Stripped Gas Tank Threads |
cary |
Oct 16 2014, 09:44 PM
pilothyer |
Oct 16 2014, 10:03 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I would be glad to pay you for one plus mailing cost if you have an extra...with the v cut or not.........LMK...........Thanks.............Jerry
Kansas 914 |
Oct 17 2014, 07:54 AM
I would be glad to pay you for one plus mailing cost if you have an extra...with the v cut or not.........LMK...........Thanks.............Jerry Thanks Cary. O'Reilly's states not available in store or Online. I'm with Jerry on buying spare from you. EDIT: I see where eBay has them for $11.63 with Free Shipping. I will go that route. |
cary |
Oct 17 2014, 01:38 PM
Rock auto
Use 1995 Nissan Pickup. Brake/hub. Comes up as Spindle Nut. Like $2. |
Kansas 914 |
Oct 17 2014, 01:45 PM
Rock auto Use 1995 Nissan Pickup. Brake/hub. Comes up as Spindle Nut. Like $2. Thanks Cary - order is placed (minimum 5 pieces) $22 shipped to the door. http://www.rockauto.com/catalog/raframecat...p;parttype=1616 |
cary |
Oct 27 2014, 08:41 AM
I'm buying 2 pair of these to get something with new aluminum threads.
http://www.cbperformance.com/ProductDetail...roductCode=3288 Then go to an AN6 to barbed fitting. Should make it quite a bit tidier under the tank. With the pump in the trunk I'll drain the tank with the firewall to engine fuel filter hose. For those that need hoses and fittings. I use A1 Coupling on Tualatin Sherwood Rd.It's a commercial place, but great service even for the dinky do things I buy. Last time I was looking to replenish my supply of Oetiker clamps and they took back into the warehouse to take my pick of styles. |
Kansas 914 |
Oct 27 2014, 08:45 AM
I'm buying 2 pair of these to get something with new aluminum threads. http://www.cbperformance.com/ProductDetail...roductCode=3288 Then go to an AN6 to barbed fitting. Should make it quite a bit tidier under the tank. With the pump in the trunk I'll drain the tank with the firewall to engine fuel filter hose. I am thinking about doing the same thing in the Spring when I pull my tank in the '74. I will watch your progress - thanks! |
cary |
Oct 31 2014, 07:42 AM
Another lesson from this experience. After you drain the tank of POR15 sealer and your letting it drip out the big sender and fill holes (upside down). Clean the threaded fittings and put the nuts back on loosely, or the sealer will set up on them. Tried putting on the CB fittings last night after they arrived. No go, too much sealer on them. They'll need to be tidied up with the steel nut, again.
Heading to the hose store this am looking for barbed AN/JIC fittings. |
Kansas 914 |
Oct 31 2014, 07:45 AM
Another lesson from this experience. After you drain the tank of POR15 sealer and your letting it drip out the big sender and fill holes (upside down). Clean the threaded fittings and put the nuts back on loosely, or the sealer will set up on them. Tried putting on the CB fittings last night after they arrived. No go, too much sealer on them. They'll need to be tidied up with the steel nut, again. Heading to the hose store this am looking for barbed AN/JIC fittings. This is the exact issue I have - but I used Red Kote. I now have a mess and I don't know what to use as a solvent to help clean up the mess. I will use the modified nuts as a thread chaser. Good luck Cary. |
cary |
Oct 31 2014, 07:49 AM
I'll update from the shop in a coupe hours.
cary |
Oct 31 2014, 01:14 PM
Had I little trouble at hose shop. They don't really deal in the small stuff. But we finally found what I was looking for.
With my bunged up threads they were tough to get started and not go on cross threaded. But you can see them sitting here with 2 gallons of gas checking for leaks. Dry as a bone. But I am going to mark the bottom of the tank .... never remove bad threads I tested one of them on one of my other tanks. They went on smooth as silk. Nice product. Note : They seal with an O-ring. I'd say for cleaning the threads if the tank sealer is your only issue. Clean threads with the nut with the cuts in it. Oil as you go thru the cuts. I turn a 1/4, back up a 1/2. Rinse and repeat until you get to the bottom. I took it off once and cleaned the threads with a wire brush. Then use a new unused nut to tidy up the starter threads. |
Kansas 914 |
Oct 31 2014, 02:05 PM
Had I little trouble at hose shop. They don't really deal in the small stuff. But we finally found what I was looking for. With my bunged up threads they were tough to get started and not go on cross threaded. But you can see them sitting here with 2 gallons of gas checking for leaks. Dry as a bone. But I am going to mark the bottom of the tank .... never remove bad threads I tested one of them on one of my other tanks. They went on smooth as silk. Nice product. Note : They seal with an O-ring. I'd say for cleaning the threads if the tank sealer is your only issue. Clean threads with the nut with the cuts in it. Oil as you go thru the cuts. I turn a 1/4, back up a 1/2. Rinse and repeat until you get to the bottom. I took it off once and cleaned the threads with a wire brush. Then use a new unused nut to tidy up the starter threads. Looks like a job well done - thanks for documenting this repair so well - cheers! |
cary |
Nov 1 2014, 08:37 AM
Final couple shots ............
Tank with my notes on it. New look under the tank .......... Zip tie is to take a slight kink out of the pressurized line New fuel pump layout in the trunk So tank is sitting there with a couple gallons in it checking for static leaks. If it passes. I'll pressurize it this am. |
puffinator |
Nov 1 2014, 01:19 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
The fittings? Is that an AN-6 to AN-4 reducer and then a AN-4 reducer? Where did you get those? |
cary |
Nov 1 2014, 01:47 PM
AN-6.
Ordered from CB Performance. Part was cheap. $7. Shipping $15. Was here in 3 days. No reducer. That is AN-6 to 5/16 barb. Did the nut show up yet? |
puffinator |
Nov 1 2014, 03:53 PM
Lo-Fi Version | Time is now: 18th January 2025 - 10:59 PM |
