Question for the MegaSquirt crowd, Oxy sensor locations or Exhaust options |
CatDaddy60 |
Sep 2 2014, 09:09 PM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
I was looking at a MS 2 with an oxygen sensor when it occurred to me the stock exhaust for my oversized 1.7 has header pipes that never come together for a place to locate a single or dual oxygen sensor. Please share any thought or location you have found to place a sensor or two sensors.
Thank you in advance. |
mikesmith |
Sep 2 2014, 09:37 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
I was looking at a MS 2 with an oxygen sensor when it occurred to me the stock exhaust for my oversized 1.7 has header pipes that never come together for a place to locate a single or dual oxygen sensor. Please share any thought or location you have found to place a sensor or two sensors. Thank you in advance. Work out which cylinder runs the leanest, and use the runner for that one. If you're using split intakes, pick one from either side... |
Mike Bellis |
Sep 2 2014, 10:32 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I would put it on #3, it runs the hottest.
Lo-Fi Version | Time is now: 2nd January 2025 - 12:55 PM |
