An affordable upgrade from a 1.8, Engine Upgrade |
lexatola |
Sep 17 2014, 10:14 PM
Newbie Group: Members Posts: 10 Joined: 17-September 14 From: Woodinville, WA Member No.: 17,914 Region Association: Pacific Northwest |
Hello all - I'm brand new to this forum with my first post! I've got other Porsches but just purchased my first 914. I picked up a 1970 with a 1.8 motor with dual weber 40 IDF Carbs.
I've been researching motors and see that the 2270 is a very popular upgrade. I love everything I've read about it - thinking about the kit from the type 4 store. So what work would need to happen to the 1.8 in order to make this happen? Will the Weber 40s work for induction or will this build require 44s? Are there other tried and true builds that could be put together from known parts for less money? I'm just trying to figure out the best way to build a cost effective motor that will make the car go and last.... Love to hear opinions, Alex |
Johny Blackstain |
Sep 18 2014, 07:26 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I'm hardly an expert but I believe it's all relative to what you want to do with the car- daily driver, track car, full restoration (probably not the latter since your looking to upgrade). The 2270 is extremely popular & the man who invented it is a regular on this forum & will have 99.9% of the answers you're looking for regarding it. I'm not sure but I think that dual 40mm Weber downdrafts are NLA & might be worth some coin on the used market. From what little experience I have on the subject, it seems the 40's are more for street use over the 44's. |
Bob L. |
Sep 18 2014, 11:19 AM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I'm no expert either, from what I have read, going 2270 would probably require the 44's. Going with the stroker crank might also require some machining inside the case for clearance.
larryM |
Sep 18 2014, 11:34 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
Will the Weber 40s work for induction or will this build require 44s? Alex the answer is in this book - get it Tomlinson weber manual |
rhodyguy |
Sep 18 2014, 11:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
it is my understanding that to fully realize the hp potential in a 2270, heat exchangers aren't going to cut it and you'll spend $$$ while leaving hp on the table. the owners i know with that displacement run header systems. a 1911 or sourcing the components for 2056 (find a good core and use your current engine til the build is done) should provide a pleasant increase in power and the monetary dif can be applied to other areas of the car. living in the pnw you'll miss a warm interior and hate a foggy windshield. how much hp and torque do you think you need?
horizontally-opposed |
Sep 18 2014, 12:06 PM
Advanced Member Group: Members Posts: 3,453 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
2056 with carbs or FI is supposed to be a really nice package.
Beware the 914-4 owner's quest for more power...it seems to lead to six cylinders an $$,$$$ all too often. Ask me how I know... pete |
lexatola |
Sep 18 2014, 03:21 PM
Thanks for the various responses. I'm looking to restore this car to largely original cosmetics. I'd like to keep it narrow, add a nice set of 15" Fuchs. Tighten up the suspension and add a bunch of HP and Torque and have it be a great tear around street car. I have an Emory 356 outlaw that makes about 120hp but the car only comes in at about 1,600lbs. I figure the 914 will need to make around 150hp to be comparable. I like the 2270 because of its torque. My other cars are all high revers. This would be something different.
Best, Alex |
rhodyguy |
Sep 18 2014, 03:26 PM
btw. welcome to 914world!
Sep 18 2014, 03:35 PM
Thanks for the various responses. I'm looking to restore this car to largely original cosmetics. I'd like to keep it narrow, add a nice set of 15" Fuchs. Tighten up the suspension and add a bunch of HP and Torque and have it be a great tear around street car. I have an Emory 356 outlaw that makes about 120hp but the car only comes in at about 1,600lbs. I figure the 914 will need to make around 150hp to be comparable. I like the 2270 because of its torque. My other cars are all high revers. This would be something different. Best, Alex Welcome to 914world, and the world of Porsche's "other" genius. I was looking for exactly the setup you are, and was sabotaged just before pressing go by a high-school friend's offer to help me convert my car to a six. Doing a 2270 to 150~ hp right isn't cheap, as I discovered, so I went with a rebuilt 2.2 six with (nice) used parts and a mix of NOS and aftermarket parts. It was about a wash when I started in 2010. Not so much now, I bet—though I hear good Type IV parts are getting hard to find. I too like the Type IV for its torque (and, especially) its low weight. That said, I've got no regrets. Your mileage may vary, and you'll have the car I wanted if you stick to your plan. Enjoy! pete |
blackmoon |
Sep 18 2014, 03:41 PM
Member Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None |
I did a lot of research before I made the plunge, I went with the 2270 kit from Jake Raby with twin 45 dellortos and very happy with my build. Lots of torque and a good daily driver
Bleyseng |
Sep 19 2014, 08:43 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Hello all - I'm brand new to this forum with my first post! I've got other Porsches but just purchased my first 914. I picked up a 1970 with a 1.8 motor with dual weber 40 IDF Carbs. I've been researching motors and see that the 2270 is a very popular upgrade. I love everything I've read about it - thinking about the kit from the type 4 store. So what work would need to happen to the 1.8 in order to make this happen? Will the Weber 40s work for induction or will this build require 44s? Are there other tried and true builds that could be put together from known parts for less money? I'm just trying to figure out the best way to build a cost effective motor that will make the car go and last.... Love to hear opinions, Alex Let's meet up and I'll let you drive my 2056 w/Raby cam, Djet and still has stock heat for the NW's cold days. That will let you decide how much HP you need. Geoff |
914work |
Sep 19 2014, 09:58 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Alex, (IMG:style_emoticons/default/welcome.png) take Geoff up on his offer ...& come swing by my place (Mill Creek area) (IMG:style_emoticons/default/smile.gif)
Phoenix914 |
Sep 19 2014, 10:07 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Why do I have to be the one to say this?
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Ok, really I've always wanted to say it! So there it is. (IMG:style_emoticons/default/biggrin.gif) |
EdwardBlume |
Sep 19 2014, 03:28 PM
It all depends what you want to use the car for. A DD may call for something entirely different from a streetable track car. Then there's cost. If I were starting out, I would put money in suspension and mods with the 1.8 in, and upgrade to a 2056 when someone sells one for a decent price. |
Chris H. |
Sep 19 2014, 03:48 PM
Senior Member Group: Members Posts: 4,049 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
It might be worth it to check out McMark's turbo setup he installed on the gold car. Seems like a great alternative to a full-on engine build. He was really pleased with it. I think there's a thread somewhere.
lexatola |
Sep 19 2014, 04:04 PM
Hey Geoff and 914werke - do you guys ever come down for the Redmond Town Center exotics event? Saturday mornings - It would be a great time to meet up. My 914 is not on the road but I could bring a 356 or bus just for fun!
Lemme know, Best, Alex |
0396 |
Sep 19 2014, 06:26 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
It's an opened ended question. I think it all depends on one's ultimate budget.
flmont |
Sep 19 2014, 08:23 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
You can also read a article on pelican parts about the big four engine under there tech.heading,..its a article from Mr. Nugent that built and ran it as a racer,.??? or look up lite914.com,..Iam in the same boat with a 2.0 ready to build found a shop in hawthorne ca,..Iam going with..European motorworks. (IMG:style_emoticons/default/welcome.png)
TravisNeff |
Sep 19 2014, 08:40 PM
A 2316 is not too much more $$ than a 2270.. Freight Train!
HalfMoon |
Sep 19 2014, 10:24 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
When I toast 5.0 mustangs with my sbc Darkside Teener it gives me a warm and fuzzy feeling.
Come to the Darkside Luke |
Lo-Fi Version | Time is now: 26th December 2024 - 11:27 AM |
