motor mount conversion, looking for parts |
sumcar71 |
Sep 16 2014, 09:36 PM
Newbie Group: Members Posts: 3 Joined: 16-September 14 From: Colorado Member No.: 17,909 Region Association: None |
I currently have a 1971 914 that has been in the family since 1973. I did an engine overhaul in 1982. Now it is due again and I am replacing the engine with a 1.7 rebuild, small block and I am replacing the tail shifter transaxle for the side shift. I have located the shift lever parts from a 1973 parts car and through the internet, but I am looking for motor mount conversions for accommodating the different shifter configuration. I am looking for the engine carrier bar and the outboard mounts as well as the bolts with bushings that attach to the engine.
bdstone914 |
Sep 16 2014, 09:43 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I currently have a 1971 914 that has been in the family since 1973. I did an engine overhaul in 1982. Now it is due again and I am replacing the engine with a 1.7 rebuild, small block and I am replacing the tail shifter transaxle for the side shift. I have located the shift lever parts from a 1973 parts car and through the internet, but I am looking for motor mount conversions for accommodating the different shifter configuration. I am looking for the engine carrier bar and the outboard mounts as well as the bolts with bushings that attach to the engine. I have all of those parts. By bushings I think you mean the motor mounts which are best to buy new. Do you have the different brackets that mount to the engine? You also need a special bushing for the firewall that works with the smaller side shift bar. Bruce |
sumcar71 |
Sep 16 2014, 09:48 PM
I have the original bracket from the first engine. I have ordered the firewall bushing and all of the shifter linkage
Mike Bellis |
Sep 16 2014, 09:51 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
EdwardBlume |
Sep 16 2014, 09:56 PM
Lo-Fi Version | Time is now: 26th December 2024 - 01:03 PM |
