Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I love my Boxster/Cayman 6 speed... (IMG:style_emoticons/default/wub.gif)
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Very similar to the Holley Pro-Jection that I used for years. Worked great till the ECU died, then they asked me to fork over 1400 for an ecu replacement... To which I replied f you and grabbed a new edelbrock carb for $200 the new-ish kid on the block. http://www.atomicefi.com/home.aspx |
swooshdave |
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest ![]() |
What breaks first? I'm guessing your wallet. (IMG:style_emoticons/default/beerchug.gif)
Dunc |
Newbie ![]() Group: Members Posts: 37 Joined: 4-July 14 From: Kennewick, WA Member No.: 17,590 Region Association: Pacific Northwest ![]() |
HA.....no guessing about it. You are spot on. Thanks swooshdave! |
Dunc |
Thanks Mike. The Renegade site leads me to believe that installing the Boxter xmssn in the 914 is not a big deal...but that might just be my rose colored glasses. From what I have read, those xmssn's can take the hp and torque....and with a cable set up, shift nicely......any thoughts? Mike |
Mike Bellis |
Thanks Mike. The Renegade site leads me to believe that installing the Boxter xmssn in the 914 is not a big deal...but that might just be my rose colored glasses. From what I have read, those xmssn's can take the hp and torque....and with a cable set up, shift nicely......any thoughts? Mike I'm no expert but I'm running 350hp turbo Audi motor. The main problem with putting it in a 914 it the starter location. It is close to the V8 location but I can't be sure. In my case it was a direct bolt on; no modifications required. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:41 AM |
