supplier for 1.8 big bore pistons/cylinders? |
LCOX |
Sep 23 2014, 09:40 AM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
Anyone know of a good souce for new big bore 1.8 pistons and cylinders. I want to go with a big bore set and still use my stock 1,8 heads. Anyone make a slip in set. My 1,8 still has the stock 93 mm p/cs. Thanx L
stugray |
Sep 23 2014, 09:55 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
European Motor Works
wndsrfr |
Sep 23 2014, 11:18 AM
Senior Member Group: Members Posts: 1,441 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Anyone know of a good souce for new big bore 1.8 pistons and cylinders. I want to go with a big bore set and still use my stock 1,8 heads. Anyone make a slip in set. My 1,8 still has the stock 93 mm p/cs. Thanx L Bore out your oem 1.8 cylinders to fit a set of 96mm pistons....they're better than new aftermarket..... |
Lo-Fi Version | Time is now: 26th December 2024 - 05:41 PM |
