2 Pages V < 1 2
> Picking up new 914, Subie conversion
dale73914
post Sep 8 2014, 12:24 AM
Post #21
Region Association: Australia and New Zealand
QUOTE(Mike1981 @ Sep 8 2014, 06:36 AM) *
Hello Everyone
I flew down to Atlanta and purchased Pankopp's Subie powered 914
Sale went smoothly as Pankopp was very helpful
Drove her back to Michigan in 12.5 hours she purred on the Highway
Car is in good shape.
However I need to address rear brakes and adjusting the shifter (Im grinding 1st)
http://i273.photobucket.com/albums/jj216/m...zpscfa07e70.jpg
If anyone has any advice it would be most welcome
Thanks
One thing that took me a while to get used to was the clutch and gearbox " pecularities " .
My old 73 911E mever did it but the 914 i have now does the same thing.
Try this.....
When you want to engage first, push the clutch in and wait for 2 seconds before selecting first gear.
If i try to go straight in it clunks, if i wait, no grind / clunk...
Dont rush any of the gearchanges either, it's not a box to be rushed...
Have fun (IMG:style_emoticons/default/smile.gif)
Dale
Mike1981
post Sep 8 2014, 04:19 PM
Post #22
QUOTE(dale73914 @ Sep 8 2014, 02:24 AM) *
Hello Everyone
Thanks
Try this.....
Dale
Thanks for the advice Dave I will try pausing between each gear
Mike
KELTY360
post Sep 8 2014, 04:36 PM
Post #23
914 Neferati
Grinding in 1st may well be clutch adjustment. Easy to do....which means even I can do it. (IMG:style_emoticons/default/biggrin.gif)
Mike1981
post Sep 9 2014, 01:28 PM
Post #24
QUOTE(KELTY360 @ Sep 8 2014, 06:36 PM) *
Tried to change rear brakes today.
All was going well until I pulled out the brake shoes and they were larger
Would not fit in the caliper
Took them back to NAPA and they agreed that they sold me the fronts by mistake and the rears were going to be out a week
Oh well, I learned how to jack up a very low car and put jack-stands underneath
I was well along on the outside pad but the inside looks to be a bit harder
Also saw where I may be able to adjust the clutch cable
One question if anyone can help
I get in the car with the seat all the way back
I then slide the seat forward and if feels good as far as the throw of the pedal and the reach to the shifter
While shifting the seat lets loose and slides all the way back
Is this operator error?
I took the seat out, oiled it replaced it
It moves smoothly but after depressing the clutch a few times it comes free and slides back
I have determined that being more forward will be an improvment as my arms more easily reach the shifter and legs can depress the pedal.
Any Ideas?
Thanks
Mike1981
post Sep 23 2014, 06:16 AM
Post #25
QUOTE(Mike1981 @ Sep 9 2014, 03:28 PM) *
Any Ideas?
Thanks
Well
I did indeed get the correct shoes from NAPA and had to take off the rear calipers to install.
All went well thanks to the documentation on this site.
Had to bleed the calipers twice to get a firm pedal but they are good now.
The advice to pause before shifting is working very well.
I am slowly getting better at the "feel" of the gearbox.
I want to adjust it one day but have been warned I may make it worse.
I've been under the car , inspected longs battery tray and floorboards
She seems solid and is a blast to drive.
Next up is adjusting the parking brake Any Advise would be great.
After that changing trans oil and motor oil
I reall am enjoying this new hobby
Thanks
Mike
eman 928
post Sep 23 2014, 06:37 AM
Post #26
I am in Lake Orion and still looking for my first 914.
rmdinmd
post Sep 23 2014, 06:47 AM
Post #27
try pmbperformance.com web site. they have a tech tip section.
EdwardBlume
post Sep 23 2014, 07:30 AM
Post #28
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
You are going to be just fine!
2 Pages V < 1 2
- Lo-Fi Version Time is now: 27th December 2024 - 08:09 AM
