Sae 40w motor oil? |
Ben and Ralph |
Sep 30 2014, 11:28 AM
Ben Group: Members Posts: 110 Joined: 8-July 10 From: Los Angeles Member No.: 11,917 Region Association: Southern California |
So the VW shop that rebuilt my engine had always recommended I use straight 40 weight motor oil. I took their word for it and have used it ever since my car has been running. Now I see that no one here on the world uses it! Have I been using the wrong motor oil? Should I switch? I live in Southern California so temps hit 100+ sometimes, and this is my daily driver.
injunmort |
Sep 30 2014, 11:36 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I run straight 50w (valvine vr 50) in the summer and vr 30 in fall and spring.
Ben and Ralph |
Sep 30 2014, 11:50 AM
Cap'n Krusty |
Sep 30 2014, 12:01 PM
Back in the 60s, Porsche used to caution against multi-grade motor oils. By the mid 1970s the technology had changed and 20w50 became the oil of choice for 914s, at least in places like So Cal and other areas with a moderate to hot climate. That would include most of the US during the summer months. I would NEVER use a 50 wt. motor oil in a 914 unless it had a terrible low oil pressure problem, and then only until I could get it to a shop for repairs to correct the problem. Pretty much the same for 40 wt. The engine is still cold on startup, and that's where the "20" is important. The thin oil moves well through the engine when its cold, than the multi-viscosity additives kick in and increase the effective viscosity, providing the lubrication the engine needs when its hot. Really modern engines are designed to use even thinner oils, and current 911s call for 0w20 motor oil (many knowledgeable techs prefer 5w20). The tolerances and clearances are MUCH tighter and a thinner oil is required to flow properly.
Whatever brand you choose, be sure to get one with enough zinc to protect the flat tappet lifters and the camshaft. The Cap'n |
Ben and Ralph |
Sep 30 2014, 12:27 PM
Back in the 60s, Porsche used to caution against multi-grade motor oils. By the mid 1970s the technology had changed and 20w50 became the oil of choice for 914s, at least in places like So Cal and other areas with a moderate to hot climate. That would include most of the US during the summer months. I would NEVER use a 50 wt. motor oil in a 914 unless it had a terrible low oil pressure problem, and then only until I could get it to a shop for repairs to correct the problem. Pretty much the same for 40 wt. The engine is still cold on startup, and that's where the "20" is important. The thin oil moves well through the engine when its cold, than the multi-viscosity additives kick in and increase the effective viscosity, providing the lubrication the engine needs when its hot. Really modern engines are designed to use even thinner oils, and current 911s call for 0w20 motor oil (many knowledgeable techs prefer 5w20). The tolerances and clearances are MUCH tighter and a thinner oil is required to flow properly. Whatever brand you choose, be sure to get one with enough zinc to protect the flat tappet lifters and the camshaft. The Cap'n Thanks cap'n, so you'd recommend 20w50? |
Drums66 |
Sep 30 2014, 12:53 PM
.... (IMG:style_emoticons/default/dead horse.gif) (some topics are beat to death)do some searches?
(IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/bye1.gif) |
Cap'n Krusty |
Sep 30 2014, 01:10 PM
Back in the 60s, Porsche used to caution against multi-grade motor oils. By the mid 1970s the technology had changed and 20w50 became the oil of choice for 914s, at least in places like So Cal and other areas with a moderate to hot climate. That would include most of the US during the summer months. I would NEVER use a 50 wt. motor oil in a 914 unless it had a terrible low oil pressure problem, and then only until I could get it to a shop for repairs to correct the problem. Pretty much the same for 40 wt. The engine is still cold on startup, and that's where the "20" is important. The thin oil moves well through the engine when its cold, than the multi-viscosity additives kick in and increase the effective viscosity, providing the lubrication the engine needs when its hot. Really modern engines are designed to use even thinner oils, and current 911s call for 0w20 motor oil (many knowledgeable techs prefer 5w20). The tolerances and clearances are MUCH tighter and a thinner oil is required to flow properly. Whatever brand you choose, be sure to get one with enough zinc to protect the flat tappet lifters and the camshaft. The Cap'n Thanks cap'n, so you'd recommend 20w50? Yup. |
Big Len |
Sep 30 2014, 05:29 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
struckn |
Sep 30 2014, 07:48 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Translog, after an engine rebuild used SWEPCO 15W 40 Engine Oil in my 914 1.8L.
