Pedrini 00 wheels need to fit a later hub, Ways to cut the opening to fit the centering ring??? |
bandjoey |
Aug 29 2014, 03:38 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I have to replace a bent wheel and picked up a good replacement from BD Stone.
(Thanks!) I am going to have the 00 Pedrini early wheel cut to fit the later hubs with centering rings. So far in the DFW area I've only found a couple of shops that say they can do this at $125 per wheel. Wheeeeho! (IMG:style_emoticons/default/dry.gif) That's a little steep for me! Outside of this, I think my other option is to bolt the wheel to a spare hub, mark the distance to cut out, and dremel tool the opening to a close fit. I know it will still be a lug centric wheel, since I can't cut it exactly to fit and centered. i think it should balance ok. Mayo's Performance here can lug centric balance wheels. Any suggestions doing this or is there a better way? Anyone done this at home? All suggestions welcome. I've searched many ways and can't find a thread on the actual cutting. Thanks (IMG:style_emoticons/default/flag.gif) Bill |
Mblizzard |
Aug 29 2014, 03:43 PM
$125 is high. I got it done for $40. Don't try and do it yourself. Regardless of what you try it will be a mess. Shop a few machine shops for cheaper costs before trying anything else.
bandjoey |
Aug 29 2014, 03:56 PM
Mike did u use a machine shop or wheel shop? I've been calling just wheel shops. Thanks
Mblizzard |
Aug 29 2014, 04:06 PM
Mike did u use a machine shop or wheel shop? I've been calling just wheel shops. Thanks Machine shops only. Get the tires dismounted and take it to a machine shop. I had my cut 80 mm in diameter and 13 mm deep. Seems to work well you can measure your hubs as I think 79mm would work also. |
914Sixer |
Aug 29 2014, 07:22 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Machine shops ONLY !!! I usually take a spare wheel so the machinist can measure it with HIS tools, then he can replicate the cut on the replacement wheel..
zambezi |
Aug 30 2014, 05:53 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Can't you just put on early rotors.
Aug 30 2014, 06:17 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Not without swapping over to some other early parts.
If it's just one wheel, you could put it on the rear. The rear hubs are the same from early to late. --DD |
bandjoey |
Aug 30 2014, 11:06 PM
I'll look into machine shops next week. I have 3 good wheels to cut and one already cut oversized. If I don't do all 4 I can't do a normal tire rotation. I'll find a 4th later on so they're all matching and keep the oversize cut for a spare. Thanks for the info.
Lo-Fi Version | Time is now: 26th December 2024 - 04:00 PM |
