3 Pages V  1 2 3 >
> Converting a Vanagon TB for use with 1.8 L-Jet, How I did it
MrKona
post Nov 2 2014, 08:36 PM
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet.
Pictures are worth a thousand words, so here goes..
Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS.
MrKona
post Nov 2 2014, 08:44 PM
I didn't want to simply make a new flat on the bottom of the shaft where it engages the TPS because there is already a flat on the other side. That wouldn't leave much metal. Also, I think it would be difficult to exactly duplicate orientation of the factory flat. I put a multimeter to the TPS when it was installed on the TB and found that the switch engages pretty precisely at closed and WOT. I don't think I could duplicate that exact angle by eyeballing it on the bench grinder.
MrKona
post Nov 2 2014, 08:48 PM
So I decided to use the shaft from the 1.8 TB. Only problem is that the recess in the shaft is sized for the smaller TB plate.
The 1.8 plate is 43mm in diameter, the vanagon plate is 48mm.
MrKona
post Nov 2 2014, 09:18 PM
So I decided the way to go was to lengthen the recess on the 1.8 TB shaft to fit the vanagon TB plate. 2.5mm on each side would do it. So I measured and taped it off to guide me with the bench grinder.
Geezer914
post Nov 2 2014, 09:20 PM
Geezer914
Great pictures! I just picked up a 2.1L throttle body on the Samba. (IMG:style_emoticons/default/piratenanner.gif)
MrKona
post Nov 2 2014, 09:24 PM
Brief intermission, and on a related note.. another one of my hobbies is vintage shop machines. My bench grinder is a 1962 Sears Craftsman that I rescued a few years ago and restored to it's former glory (and back to original colors).
MrKona
post Nov 2 2014, 09:27 PM
Five minutes of careful grinding on each side was all it needed. What a great thing that VW/Porsche used the same spacing between holes for both TB plates.
MrKona
post Nov 2 2014, 09:31 PM
And with that, I inserted the modified shaft in the Vanagon TB, attached the plate, assembled the spring mechanism... and I now have an enlarged TB that will fit the 1.8 L-jet system (for use on my 2.0 engine).
MrKona
post Nov 2 2014, 09:34 PM
One more note, you may have noticed already that there is a casting difference between the original TB and Vanagon TB where the TPS attaches. It feels pretty well anchored with one screw and of course the shaft that inserts into the TPS. Just for good measure, I put a zip tie around the non-screwed end and the vacuum port. I doubt it's needed, but it's just added assurance.
rick 918-S
post Nov 2 2014, 09:50 PM
Hey nice rack! -Celette
Nice work. Way to think out of the box.
Dave_Darling
post Nov 3 2014, 12:29 AM
914 Idiot
Peen or use Loctite on the throttle plate screws. You don't want one of them to fall out...
--DD
MrKona
post Nov 3 2014, 01:47 AM
QUOTE(Dave_Darling @ Nov 2 2014, 10:29 PM) *
--DD
Dave - thanks for the reminder. I'll peen them.
Valy
post Nov 3 2014, 02:11 AM
Did you try to use the vanagon throttle switch?
MrKona
post Nov 3 2014, 09:16 AM
QUOTE(Valy @ Nov 3 2014, 12:11 AM) *
No. There are two terminals on the Vanagon switch, and three on the l-jet, hence the wiring harness would need work. Didn't want to open that can of worms.
Root_Werks
post Nov 3 2014, 09:43 AM
Village Idiot
Really good write up and something I would have used on a L-Jet 2.0 a few years back. Well done!
Valy
post Nov 3 2014, 02:14 PM
QUOTE(MrKona @ Nov 3 2014, 08:16 AM) *
Thanks!
Does the bigger TB fit the rubber boot from the AFM?
pilothyer
post Nov 3 2014, 02:32 PM
Bryan Do you have the part number for this throttle body? also Would one from a 1.9 work or is there a difference in dimension? Thanks for a reply
MrKona
post Nov 3 2014, 10:46 PM
QUOTE(Valy @ Nov 3 2014, 12:14 PM) *
Thanks!
It sure does! The beautiful thing is that the outer diameter is the same on both. Here's a picture, Vanagon TB on the left, L-Jet TB on the right.
MrKona
post Nov 3 2014, 10:59 PM
QUOTE(pilothyer @ Nov 3 2014, 12:32 PM) *
The p/n for the late model, 2.1 Vanagon is 025 133 067. The earlier 1.9 Vanagon TB is 45mm, the same as the 1.8 L-jet TB. I only know this from the experience of removing one from a 1.9L only to find it was 45mm diameter.
type47
post Nov 4 2014, 06:15 AM
Viermeister
I wonder what is the size of the TB for the 912E. But finding one ... (IMG:style_emoticons/default/wacko.gif)
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 21st December 2024 - 10:53 AM
