4 Pages V < 1 2 3 4 >
> In Over My Head Restoration, No More Excuses - Just Start Cutting...
BeatNavy
post Jan 1 2015, 07:28 PM
Post #21
Excellent, thanks for the input, Scotty. I'll keep cutting, but based on your experience I'm sure you're probably right on (although I'm hoping I don't have to replace that suspension ear). I'll post more pictures hopefully this weekend and start saving up for my purchase at RD.
type47
post Jan 3 2015, 08:01 AM
Post #22
Viermeister
Incredible thread for a guy who joined 914world in Feb 2014! I am not worthy (IMG:style_emoticons/default/pray.gif)
ThePaintedMan
post Jan 3 2015, 08:20 AM
Post #23
Wow, nice progress Rob! Unfortunate that you ended up with such a turd of a car. Have you learned how to remove the spot welds yet? You'll need a decent spot weld bit, or do the grind away trick that Rick does. Much better than just hacking out portions of the unibody.
Might also be worth it to go further into the body before you order pieces from RD. That car looks like it had a lot of bondo and patches on it, so there might be more rust that lurks...especially front and rear trunks.
BeatNavy
post Jan 3 2015, 11:26 AM
Post #24
QUOTE(type47 @ Jan 3 2015, 09:01 AM) *
Hey Jim! You are more than worthy ... and wise ...and not foolish like I probably am. We'll see what I've got myself into. (IMG:style_emoticons/default/smile.gif)
QUOTE(ThePaintedMan @ Jan 3 2015, 09:20 AM) *
Hey George! No worries about the car. It's gives me challenges and plenty of opportunity to learn, which is a large part of what this effort is all about. I should have done a better pre-buy inspection, but what the hell? I'm using a spot weld removal bit, but I'm still learning my technique. It takes time. And I agree, I'm not ordering stuff until I get a better assessment of what I have to work with. Trunks do not LOOK bad, although they're heavily painted over. I'm sure PO wasn't trying to hide anything. (IMG:style_emoticons/default/dry.gif)
Right now I'm working on my other teener, trying to change output shaft seals (done) and rear bearings, based on the way you documented in your thread. Back from a wrestling tournament now, and I'm trying to get the driver's side axle out, but I'm pretty sure I have to remove the starter. Ugh...
ThePaintedMan
post Jan 3 2015, 11:55 AM
Post #25
Yep, not a bad idea to strip the trunks as well. My PO did a better job hiding the rust in them than he did with the rockers.
Yes, you do need to remove the starter to get the axle out (or it at least makes life a lot easier.)
post Jan 3 2015, 01:30 PM
Post #26
914-6 GT in waiting
QUOTE(BeatNavy @ Jan 1 2015, 08:28 PM) *
The suspension ear is one of the first things to go on these cars. battery acid and rain dripping down helped insure its early demise. the little drain hole was always plugged up and held the mixture inside against the untreated metal. 99% chance you will need a new one. Strip yours down and check.
BeatNavy
post Jan 3 2015, 02:32 PM
Post #27
QUOTE(ThePaintedMan @ Jan 3 2015, 12:55 PM) *
Wow, I got the starter out and the bearings in. But I barely got that half-shaft out even with removing the starter, and now I can't get it back in despite negotiating it all over the underside. Do you have to disassemble the half shaft at the CV or something? This is one of the most challenging things I've had to do...until the next thing.
EDIT: I'm going to start a new thread.
r_towle
post Jan 3 2015, 03:47 PM
Post #28
Custom Member
Not sure I am following this along, but don't put a car on a rottisierre with the enging installed.
type47
post Jan 3 2015, 04:06 PM
Post #29
Viermeister
I believe he's referring to his other daily driver 914. Seals, axles, starter stuff on the DD. Car undergoing surgery already sans drivetrain.
barefoot
post Jan 3 2015, 04:17 PM
Post #30
Anyway, after removing the drive axels with a gear puller and banging out the hubs, it was time to take out the rest of the trialing arm. Here’s a picture of the bolts connecting the arm to the body. There were two shims there (don’t know what size), and I know from reading here that these are important to rear wheel alignment. I imagine I did not do correctly whatever I’m supposed to do to make alignment easier upon install.
Stupid question #1: is it the number (or total size) of shims present and/or the positioning of the shims that determines the alignment?
when I was taking the rear trailing arms off I drilled up thru the bracket into the body structure so i could pin the exact location when re-assembling. Also noted what shims were on either side
BeatNavy
post Jan 3 2015, 05:45 PM
Post #31
QUOTE(type47 @ Jan 3 2015, 05:06 PM) *
Yes, thanks for the assist Jim. Yeah, sorry Rich. My daily driver. I should have been more specific.
r_towle
post Jan 3 2015, 06:40 PM
Post #32
Custom Member
Makes sense considering you are a long way from worrying about bearings.
