914-6 washer pump, not working.... |
siverson |
Oct 24 2014, 05:50 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
how is this supposed to work? i filled up the bottle half way and the pump motor just spins. if i pull off the suction/intake tube and stick it in a glass of water everything works.
it seems like my tank might be missing a tube to pickup water from the bottom of the tank. or is the tank pressurized or what? -steve Attached thumbnail(s) |
siverson |
Oct 24 2014, 06:12 PM
Weird... if you click on the image, it is no longer upside down.
I'm guessing the thumbnail generator does not honor the photo's orientation metadata, but the browser does when the original image is rendered. -Steve |
McMark |
Oct 24 2014, 07:41 PM
You're right about the image.
Do you have a 914/6 washer bottle? Or is it from a four? The four bottle is a pressure vessel and so is sealed. The six bottle is just a reservoir and has a vent. If you have the four bottle, try it with the cap off. |
McMark |
Oct 24 2014, 07:44 PM
Oh, just looked at the big pic and saw it is a six tank. I would still try it with the cap off and see if that works
Socalandy |
Oct 24 2014, 11:10 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
Cap off and prime it. you have the internal pickup tube?
914Sixer |
Oct 25 2014, 07:22 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Pumps are the same as the 911 of the period. Now available in reproduction.
siverson |
Oct 25 2014, 09:49 AM
internal pickup tube? that sounds like something im missing. any photos of what that looks like?
does the connector on top with the hose connections pop off? if so it would be easy to add a pickup tube, but i tried a little and it was stuck. i really dont want to break the tank. doesnt work the cap off either. right now its just sucking air so it makes sense that it would not work. and yes, this is a repro pump. an original was in the car but rusty and ratty looking. the repro is actually quite different from the original and is far from a perfect copy as advertised. but it looks close. |
type47fan |
Oct 25 2014, 10:14 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
internal pickup tube? that sounds like something im missing. any photos of what that looks like? does the connector on top with the hose connections pop off? if so it would be easy to add a pickup tube, but i tried a little and it was stuck. i really dont want to break the tank. doesnt work the cap off either. right now its just sucking air so it makes sense that it would not work. and yes, this is a repro pump. an original was in the car but rusty and ratty looking. the repro is actually quite different from the original and is far from a perfect copy as advertised. but it looks close. PM sent. |
altitude411 |
Oct 25 2014, 11:43 AM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
edit
altitude411 |
Oct 25 2014, 11:44 AM
edit again...
altitude411 |
Oct 25 2014, 11:46 AM
internal pickup tube? that sounds like something im missing. any photos of what that looks like? Please forgive the condition... just removed from a twenty-five year parking ticket. PO black paint. Why do they try and paint these? (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
Oct 25 2014, 12:22 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
and yes, this is a repro pump. an original was in the car but rusty and ratty looking. the repro is actually quite different from the original and is far from a perfect copy as advertised. but it looks close. If i recall correctly, a 911 washer pump of the same vintage is almost an exact match for the 914-6 pump. No need to go 'repro' ... (IMG:style_emoticons/default/smile.gif) |
siverson |
Oct 25 2014, 03:59 PM
thanks everyone. mystery solved. your photos gave me the confidence to pull hard on that top plug thing and it does just pop off.
and... somehow... mine is missing that intake tube. which is really strange because it could never work like this and its not loose in the tank. i'll just add some tube to get it to work. Attached thumbnail(s) |
siverson |
Oct 25 2014, 04:00 PM
914
siverson |
Oct 25 2014, 04:29 PM
> PM sent.
No PM for me... ? |
Lo-Fi Version | Time is now: 26th April 2024 - 11:30 AM |
