Help! just lost my tach, wipers, voltmeter, fuel gauge, 11-03-new question: how to id. the fresh air fan wire ----- (solution: always check and recheck fuses- #9 (4th from right) was off center not in tight |
DRPHIL914 |
Oct 31 2014, 04:19 PM
Dr. Phil Group: Members Posts: 5,760 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Don't know what happened- I also had lost my dash lights earlier, put in a new #7 fuse then o.k. then about 30 minutes later I ooze all that stuff and the center console everything - volt meter oil temp gauge and a/f meter all out- what to check first!
DRPHIL914 |
Oct 31 2014, 04:30 PM
Voltage while running is 13.5, -
Could this be an ignition switch going ( no issue starting) , or a bad light switch? Or a short at the tachometer?. |
type47 |
Oct 31 2014, 04:43 PM
(IMG:style_emoticons/default/icon_bump.gif) this thread for solutions. I'm chasing an electrical problem also. Number 9 fuse blows; alt light comes on; step on the brakes and the tach, and gauges die.
DRPHIL914 |
Oct 31 2014, 04:54 PM
And no signal lights.
Relay? I don't have my book so I don't have much info to trouble shoot this. |
DRPHIL914 |
Oct 31 2014, 04:58 PM
76-914 |
Oct 31 2014, 07:25 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
cig lighter/fan/wipers/horn all dead also?
Oct 31 2014, 07:41 PM
It's still a fuse. Remove each fuse and inspect.
--DD |
904svo |
Oct 31 2014, 07:52 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Just a WAG but could one of the RED wires on the battery terminal be broken off?
DRPHIL914 |
Oct 31 2014, 09:10 PM
DRPHIL914 |
Oct 31 2014, 09:15 PM
Yes horn, Wipers , blinkers all gone, but
When I brake, the gas gauge goes far left and the tach drops . Same happens when wipers or signal is used. |
DRPHIL914 |
Oct 31 2014, 09:55 PM
It's still a fuse. Remove each fuse and inspect. --DD Dave you were correct! When you suggested this I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " So I went back out to check this and it looked normal and in place but the top of the fuse was not in position tight! Once adjusted all is well. SO! I am definitely going to replace this fuse panel this weekend!!!! |
76-914 |
Nov 1 2014, 02:35 AM
DRPHIL914 |
Nov 3 2014, 08:11 AM
along this line, i have a question about the fresh air fan connection. my understanding is that is should be on the #9fuse circuit, but when i turn this fan on either low or high(only works on medium-but still goes slow) it will blow the fuse- but #8 not 9. so while i am doing the new fuse board, can i just trace the main power wire from the fan controls to the board or is there a power wire to the fan itsself? - i remember reading that the controls are just a ground circuit to relay to the fan and complete a circuit that would then drive the fan the proper speed. if so i have to figure out which wire is the fan wire because id like to get it put back to the correct circuit i have to assume a P.O. messed this up at some point .
So any suggestions on trouble shooting this would be appreciated. |
bdstone914 |
Nov 3 2014, 11:06 AM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Unbolt the control and pull it out far enough to inspect the contacts. If they look like this one it could be your problem. Also not the raised plastic between the second and third contact. I have seen this happen and raise the sliding contact and making high speed inoperative. Also check the ground wire from the control to the body under the dash.
bdstone914 |
Nov 3 2014, 11:07 AM
Attached thumbnail(s) |
DRPHIL914 |
Nov 3 2014, 11:59 AM
Unbolt the control and pull it out far enough to inspect the contacts. If they look like this one it could be your problem. Also not the raised plastic between the second and third contact. I have seen this happen and raise the sliding contact and making high speed inoperative. Also check the ground wire from the control to the body under the dash. The contacts look fine, clean no warping of plastic like that. I also switched the wires around and still only the wire connected in center will work so it must be the controller. I need to get a different controller that is known to work in all 3 positions to try and that would help with my trouble shooting. I have a second fresh air box I am going to bench test As well |
poorsche914 |
Dec 15 2014, 04:43 PM
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
... I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " And this is why I love this site... Driving to work this morning, my alt light came on, tach started acting funny and would drop to 0 when brakes were applied, plus other electrical glitches. Drove home after work, did a search, and found my answer in under 5 minutes (IMG:style_emoticons/default/aktion035.gif) Checked fuse #9 and, sure enough, it was bad. The metal piece fell right out! Replaced the fuse and back in business (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/driving.gif) |
76-914 |
Dec 15 2014, 05:00 PM
... I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " And this is why I love this site... Driving to work this morning, my alt light came on, tach started acting funny and would drop to 0 when brakes were applied, plus other electrical glitches. Drove home after work, did a search, and found my answer in under 5 minutes (IMG:style_emoticons/default/aktion035.gif) Checked fuse #9 and, sure enough, it was bad. The metal piece fell right out! Replaced the fuse and back in business (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/driving.gif) It was such a problem area that the Beetle's mentioned it on "The White Album"; number 9, number9,. number9................ (IMG:style_emoticons/default/biggrin.gif) |
DRPHIL914 |
Dec 15 2014, 08:54 PM
... I dug out my tech tips book- page 81 #611 : if the alternator light glows and the tach needle drops when applying the brakes this is a loose fuse #9, " And this is why I love this site... Driving to work this morning, my alt light came on, tach started acting funny and would drop to 0 when brakes were applied, plus other electrical glitches. Drove home after work, did a search, and found my answer in under 5 minutes (IMG:style_emoticons/default/aktion035.gif) Checked fuse #9 and, sure enough, it was bad. The metal piece fell right out! Replaced the fuse and back in business (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/driving.gif) Awesome. After that happened to me I decided to finally replace my board with the new one with blade fuses (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 1st May 2024 - 03:49 PM |
