Good Progress on Major Smash Repair, Body repairs complete, very pleased with the results |
phillstek |
Oct 14 2014, 01:09 PM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Just curious: Did you move and re-weld the old VIN when you changed out that section, or use the VIN from the new car? I guess you could go either way. I managed to retain the original VIN. The inner wheel well was cut just behind where the numbers are stamped. |
Rob-O |
Oct 14 2014, 01:39 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Slight hijack... maybe Scotty or Rick can clarify... Does it really take three weeks for epoxy primer to cure? Very nicely done! Should be good as new when finished. (IMG:style_emoticons/default/driving.gif) Actually if I remember correctly you're supposed to seal the epoxy prime pretty quickly (3 days? Do t remember for sure). If you let epoxy primer cure too long it loses its ability to bond with the basecoat. It will still bond, but you get a better bite when the paint isn't fully cured. |
Harpo |
Oct 14 2014, 05:15 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Yes, but it can be scuffed up with a scotch brite so the next layer of paint will not
have any adhesion problems. Dave |
phillstek |
Nov 3 2014, 10:19 PM
Went out to Zag this afternoon to see if there was anything happening to my car and was pleasantly surprised by what I saw.
The paint is finished under the fenders, inside the frunk and the closing panel. Both sides of the car are going to be repainted as well. Re-assembly has begun with the oil cooler etc in place. The A arms and other suspension pieces are due back from the powder coaters tomorrow. Also doing coil overs with the ER bushings, camber plates and other goodies. The guys at the shop have been extraordinarily helpful and nothing is too much trouble for them. If ever anyone local needs paint or panel work done to their Porsche, then I would strongly recommend you talk to John or George at Zag. They only do Porsche and they do them very well. Attached image(s) |
Mikey914 |
Nov 3 2014, 10:27 PM
The rubber man Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
WOW
Nice work |
rick 918-S |
Nov 3 2014, 10:44 PM
Hey nice rack! -Celette Group: Members Posts: 20,508 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Cairo94507 |
Nov 4 2014, 07:03 AM
Michael Group: Members Posts: 9,845 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Excellent work. That is one fine car. Keep posting.
Nov 4 2014, 10:09 AM
914 Idiot Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Consider reinforcing the strut towers. They weren't really designed to take the weight of the car, and can have problems over the long term with a coil-over conversion.
--DD |
blackmoon |
Nov 4 2014, 12:32 PM
Member Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None |
Went out to Zag this afternoon to see if there was anything happening to my car and was pleasantly surprised by what I saw. The paint is finished under the fenders, inside the frunk and the closing panel. Both sides of the car are going to be repainted as well. Re-assembly has begun with the oil cooler etc in place. The A arms and other suspension pieces are due back from the powder coaters tomorrow. Also doing coil overs with the ER bushings, camber plates and other goodies. The guys at the shop have been extraordinarily helpful and nothing is too much trouble for them. If ever anyone local needs paint or panel work done to their Porsche, then I would strongly recommend you talk to John or George at Zag. They only do Porsche and they do them very well. Nice color and work to get it to this point (IMG:style_emoticons/default/piratenanner.gif) |
phillstek |
Nov 11 2014, 11:46 PM
WOW indeed! Went out to Zag today for my weekly visit (I have to stop myself from going there anymore frequently) to find the car very close to being done.
The standard of work is so good that I’m afraid the car might become a garage queen. While I was there the guys were frigging around with the door as it turned out to be a late one and they had to modify a few things so they could get the early regulator to work. The pictures are pretty self explanatory and show the skills they have. They told me that they’d never worked on a 914 before working on mine and that they really liked them now. Coming from someone that does nothing but 911s , I thought that was a pretty cool thing to say about our cars. They were also very impressed by the coil overs and other ER bits, so much so, that they and a couple of their customers who’d seen the quality and simplicity, would be converting their cars to suit. I’ll keep a close eye on the strut towers though. Got the Boxster callipers from them too, having paid $500 for the pair which I figured was a pretty sweet deal. Thanks for all the comments. Attached thumbnail(s) Attached image(s) |
PlantMan |
Nov 12 2014, 12:19 AM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I love quality craftsmanship!
Nice work indeed! |
boogie_man |
Nov 12 2014, 10:22 AM
Member Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California |
Wow !! Awesome workmanship that looks great !!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
phillstek |
Nov 17 2014, 12:42 AM
Big day today, the car came off the stands and is rolling (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
Attached thumbnail(s) |
veltror |
Nov 17 2014, 02:06 AM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Ripper !
Cairo94507 |
Nov 17 2014, 07:29 AM
Beautiful car.
pilothyer |
Nov 17 2014, 08:14 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Beautiful car, and Superb Workmanship !! (IMG:style_emoticons/default/beerchug.gif)
02loftsmoor |
Nov 17 2014, 10:05 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
WOW, what a Job. better man than me.. (IMG:style_emoticons/default/beerchug.gif)
0396 |
Nov 17 2014, 10:26 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Consider reinforcing the strut towers. They weren't really designed to take the weight of the car, and can have problems over the long term with a coil-over conversion. --DD Mmmm, how would he do that? Overlay metal over the existing shock tower ? To the OP, congrats on reclaiming your -6 (IMG:style_emoticons/default/piratenanner.gif) |
phillstek |
Nov 28 2014, 05:48 AM
Thanks to all for the compliments and kind comments (IMG:style_emoticons/default/beerchug.gif) I’ll pass them on to the guys that did the work (IMG:style_emoticons/default/biggrin.gif)
Very happy to have my car back home at last and I’m really pleased with the way it turned out. I had the car painted about 3 years ago and it always bugged me that it was a pretty average job. The frunk was particularly bad having had this soft black undercoat stuff that never went hard under the paint. As well, the paint had lifted in places on the floor around the oil cooler shroud. Now it looks pretty much perfect in there. The engine has yet to be assembled as a result of a small but significant problem with the cams. We put the engine together, went time the cams and had a valve to piston clearance issue. Pulled it all apart and we could tell by just looking at them that the lobe centres did not match the cam specs supplied with them. Long story short, someone at the manufacturer pulled the wrong profile, put them in the box marked as the profile I ordered with the timing specs for same. Needless to say, I was not happy and contacted the manufacturer who promised to send the correct profile cams earlier this week. Attached thumbnail(s) Attached image(s) |
EdwardBlume |
Nov 28 2014, 06:58 AM
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Looks museum quality... Good luck with the motor reassembly! |
Lo-Fi Version | Time is now: 20th June 2024 - 09:11 AM |