BeatNavy
post Jan 11 2015, 01:08 PM
Post #33
Ok, last weekend was replacing bearings and tranny seals on my other teener – very greasy and dirty – this weekend it’s back to IOMH (in over my head) restoration and getting dusty. What better way to spend a weekend than in a cold garage cutting steel and bondo? So I put aside some time and did some more exploratory surgery. I’ll have at least three more stupid questions for anyone that can answer them as I assess and figure out how to repair:
1. The long up to the door frame
2. The suspension console and long inside engine bay
3. The hell hole itself
Based on what I saw this weekend, I think the “RD shopping list” Scotty helpfully put together for me in post #20 is looking pretty accurate about now.
First the long under the door. Cut away some more steel and here’s what I have (apologies for picture quality and lighting):
What??? Leftover mouse stuff in the heater channels?? (IMG:style_emoticons/default/new_shocked.gif) My first reactions to this are a) where did God’s little rodents live prior to the first 914? and b) is my spot-weld removing technique actually worse than my welding? Anyway, there was a fair amount of loose rust and other gunk in the longs. The lower third of the inner shell is possibly salvageable, but it gets to the question I have on this. Here are a couple of other views first:
and
And, after some cleanup and chipping away the loose and rusted metal:
and
So here is first stupid question, or set of stupid questions, for today (#4 overall): What I didn’t realize is that there are two layers of steel on the horizontal section of the long. Is that correct? I’m trying to decide if that’s the way it’s built or not. But I also see what might be a seam right underneath the first bracket for the heater hose. It’s rusted so much it’s hard to tell, but maybe that’s a layer of steel from a previous PO fix. In the picture above you can see the jagged edges where I’ve torn out one layer of rusty metal up to just under the heat pipe. The lower layer doesn’t look bad. The top layer has a lot of surface rust that could probably be treated and sealed.
Should I simply cut out that top layer to some point and fabricate a replacement to weld in attached to the inner shell and then marry up the outer long piece? I see how George cut the whole bottom section out and welded a horizontal section along a good portion of the long as shown here: College Budget Restoration
I guess the answer may sort of depend on whether there are really two layers of metal there and whether or not one or both should be replaced. If there aren’t two layers along that long, I think I can minimize the actual fabrication and replacement required on that inner long.
Oh, and the seat belt mount came out in the process. I’m not sure whether or not that can be cleaned up or not. I may have to fabricate a solution there. Right now that's not the biggest issue I have, as I'll post something on the suspension console soon...
boxsterfan
post Jan 11 2015, 01:33 PM
Post #34
914's are kewl
I really think you should change those jack stands out for ones that have pins in them. I don't think those "teeth" based ones are all that safe.
BeatNavy
post Jan 11 2015, 01:46 PM
Post #35
QUOTE(boxsterfan @ Jan 11 2015, 02:33 PM) *
Thanks for the comment. The car is also partially supported by the rotisserie right now, so even if those gave way it shouldn't go "anywhere." Hopefully.
Tilly74
post Jan 11 2015, 02:08 PM
Post #36
(IMG:style_emoticons/default/smilie_pokal.gif) Great work! You inspire the rest of us to get stuff done, and your "stupid questions" make me feel less stupid so keep on asking.
And definitely use extreme caution when under any vehicle, my father-in-law, a farmer his entire life and no stranger to working on heavy machinery, is dealing with two broken ribs after being run over by a semi over the weekend. Not a typo. He was using the appropriate jack stands, blocks, and wheel chocks. One of the wheel chocks started to slide and he couldn't get out in time. Almost cost his life. I only share this to serve as a reminder to all. 914's ROCK!
post Jan 11 2015, 02:13 PM
Post #37
Resident German
QUOTE(BeatNavy @ Jan 11 2015, 11:08 AM) *
Just get a new one ...
BeatNavy
post Jan 11 2015, 02:14 PM
Post #38
Yikes. That's scary, and yes, you are right. I hope he's feeling better soon. Never broken a rib (I don't think), but I'm sure it's no fun. Don't worry, I have plenty of stupid questions stored up... (IMG:style_emoticons/default/smile.gif)
BeatNavy
post Jan 11 2015, 02:17 PM
Post #39
QUOTE(SirAndy @ Jan 11 2015, 03:13 PM) *
Haven't seen them listed before, but if they are available it's probably the cheapest fabricated part I'll end up buying. Cool, thanks Andy.
post Jan 11 2015, 02:44 PM
Post #40
Resident German
QUOTE(BeatNavy @ Jan 11 2015, 12:17 PM) *
Hmmm, i remember someone making those, but now i can't find them. (IMG:style_emoticons/default/idea.gif)
The bolt/thread is M11 X 1.25 just in case you end up making your own ...
(IMG:style_emoticons/default/smash.gif)
- Lo-Fi Version Time is now: 18th December 2024 - 07:13 AM
