> eBrake won't set, Took it apart- see pics Monday
jim_hoyland
post Sep 13 2014, 08:51 PM
Get that VIN ?
It's a late car; when I pull up on the eBrake handle it doesn't set. It will go back down to the floor. Is a part sticking ?
partwerks
post Sep 13 2014, 08:53 PM
QUOTE(jim_hoyland @ Sep 13 2014, 06:51 PM) *
It would make ya think that something is not catching? I've never had one apart. I would assume there are some sort of notches, as I recall it clicks.
I have a hydraulic one.
jim_hoyland
post Sep 13 2014, 09:02 PM
Get that VIN ?
QUOTE(partwerks @ Sep 13 2014, 07:53 PM) *
That's right: it's not catching.... (IMG:style_emoticons/default/sad.gif)
post Sep 13 2014, 09:07 PM
914-6 GT in waiting
mine wasn't catching. I took it out of the car, soaked in vinegar for a day,lubed it up and it worked great.
ndfrigi
post Sep 13 2014, 09:10 PM
QUOTE(jim_hoyland @ Sep 13 2014, 08:02 PM) *
Hi Jim, I think it just need some oil inside the handle.
bdstone914
post Sep 13 2014, 09:17 PM
bdstone914
QUOTE(jim_hoyland @ Sep 13 2014, 07:51 PM) *
There is a toothed pawl that should catch on the larger toothed part. The spring in the handle should engage it. I have parts for them. Can get you pictures tomorrow. The button unscrews. There is a spring under it. The spring may be bent or broken. You can do that with the handle still in the car.
Bruce
jim_hoyland
post Sep 13 2014, 09:37 PM
Get that VIN ?
QUOTE(bdstone914 @ Sep 13 2014, 08:17 PM) *
Bruce
I'll check that out first. Thanks for the suggestions (IMG:style_emoticons/default/smile.gif)
914_teener
Bruce,
Sounds like the spring is Kaput.
I don't think there is a throw out bearing in there.....so it should be okay (IMG:style_emoticons/default/poke.gif)
bdstone914
post Sep 13 2014, 09:53 PM
bdstone914
QUOTE(914_teener @ Sep 13 2014, 08:37 PM) *
Bruce,
If the spring were bad I would think there would be no tension on the button. Could be the rod that pushes on the pawl.
post Sep 14 2014, 07:26 AM
Jim, unscrew the blk plastic knob and look. Sounds like the spring broke. Is there tension when you depress the button? If so, I would think the spring is good.
jim_hoyland
post Sep 14 2014, 08:21 AM
Get that VIN ?
Unscrewed the button and pulled the spring; spring is not broken. Replaced both and still doesn't catch when pulled.
Is my next step going to be seat removal and ??
Cap'n Krusty
post Sep 14 2014, 09:01 AM
Cap'n Krusty
You have a hydraulic parking brake? Not safe, not effective over the long term (i.e., hours), and illegal in the US.
The Cap'n
Cap'n Krusty
post Sep 14 2014, 10:17 AM
Cap'n Krusty
QUOTE(jim_hoyland @ Sep 14 2014, 07:21 AM) *
There's a rod inside, the one that the washer, spring, and knob work with, and it has a welded flat steel finger near the bottom that has a well known propensity for breaking off. You need to remove the lever assembly and take a look at it. WARNING!: There are early and late rods, and they don't interchange!
The Cap'n
jim_hoyland
post Sep 14 2014, 10:35 AM
Get that VIN ?
A seat removal is required ?
Dave_Darling
post Sep 14 2014, 12:20 PM
914 Idiot
Maybe not, but it makes access easier, and it takes all of 15 seconds. So why not?
--DD
post Sep 14 2014, 12:23 PM
914-6 GT in waiting
QUOTE(jim_hoyland @ Sep 14 2014, 12:35 PM) *
eisier to do with the seat out. It takes ten seconds and no tools to remove a seat. reach down to the track next to the brake. Hold the flat spring up with a finger. Slide the seat forward. done.
bdstone914
post Sep 14 2014, 03:52 PM
bdstone914
[quote name='mepstein' date='Sep 14 2014, 11:23 AM' post='2085989']
[quote name='jim_hoyland' post='2085957' date='Sep 14 2014, 12:35 PM']
[/quote]
[/quot
You are going to have to replace the handle. I have not found a way to take them apart without damaging them. I have a used one that needs paint and a replacement handle. I think they are still available as they are the same on 911's.
Bruce
post Sep 14 2014, 04:13 PM
914-6 GT in waiting
QUOTE(jim_hoyland @ Sep 14 2014, 10:21 AM) *
Did you try lubing it. The spring might not have enough force to overcome 40 years of corrosion. Hit it with a lot of lube and try working the mechanism. Sounds like there's nothing to loose at this point.
bdstone914
post Sep 14 2014, 04:28 PM
bdstone914
Here is the layout of the parts.
jim_hoyland
post Sep 14 2014, 06:31 PM
Get that VIN ?
Is the rod and piece on the right end one piece ?
- Lo-Fi Version Time is now: 26th December 2024 - 09:46 AM
