> starter problem, starter/flywheel grinding
mattc
post Sep 12 2014, 12:32 PM
Hello. new to 914world but owned many 914's since early 90's. Have a 73 2.0. purchased rebuilt starter and hot start kit. Installed. When restarting when engine is warm/hot. Starter and flywheel do not engage properly and grind. Takes about 3-8 turns of key before it "catches". Does not happen when cold. 1. What am I destroying? 2. How do i fix it? Thanks.
PotterPorsche
post Sep 12 2014, 03:09 PM
I have the same issue. pull your starter inspect flywheel teeth. When I bought the car it was this way. 7-10 starts are fine. Mine is getting worse. already have replacement flywheel . Waiting for it to get intolerable , at which point I pull tranny replace flywheel, clutch throw out bearing and clutch.
mattc
post Sep 14 2014, 05:55 AM
Do you know if it is flywheel or starter problem? Is yours heat related in any way?
PotterPorsche
post Sep 14 2014, 01:53 PM
Mine is not heat related. I pulled started gear was fine. With a mirror and flashlight i rotated the engine lookong at flywheel. Visual onspection revealed teeth damage. U can also rub your finger on the edges of teeth. Car not running of course
- Lo-Fi Version Time is now: 26th December 2024 - 05:39 PM
