1stworks |
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None ![]() |
One more FG front bumper with flex.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1408451645.1.jpg) |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,734 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
The LE air dam is fine for air flow and screws in to the stock locations. Do a search for air dams and engine cooling to find the older threads on this subject.
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
I remember some people claiming there is an engine cooling issue for four cylinder cars using spoilers like this. The claim is that the LE airdam is raised up in the center allowing enough air under the car to hit the black plastic deflectors on the underside of the car to help draw air through the engine. I found this to be true. Back when I had a 2.0/4, I was running a 'deep' LE-style spoiler and was running hot. At some point I decided to change to a regular LE and my temps went down. This was on a motor without any external oil cooler. |
dudzy's914 |
The youngin' ![]() ![]() Group: Members Posts: 271 Joined: 21-December 13 From: Hatfield, MA Member No.: 16,784 Region Association: North East States ![]() |
I'm not doing the deep one. Just wondering if my engine will run hot with a "shallow?" LE spoiler
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
You can run the flexdam without the rubber, or even modify the rubber by cutting. I've run mine without the rubber and it's fine. The LE looks good two, so really its a matter of preference. The airflow wasn't an issue for me, but I'm not running mine hard, and it's not my daily driver, so if it's really hot, I'm not driving it.
dudzy's914 |
You can run the flexdam without the rubber, or even modify the rubber by cutting. I've run mine without the rubber and it's fine. The LE looks good two, so really its a matter of preference. The airflow wasn't an issue for me, but I'm not running mine hard, and it's not my daily driver, so if it's really hot, I'm not driving it. Do you have a picture of your Flexdams with out the rubber? |
Lo-Fi Version | Time is now: 30th June 2024 - 07:42 PM |
