> EBrake pivot yoke, Best way to reconnect
jim_hoyland
post Sep 19 2014, 07:08 AM
Get that VIN ?
What is the best way to get enough slack at the eBrake pivot yoke so that the cable and pin can be reinstalled ?
It was hard to remove I didn't loosen the eBrake cables at the firewall nor the caliper
bdstone914
post Sep 19 2014, 07:50 AM
bdstone914
You can attach the cable to the handle before you bolt it to the long. You may be able to pull to handle enough to get it back on the stud. Otherwise you will have to loosen the cables at the firewall then readjust after installing the handle.
jim_hoyland
post Sep 19 2014, 07:53 AM
Get that VIN ?
[quote name='bdstone914' date='Sep 19 2014, 06:50 AM' post='2087999']
That worked ! Thanks. I have the new lever mounted and just need to take up some slack at the firewall
- Lo-Fi Version Time is now: 26th December 2024 - 02:26 PM
