car is bucking under acceleration...any ideas? |
era vulgaris |
Aug 27 2014, 02:04 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first? |
Mike Bellis |
Aug 27 2014, 02:50 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
sounds like a lack of fuel.
jt914-6 |
Aug 27 2014, 03:23 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
When you get the bucking worked out check your motor mounts and make sure you haven't broken one or both.....
Rand |
Aug 27 2014, 03:45 PM
Don 't know if the TPS would cause bucking to that extreme, but it would be worth looking for tracks.
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Car still have the Djet?
Has the tank ever been cleaned along with the bottom screen replaced? John |
era vulgaris |
Aug 27 2014, 04:32 PM
Motor mounts and trans mounts are still good.
TPS has been on my to do list. I should check it anyway. The stumble isn't while cruising though, which I understand is what happens with the TPS. My problem's only with acceleration. Yup, still D jet - it's in the sig! (IMG:style_emoticons/default/wink.gif) It's anyone's guess if the tank has been cleaned or the screen replaced. I've only owned the car since last november, and I wouldn't trust a word the PO says about it. That seems logical though, considering the issue started with hard cornering. Maybe some sludge got knocked loose. |
era vulgaris |
Aug 27 2014, 04:52 PM
Any chance a dying fuel pump would cause this?
Just curious before I start pulling the tank out. |
Mike Bellis |
Aug 27 2014, 06:52 PM
scotty b |
Aug 27 2014, 07:18 PM
Check all of the vaccum lines. there is one in particular I have experienced that is buried under all of the F.I. It is a large 3 way that ( IIRC) connects the Decel valve, Aux air reg and the intake manifold together. That will cause symptoms like you are describing. there are diagrams somewhere on the site.
jasons |
Aug 27 2014, 07:21 PM
Jackstand Extraordinaire Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
When my 2.0 did this, it was the trigger points in the dizzy. The contacts were good but the dogs that rides the cam on the dizzy shaft that open and close the points was worn out so they weren't opening fully.
brp986s |
Aug 27 2014, 07:31 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
Motor mounts and trans mounts are still good. TPS has been on my to do list. I should check it anyway. The stumble isn't while cruising though, which I understand is what happens with the TPS. My problem's only with acceleration. The TPS provides accel enrichment. You can spot check by turning ign on w/o starting engine, then go to engine and operate throttle valve. You should hear clicks from the injectors firing. |
Aug 27 2014, 07:52 PM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mine did this. Did a LOT of things to try to fix but I think it was overhauling the dizzy that finally did the trick. Also check all grounds.
warrenoliver |
Aug 27 2014, 09:16 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
Could be a loose ground wire on your distributor plates. Simple to check, just pop the dizzy cap, remove the rotor and dust cap and look at the ground wire connecting the plates.
era vulgaris |
Aug 27 2014, 09:44 PM
Check all of the vaccum lines. there is one in particular I have experienced that is buried under all of the F.I. It is a large 3 way that ( IIRC) connects the Decel valve, Aux air reg and the intake manifold together. That will cause symptoms like you are describing. there are diagrams somewhere on the site. I've replaced all of my vacuum hoses and recently repaired my AAR. I know the 3 way you're talking about. I'll check it to make sure maybe something hasn't come loose there while I was replacing the AAR. When my 2.0 did this, it was the trigger points in the dizzy. The contacts were good but the dogs that rides the cam on the dizzy shaft that open and close the points was worn out so they weren't opening fully. Mine did this. Did a LOT of things to try to fix but I think it was overhauling the dizzy that finally did the trick. Also check all grounds. Could be a loose ground wire on your distributor plates. Simple to check, just pop the dizzy cap, remove the rotor and dust cap and look at the ground wire connecting the plates. All you guys talking about the dizzy have me thinking. When I got the car, the vacuum canister was missing a screw and was hanging out of the dizzy causing the car to run waaaay underpowered. When I reattached it, the power came back. It does feel like the car is flipping back and forth between the feel of those two instances. I'll check this out. Is there a good guide to overhauling the dizzy, plates, trigger points, etc? |
76-914 |
Aug 27 2014, 09:46 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's your fuel pressure?
TheCabinetmaker |
Aug 28 2014, 04:03 AM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm surprised that no one has mentioned the fuel filter.
BeatNavy |
Aug 28 2014, 04:30 AM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
QUOTE Is there a good guide to overhauling the dizzy, plates, trigger points, etc? I think it's probably worth reading this thread: D-Jet Troubleshooting. It's what I used when I serviced my dizzy. The whole thread is worth reading, but it doesn't get to breaking apart the dizzy until midway on page 2. Good luck. |
dknechtly |
Aug 28 2014, 07:55 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
There's a lot of good advice here. Make sure your vacuum advance is working good. Check that your mechanical advance weights are moving freely and the springs are all good. Timing correctly set? If you clean the trigger points, make sure to only use something like a note card. DO NOT use emory cloth! These things need to shine. You want the resistance as low as possible.
era vulgaris |
Aug 28 2014, 01:29 PM
So first I cleaned every contact I could find in both the ignition and FI systems. Didn't help the problem at hand although the engine does run a little smoother.
Then I changed the fuel filter...and holy crap! That was it....mostly. I drove around for about 30 min and the car had completely woken up with smooth acceleration. I did have a couple very slight instances of bucking, and I suspect a professional fuel tank cleaning is in my future. Especially judging by the crap that came out of the old fuel filter! But it's 99% better than what it was before changing the filter. |
Phoenix914 |
Aug 28 2014, 03:43 PM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Lo-Fi Version | Time is now: 26th December 2024 - 06:20 PM |
