
ripper911 |
Jun 14 2014, 04:46 AM
brant |
Jun 14 2014, 07:16 AM
914 Wizard Group: Members Posts: 11,822 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
leaks and a 914 go hand in hand...
its part of the experience. |
Cuda911 |
Jun 14 2014, 10:20 AM
Ah, sounds like the early 911's. Oil stains and 911's are inseparable.
"Twist off the horn pad (counter clockwise) and see if the wire from the steering wheel is connected to it. It's not uncommon for there to be a problem with that connection causing the horn to honk when turning the wheel, or, worst case, an "always on" condition." Thanks for the tip, I will take a look. |
Sleepin |
Jun 14 2014, 11:34 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Looks like it is a speedo drive o-ring leaking...not a hard fix and not a reason to pull the trans. Find McMark and see if he is still making his double o-ring speedo drives. They fix that problem.
Cuda911 |
Jun 15 2014, 01:57 AM
^^^ Ah, that makes sense... seller said something about an O-ring that was leaking, but I didn't know what he meant.
Dave, that was a good tip on the horn pad... I fixed the horn today!!! Right tail light and turn signal don't work. I thought it was probably a fuse, but I checked this morning and all fuses were fine. Now, I'm keeping fingers crossed that it is the bulb.... haven't checked yet. Today I took off the targa top and drove the 914 down to La Jolla and Seaport Village. Everywhere I went, all day long, people made comments and compliments about the car and wanted photos of it... crazy!!! Do you guys get that much attention in your 914s? I never get that many comments in either the Cayman or the 911. Here's the oddest incident of all today: I was in La Jolla, waiting in an alley for some friends that I was meeting. I was fiddling with the radio, and heard someone next to the driver's side say something. I looked up, and there was a scruffy, scraggle-bearded, tattooed, shirtless guy with filthy tattered pants. He was swigging whiskey from a bottle in a paper bag. I looked up and said "what?". He replied (in a somewhat slurred voice): "Great 914, man.... I haven't seen one of those in years." He took another swig, staggered a bit and nearly fell over, and then said: "Is that the 1800 engine? Your car is great, dude, I never see 914s any more." Then he gave me that surfer "hang loose" hand gesture and staggered off down the alley. . Attached image(s) |
ripper911 |
Jun 15 2014, 04:58 AM
orthobiz |
Jun 15 2014, 06:56 AM
I'm in the process of reading the owner's manual from cover to cover. Just saw the oddest thing.... I guess familiar to all of you, but I never heard of anything like this in my life: the windshield washer tank is pressurized from the spare tire!!! Wow! That is simultaneously crazy and sheer genius! Not uncommon to have the hose dry up at the steering column and wet your feet. Paul |
Cuda911 |
Jun 15 2014, 01:31 PM
^^^ My understanding is that the nozzles tend to clog up too. I haven't put any wiper fluid into the reservoir yet to try it out. Really is of very little concern. If it works... great! If not, oh well....
Lo-Fi Version | Time is now: 19th December 2024 - 09:17 AM |
