rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,925 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
QUOTE(speedster356 @ Mar 24 2006, 02:45 PM) I have heard that the original motorcycle mounting is the same bolt spacing as an IDF? I mate has used a set of Suzuki Hyabusa bodies on his Alfa 2.0ltr powered sports car with great success. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
QUOTE(speedster356 @ Mar 24 2006, 03:45 PM) I have heard that the original motorcycle mounting is the same bolt spacing as an IDF? I mate has used a set of Suzuki Hyabusa bodies on his Alfa 2.0ltr powered sports car with great success. could be...it seems there is a "standard" 90mm bore to bore spacing for a lot of the throttle bodies |
Mueller |
progress today...I decided no welding or brazing and no adapter plate....
I simply machined the top of the manifold and will attach the throttle body directly to it with a hose and clamp...this is a similar method to how the t/bs are held on on the motorcycle Attached image(s) ![]() |
Mueller |
with hose section
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
nicely done mike!
why did you choose the "shorty manifolds" over CB talls etc??? |
Mueller |
the hose clamp is a special clamp which is used in turbocharger applications, it has a true 360° hold on the hose....it's on there pretty darn tight, I'll still add a bracket to align each t/b to on another on a common manifold.
Mueller |
QUOTE(Aaron Cox @ Apr 1 2006, 11:54 PM) nicely done mike! why did you choose the "shorty manifolds" over CB talls etc??? These are what I had, didn't know there are different options for the manifolds...oh yea, the cut is offset from the inlet on purpose, this matches the throttle body and allows the fuel injector to spray directly at the intake valve like the factory setup....it's a little further away, but I think it'll be fine... |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Very cool Mike. That sure looks like fun.
Dave |
rick 918-S |
Very cool Mike! (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Were watching you.. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
Mueller |
QUOTE(DNHunt @ Apr 2 2006, 05:38 AM) Very cool Mike. That sure looks like fun. Dave thanks....hard part is not tracking the "chips" back into the house (IMG:style_emoticons/default/unsure.gif) |
Porcharu |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California ![]() |
QUOTE(Mueller @ Apr 2 2006, 11:19 AM) thanks....hard part is not tracking the "chips" back into the house (IMG:style_emoticons/default/unsure.gif) Hey Mike - is your CNC mill up and running now or are you still just jogging around with the keyboard? |
Mueller |
QUOTE(Porcharu @ Apr 2 2006, 01:21 PM) QUOTE(Mueller @ Apr 2 2006, 11:19 AM) thanks....hard part is not tracking the "chips" back into the house (IMG:style_emoticons/default/unsure.gif) Hey Mike - is your CNC mill up and running now or are you still just jogging around with the keyboard? full CNC operation(old PC running DOS program .....TurboCNC)....my G-code programming sucks, I have BobCAD which is kicking my tail trying to learn it...these cuts made with SimpleCNC |
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
QUOTE(Mueller @ Apr 1 2006, 11:52 PM) with hose section Glad to see this project coming back to life ! Just out of curiosity, what is that little hole in the outer side of the manifold ? |
Mueller |
QUOTE(jsteele22 @ Apr 2 2006, 03:24 PM) QUOTE(Mueller @ Apr 1 2006, 11:52 PM) with hose section Glad to see this project coming back to life ! Just out of curiosity, what is that little hole in the outer side of the manifold ? the plug is for a vac. fitting |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,559 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Sweet, was waiting on a update for this, looks good.
tdsmoonchild |
Terry ![]() ![]() Group: Members Posts: 197 Joined: 18-January 06 From: Duncanville,TX Member No.: 5,431 ![]() |
QUOTE(JmuRiz @ Apr 3 2006, 08:10 AM) Sweet, was waiting on a update for this, looks good. (IMG:style_emoticons/default/agree.gif) Can't wait to see how it turns out! |
Aaron Cox |
Mike,
since the TB's are not rigid mounted, how do you plan to do a linkage between them? seems it will be pretty hard to sync if they are free to move up and down a little..... |
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
QUOTE(Aaron Cox @ Apr 3 2006, 06:33 AM) Mike, since the TB's are not rigid mounted, how do you plan to do a linkage between them? seems it will be pretty hard to sync if they are free to move up and down a little..... I think he's going to add a bracket. Plus he's using a hose but it's so short there's only one clamp so I can see it being pretty tight. Hey Mike, is there enough material on the TB and manifold to machine it down for a V-band clamp? Then you wouldn't need to use the short hose at all. QUOTE I'll still add a bracket to align each t/b to on another on a common manifold. |
Porcharu |
QUOTE(Mueller @ Apr 2 2006, 01:09 PM) .....TurboCNC)....my G-code programming sucks, I have BobCAD which is kicking my tail trying to learn it...these cuts made with SimpleCNC I had the demo version of Bobcad - that thing is a bear to learn. More like a learning cliff than curve. |
Mueller |
QUOTE(jonwatts @ Apr 3 2006, 07:57 AM) Hey Mike, is there enough material on the TB and manifold to machine it down for a V-band clamp? Then you wouldn't need to use the short hose at all. looked into it....I already bought the hose ($16 per ft), and don't want to spend too much time and effort on these... here is them mounted on one side of the motor.... I screwed up, these manifolds are for 2.0 3-bolt heads...my motor is a 1.8 with 4-bolt heads, anyone want to buy these?? (IMG:style_emoticons/default/smile.gif) (2.0 head in picture is thrashed beyond repair and for mock up use) Attached image(s) ![]() |
Lo-Fi Version | Time is now: 20th April 2025 - 06:20 PM |
