> Gas smell in the twists
57lincolnman
post Sep 18 2014, 08:09 PM
I've been taking my 914 on curvy roads in the North Georgia mountains to check out some recent suspension upgrades. Yesterday, I had the top off and the windows down and noticed a raw gas smell that only happened on the hard corners. Cruising down the highway and there wasn't any smell. Anyone else have this happen? Any thoughts as to what this is? Or maybe it's normal thing when the gas tank is kind of right under your nose.
bzettner
post Sep 18 2014, 08:12 PM
QUOTE(57lincolnman @ Sep 18 2014, 09:09 PM) *
I had that and replaced my gas cap with a new one...problem solved (for me)
Wdunster
post Sep 18 2014, 08:47 PM
Panel beater
Yep. Gas cap
boxsterfan
post Sep 18 2014, 08:48 PM
914's are kewl
I had gas vapers in my 74 2.0L. I replaced the rubber seal inside the gas cap, the rubber gasket under the tank filler and the rubber gasket under the fuel sender on the tank.
Got them all from 914rubber.com and it fixed the problem for me. Prior to that I had replaced all the vacuum lines also.
You should also check your fuel lines under the tank....make sure you don't have a leak or weeping hose.
EdwardBlume
post Sep 18 2014, 10:04 PM
When you smell the gas, its the hard seal around the inlet of the tank. I took Dad's car to an ax prior to restoration and you could actually see the gas. Not a bad idea to use new bolts to secure.
toolguy
post Sep 19 2014, 01:53 PM
Check the seal between the expansion tank and the tank. . has the little bolts under the gas cap
holding it on. .
maf914
post Sep 19 2014, 03:34 PM
Not a Guru!
QUOTE(toolguy @ Sep 19 2014, 11:53 AM) *
holding it on. .
In the past I have had leakage from this rubber gasket. Tightening all of the bolts uniformly solved the problem. Access is to the bolts is pretty tight. Be patient.
jmalone
post Sep 19 2014, 06:31 PM
All of the gaskets mentioned can be purchased from 914 Rubber at bargain basement prices. Replace them all so that you can keep smoking in the car (IMG:style_emoticons/default/biggrin.gif)
TravisNeff
post Sep 19 2014, 08:48 PM
Uh, the overflow line to the neck of the tank??
- Lo-Fi Version Time is now: 26th December 2024 - 01:01 PM