Remember that Oil is an important part of the Engine Cooling, different Oils heat and cool differently. Brad Pen would be my other choice. |
Drums66 |
Sep 30 2014, 08:11 PM
So the VW shop that rebuilt my engine had always recommended I use straight 40 weight motor oil. I took their word for it and have used it ever since my car has been running. Now I see that no one here on the world uses it! Have I been using the wrong motor oil? Should I switch? I live in Southern California so temps hit 100+ sometimes, and this is my daily driver. ....Alright! let's beat-it to DEATH...I agree with the VW shop!!!(914) |
Ben and Ralph |
Sep 30 2014, 09:01 PM
So the VW shop that rebuilt my engine had always recommended I use straight 40 weight motor oil. I took their word for it and have used it ever since my car has been running. Now I see that no one here on the world uses it! Have I been using the wrong motor oil? Should I switch? I live in Southern California so temps hit 100+ sometimes, and this is my daily driver. ....Alright! let's beat-it to DEATH...I agree with the VW shop!!!(914) Are you being sarcastic? This VW shop works on 914s as well, I just call it a VW shop since it's not everyday they have a 914 being worked on. Anyway I believe the reason why they recommended straight 40 weight is due to the fact that they have been around for so long that they might still be old school. Sorry for bringing up an old topic, didn't know it annoyed people so much |
Rand |
Sep 30 2014, 09:07 PM
Don't mind him.
Run 20w50 or Brad Penn. |
ripper911 |
Oct 1 2014, 08:51 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) 20w50.
Quick! Somebody get into the minutiae of the composition and characteristics of the different available oils. Oil threads are always good to see. It keeps an important detail fresh in our minds. You could be in a store that doesn't have your usual brands and think, I remember reading about what to look for in an oil for my precious 914 the other day. |
Ben and Ralph |
Oct 1 2014, 09:24 AM
Thanks everybody for your input. Probably going to pick up some valvoline vr1 20w50 today (IMG:style_emoticons/default/beer3.gif)
ripper911 |
Oct 1 2014, 09:26 AM
Thanks everybody for your input. Probably going to pick up some valvoline vr1 20w50 today (IMG:style_emoticons/default/beer3.gif) That's what I use. (IMG:style_emoticons/default/beerchug.gif) |
Cap'n Krusty |
Oct 1 2014, 10:31 AM
So the VW shop that rebuilt my engine had always recommended I use straight 40 weight motor oil. I took their word for it and have used it ever since my car has been running. Now I see that no one here on the world uses it! Have I been using the wrong motor oil? Should I switch? I live in Southern California so temps hit 100+ sometimes, and this is my daily driver. ....Alright! let's beat-it to DEATH...I agree with the VW shop!!!(914) Are you being sarcastic? This VW shop works on 914s as well, I just call it a VW shop since it's not everyday they have a 914 being worked on. Anyway I believe the reason why they recommended straight 40 weight is due to the fact that they have been around for so long that they might still be old school. Sorry for bringing up an old topic, didn't know it annoyed people so much "Old school" VW and Porsche guys used 30 weight. I AM "old school", and my long term memory is just fine. The Cap'n |
PotterPorsche |
Oct 1 2014, 01:36 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Brad Penn
steuspeed |
Oct 1 2014, 03:44 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Valvoline VR1 20w-50 high zinc content oil.
Cuda911 |
Oct 1 2014, 05:57 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
76-914 |
Oct 1 2014, 07:10 PM
Topics are beat to death only if you have been around here for several years. The reason they are beat to death is because we have a constant influx of like minded people joining our ranks. I didn't know shit from apple butter when I joined here but I do now. Shit from apple butter that is. I'm still learning these little cars that we all love. Newbies and curmudgeons alike. The Cap'ns advice is solid. Ignore the BS that was coming from the galleries. Did you get that engine bay rubber installed yet?
Lo-Fi Version | Time is now: 26th April 2024 - 11:41 AM |
