Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
I know this had been tried 7+ years ago, I was wondering if since then has anyone done a watercooled conversion and not put the radiator in the front trunk?
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,675 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Robert (rotary914) has. However, there is lots of free area with that tiny engine.
shoguneagle |
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California ![]() |
Master Mueller's "engineering mind" is back hard at it just as he never left. Wonder what creations are being planned????? Hope he never talks to the great Doc Evil and others; it will cost me money since I probably will want to build it.
Steve Hurt |
Mueller |
Master Mueller's "engineering mind" is back hard at it just as he never left. Wonder what creations are being planned????? Hope he never talks to the great Doc Evil and others; it will cost me money since I probably will want to build it. Steve Hurt Straying from the promise to the wife "I'll keep this one stock!" (IMG:style_emoticons/default/smile.gif) Just seeing what people smarter than me have come up with...not too difficult to achieve that! |
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
My 2.5 suby turbo goes up to get the final brackets and radiator made next week.
We will see what he says, but, with the shelf out, it looks like enough room for a dual core wide radiator with 4x12 inch fans. I am concerned as California gets a bit warm. I will let you know! |
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
jeep cherokee rad is like 10 x 36 and they make all AL versions.. shelf out , three fans mounted low I bet would work... but then again Bigkat shakes his head a lot at my ideas.....
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I always thought that using two small radiators in some IMSA. Style rear fender flares would be nice on a V8 conversion. Not subtle, but should have enough cooling capacity. I always liked the look of that Altec Lansing racer.
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,764 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I would love for the radiator to work in the engine compartment but logic says no. Heat from engine and little airflow work against it. Do you know of any production mid or rear engine car that makes it work- I dont. Again, I'm on your side. If I didn't feel it absolutely neccesary to mount the oil cooler on my gt build or the rad on my suby build up front, I wouldn't.
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,443 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
^^ Countach and Diablo.
GT engine lid and some scoops to increase airflow when you are moving. Fan tech has gotten a lot better this past decade. Spal 14" fans to 1840cfm. Max to fit under the lid 16" fan 2024 or 2467cfm ($$$). Can't find my notes but iirc mine's about 2600cfm for both and my break even point is around 30mph. Run an all aluminum engine... they dissipate heat better and they need to run hotter than old iron. |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Uh huh, that's the theory....
effutuo101 |
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans?
Inquiring minds want to know. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,105 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
It's also been done with an N/A Scooby motor. There are photos around here somewhere. Not sure what happened after the first few months with it, though.
--DD |
Mueller |
So, running an air cooled big 6 gets enough air. Why wouldn't a large 4 get enough with fans? Inquiring minds want to know. Exactly, water is a more efficient medium than air so if that compartment can shed 300hp worth of an air cooled* 3.6 it seems that same space can shed the heat from a 300hp 4 or 6 water cooled motor *anyone have the numbers how much cooling is really done by the oil? |
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
I always though a rear spoiler with a radiator enclosed would be the way to go but
I think the way a boxster does the dual radiator s in the front corners of the bumper is Brilliant And I would never hack up my front truck for water cooling , just stupid |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Mike, don't do it.
Keep it aircooled and drive it a lot sooner. |
veekry9 |
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada ![]() |
https://www.google.ca/search?q=f1+chassis&a...f-e%3B960%3B465
https://www.google.ca/search?q=f1+mid+mount...F%3B1680%3B1260 A new way to slice bread. Thermal conductivity of oil and water are known constants. Squirting oil to the bottom of pistons and tops of cylinder heads are effective methods. Air and oil cooled,a lot of oil,a lot of surface area. ![]() Do we have to put the rads up front? Making them fit in the middle down low will require some different approaches. |
veekry9 |
The fan is a centrifugal pump, just like any centrifugal water pump and it's power consumption is directly related to the mass of fluid it is moving. If you throttle the fluid, it'll use less power. Simplest solution that occurs to me is to use the flaps in the fan outlet housing tin to throttle the flow with a manual throttle cable that can be locked. Disconnect the thermostat bellows (I'm guessing that you've already done that to maximize the flow) and rig the throttle cable into the cabin somewhere handy between the seats. That way you can monitor head temp when driving on the street and not overheat by manually opening the flow when you want. If you've got a thermostat set up in your oil cooler plumbing it'll not open 'til 180F, so oil is going to warm up just as fast as without it, but you could shortcut the plumbing there to eliminate the flow to the front cooler without having to remove it. All that said, I'm concerned that trying to hurry up the warming process you may put stresses on the engine castings that may bring you grief......tread carefully! Moving a lot of air for the aircooled. Adding exchangers to cool the extra volume of oil with the associated weight. Being able to dissipate the heat of a high compression n/a or turbo engine reliably is it. 50 % efficiency of a 200hp engine means cooling 200hp of heat. |
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,562 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
Interesting side rad setup... would you have that much room on the sides and still keep all the rear trunk area? Maybe the rads would have some ducting to direct the airflow and you could run them flatter in the compartment to save room? I'm going with the upfront design but laying down at an angle but I'll definitely look into this setup for a turbo intercooler and oil cooler solution. (IMG:style_emoticons/default/idea.gif)
veekry9 |
![]() Step to the left. Step to the right. |
veekry9 |
![]() Not the first. |
Lo-Fi Version | Time is now: 22nd February 2025 - 10:42 AM |
