6 Pages V « < 3 4 5 6 >
> Any successful radiator in engine compartment conversions?, Or other than front trunk installs?
Chris914n6
post Jun 30 2015, 02:15 PM
Post #81
Jackstands are my life.
QUOTE(Andyrew @ Jun 29 2015, 07:51 PM) *
You talking about these puppies?
http://www.ebay.com/itm/DUAL-CORE-2-ROW-MO...735&vxp=mtr
Ya thats what I am going to use for my A/W Intercooler in my fender.
Yep. For a time I had plans for an a/w intercooler in the fender too. Scored a bigger engine instead.
Bill D
post Jun 30 2015, 06:36 PM
Post #82
For the TD I was able to fit the radiator next to the engine. I added a second radiator in the back (RUF oil cooler) where the muffler used to be. The alternator fit with plenty of room on the back side.Attached Image Attached Image Attached Image
Mike Bellis
post Jun 30 2015, 07:24 PM
Post #83
Resident Electrician
QUOTE(Bill D @ Jun 30 2015, 05:36 PM) *
I want to see more! Is this car running & driving?
Andyrew
post Jun 30 2015, 09:42 PM
Post #84
Spooling.... Please wait
Impressive that you were able to make that work! Adding additional cooling in the back makes perfect sense!
Bill D
post Jul 1 2015, 05:57 AM
Post #85
My project is no where near as ambitious as yours. Hats off....
The secondary radiator is plumbed just like a heater core in the stock application. There is a thermostatic switch mounted to the radiator. The plastic air deflectors were removed from the underside to allow air to flow naturally from bottom to top. The wiring is fairly simple.
matthepcat
post Jul 1 2015, 09:43 AM
Post #86
Meat Popsicle
I like it.
As I understand it the diesel runs cooler than petrol, so would this system struggle to keep up with a gas engine?
Bill D
post Jul 1 2015, 12:01 PM
Post #87
QUOTE(matthepcat @ Jul 1 2015, 11:43 AM) *
I like it.
I had some help in sizing this radiator a while back and decided i wanted extra capacity as i was thinking of adding AC to the mix and wanted the ability to box the secondary radiator in the winter and duct it so it would work like the original heater with an inline fan. i have since decided on heating the seats and have a small electric heater for defrost. don't need much heat in NC.
it would be a guess but i think this setup could manage 200hp with the right air flow and maybe an external oil cooler to help.
i am not counting on a diesel engine running cooler. my old benz dt had a radiator at least as big as the gas version
flmont
post Jul 7 2015, 07:13 PM
Post #88
Iam considering a 4.3 ltr chevy v6 system,.with a renegade water pump and Alt system,...and have the Rad ,.bolted but extended from the fire wall,..with fans, or have a rad built the size of the firewall,..also with fans should cool well,..that way I can go back to stk system,..??? build that v6 to around 280 HP with matching Tq specs..????
Mueller
post Feb 5 2017, 04:13 PM
Post #89
914 Freak!
Not a 914, but I think close enough, went to small car gathering this morning and this Northstar V8 swapped bug was there.
Guy said no cooling issues with the radiator in the middle not too far from the engine.
Running rubber scoops up underneath the car.
Mueller
post Feb 5 2017, 04:16 PM
Post #90
914 Freak!
I think what might help for any of these type swaps is to stay with an aluminum motor w/aluminum heads.
I was watching a video by a leading tuner of LS1 swaps and he mentioned when they use an aluminum block version of the LS they always run 15 to 20 degrees cooler than the iron block versions.
post Feb 5 2017, 06:27 PM
Post #91
914-6 GT in waiting
Why don't you do it and report back. You don't know until you try. Right?
sotaro
post Feb 27 2017, 09:21 PM
Post #92
QUOTE(mepstein @ Feb 5 2017, 04:27 PM) *
I am intrigued by the possibility of adding some kind of skin radiator to the rear trunk hatch. This would be a lot more work than it sounds, but it might be possible to reduce the amount of traditional tube and fin radiator area. Other body additions might include a wing or duck tail. Having two trunks is a great feature, and retaining it is a worth goal. Is it worth giving up high power?
On another topic, the air cooled engine cooling fins are usually quite a bit hotter than the fins of a radiator, often 50 to 100 degrees hotter. This reduces the amount fin area needed needed which is important given the limited fin area possible. Air flow is expensive in horsepower terms. As I remember, the 917 fan took 75 horsepower at maximum rpm.
Rand
post Feb 27 2017, 10:03 PM
Post #93
Cross Member
Aren't there examples of mid-engined sports/supercars with radiators behind the driver?
It could be done, but at the cost of some significant body mods and/or big ass fans and ducting.
Funny this topic has been discussed since the 70s. Have we seen a proven successful example yet in a 914?
post Feb 28 2017, 06:27 AM
Post #94
914-6 GT in waiting
Are the radiators in boxters in the front?
Andyrew
post Feb 28 2017, 07:05 AM
Post #95
Yes. Boxsters have two small ones and boxster S's have a third in the middle hence the small extra opening in the front bumper.
Check out the Neo914 build, he uses those radiators
post Feb 28 2017, 07:49 AM
Post #96
914-6 GT in waiting
QUOTE(Andyrew @ Feb 28 2017, 08:05 AM) *
So even with a clean sheet of paper, Porsche put the radiators of a mid engine car, in the front.
914forme
post Feb 28 2017, 09:03 AM
Post #97
Positive pressure is king to cooling.
And there is enough room in the front of the 914 if you want to do it, but you loose the head light buckets and the pop up lights.
You could also just do the AIR 934 body and just run them in one or both of the side fenders.
I so (IMG:style_emoticons/default/drooley.gif) over that car as a kid. 934 engine in the correct place, full Aluminum roll cage. half a 904 sitting in the background of the VW & Porsche mag article. (IMG:style_emoticons/default/wub.gif)
No not so much (IMG:style_emoticons/default/confused24.gif)
Andyrew
post Feb 28 2017, 09:17 AM
Post #98
QUOTE(mepstein @ Feb 28 2017, 05:49 AM) *
Correct, every water cooled porsche has had the radiator up front. They are however very efficient with radiator design in relation to the front bumper and hiding it well so they allow for as large a trunk as possible.
Mueller
post Feb 28 2017, 04:54 PM
Post #99
914 Freak!
Twin side mounted radiators, good enough for a big V8 (IMG:style_emoticons/default/wink.gif)
https://www.palatov.com/cars/d2/
post Feb 28 2017, 07:04 PM
Post #100
914-6 GT in waiting
QUOTE(Mueller @ Feb 28 2017, 05:54 PM) *
i thought you were asking for a 914?
- Lo-Fi Version Time is now: 22nd February 2025 - 02:09 AM
