> Oil temp sender drain plug 14mmx1.5, Is that the right size anyone using this?
shane
post Sep 15 2014, 07:43 PM
I have a 74 1.8 wanted to use the plug instead of taco plate is that a good choice? Thanks
bdstone914
post Sep 16 2014, 04:33 PM
bdstone914
QUOTE(shane @ Sep 15 2014, 06:43 PM) *
Sounds risky to me if it does fit. If something hits the ceramic isolated and breaks it you could loose all your oil.
shane
post Sep 16 2014, 05:44 PM
Was thinking that to, it looks like the plug is one solid piece with the sender on the outside, not to much differant then a sender hanging out of a taco plate I would think thanks for your thoughts
Dave_Darling
post Sep 16 2014, 06:36 PM
914 Idiot
The proper "taco plate" is recessed up into the sump. The sender screws into the side of the recess, and there is a cover plate that goes under it. The whole sender is above the level of the bottom of the engine, and it is not exposed to the relatively-cold outside air.
--DD
- Lo-Fi Version Time is now: 26th December 2024 - 06:10 PM
