fire extinguisher mounting for in front of fixed seat?, looking for ideas where and |
two914-6s |
Sep 19 2014, 11:55 AM
Member Group: Members Posts: 51 Joined: 1-September 14 From: Los Angeles Member No.: 17,846 Region Association: None |
Does someone sell a bracket for in front of a fixed passenger seat
Thanks Dave |
GeorgeRud |
Sep 19 2014, 03:56 PM
I haven't seen on, but they're easy enough to make with a piece of angle iron, a couple flat bar extensions to utilize the front factory seat mounting bolts, and a fire extinguisher bracket. Seems to fit very well, is easily reachable if needed, and doesn't interfere with the passenger's legroom.
1970 Neun vierzehn |
Sep 19 2014, 09:24 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Here are some photos of my Halon fire extinguisher "installation". I used two very strong magnets that I acquired from an automobile dealership. They use these magnets frequently to attach license plates to autos for demo drives, dealer trades, or other over-the-road movements. Placing these magnets back-to-back on the leading edge of the bottom of the passenger seat, the F/E, which came with a bracket, is held firmly in place. As hard a I can brake, or as much lateral force as I can generate, the F/E stays in place. No movement, no vibration, and no drilling.
I purchased the F/E at a small regional airport that sells to the civilian aviation enthusiast......"Sporty's" in Batavia Ohio. Paul Attached image(s) |
ablesnead |
Sep 19 2014, 09:30 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
that is nuts
campbellcj |
Sep 19 2014, 10:10 PM
I can't Re Member Group: Members Posts: 4,593 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Check Rennline for a pre-fab mount. In a previous car I installed a 2.5lb in the storage bin between the seats (appearance group car), with the lid removed. Clean installation and easier for driver or passenger to reach in that location.
ConeDodger |
Sep 20 2014, 11:58 AM
Apex killer! Group: Members Posts: 23,852 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Check Rennline for a pre-fab mount. In a previous car I installed a 2.5lb in the storage bin between the seats (appearance group car), with the lid removed. Clean installation and easier for driver or passenger to reach in that location. (IMG:style_emoticons/default/agree.gif) Rennline is a little better than most shade tree fabrication... Well ok, a lot better... |
two914-6s |
Sep 20 2014, 12:10 PM
Here are some photos of my Halon fire extinguisher "installation". I used two very strong magnets that I acquired from an automobile dealership. They use these magnets frequently to attach license plates to autos for demo drives, dealer trades, or other over-the-road movements. Placing these magnets back-to-back on the leading edge of the bottom of the passenger seat, the F/E, which came with a bracket, is held firmly in place. As hard a I can brake, or as much lateral force as I can generate, the F/E stays in place. No movement, no vibration, and no drilling. I purchased the F/E at a small regional airport that sells to the civilian aviation enthusiast......"Sporty's" in Batavia Ohio. Paul Thanks paul great idea |
two914-6s |
Sep 20 2014, 12:16 PM
Check Rennline for a pre-fab mount. In a previous car I installed a 2.5lb in the storage bin between the seats (appearance group car), with the lid removed. Clean installation and easier for driver or passenger to reach in that location. The Rennline looks great Did you screw into the sheet metal? or use the drivers seat rail from the side? thanks dave |
struckn |
Sep 20 2014, 08:06 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
All I did was use a dog collar to strap it to the front of the seat frame. It removes quickly by sliding it out of the collar, meaning it doesn't need to be unbuckled.
I know this sounds stupid but it works great. (IMG:style_emoticons/default/confused24.gif) |
orthobiz |
Sep 20 2014, 08:12 PM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
May be easy to make but someone should sell a mount!
Paul |
pvollma |
Sep 20 2014, 09:03 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
May be easy to make but someone should sell a mount! Paul From one Paul to another: Front seat extinguisher mount |
57lincolnman |
Sep 21 2014, 09:06 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
Does someone sell a bracket for in front of a fixed passenger seat Thanks Dave I used a velcro patch and anchored it to the exposed frame under the passenger seat. It's definitely a grab-n-go solution. My fire extinguisher had a wall mount bracket which gave a flat edge to place the velcro. I had to tip the passenger seat back slightly to get it to fit. Looks great and is very easy to access. |
iamchappy |
Sep 21 2014, 09:25 PM
I made one out of aluminum.
GeorgeRud |
Sep 22 2014, 06:58 AM
Iamchappy's looks just like mine, but I used steel as I don't have the skill and equipment to weld aluminum. This design fits perfectly and is totally removable if desired in the future without drilling any holes into the car.
EdwardBlume |
Sep 22 2014, 07:11 AM
Very cool.
What is the button on the right next to the fire extinguisher handle? |
DRPHIL914 |
Sep 22 2014, 07:23 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I like the magnet idea, i might use this for this trip coming up , maybe fabricate a mount or buy one later. just need something for this coming week.
iamchappy |
Sep 22 2014, 07:29 AM
Trunk release
Lo-Fi Version | Time is now: 26th December 2024 - 04:42 AM |
