> Is this part of the clutch?, I STILL NEED HELP
PanelBilly
post Dec 9 2014, 02:46 PM
Found this with the clutch parts. It looks like a bearing for the tranny, but I'm not sure. Is it part of the clutch assembly?
McMark
post Dec 9 2014, 02:50 PM
914 Freak!
pilot bearing
PanelBilly
post Dec 9 2014, 04:41 PM
So where does the pilot bearing go?
Mike Bellis
post Dec 9 2014, 04:42 PM
Resident Electrician
QUOTE(PanelBilly @ Dec 9 2014, 02:41 PM) *
In the flywheel
post Dec 9 2014, 04:45 PM
Resident German
Inside the center of the flywheel. It holds the front of the transmission shaft in place. Without it, the shaft will wobble and you'll have a substantial oil leak from the main seal.
There's also a felt washer needed in that location.
roblav1
post Dec 9 2014, 07:44 PM
Most engines I've seen have the pilot bearing in the crankshaft. Is the type IV in the flywheel?
I've also run a quality bushing there as well in my Ford powered formula cars.
r_towle
post Dec 9 2014, 07:45 PM
Custom Member
It goes in the pilot bearing hole.....duh
Cap'n Krusty
post Dec 9 2014, 09:08 PM
Cap'n Krusty
In the 914/4 it goes in the flywheel. The same engine in a bus uses a crankshaft mounted pilot bearing because the mainshaft is longer.
The Cap'n
McMark
post Dec 10 2014, 02:06 AM
914 Freak!
He wouldn't be here if he had a bus. (IMG:style_emoticons/default/tongue.gif)
Ha! I'm krustying the cap'n! (IMG:style_emoticons/default/zorro.gif)
Bleyseng
post Dec 10 2014, 08:27 AM
Aircooled Baby!
Make sure you have the spacer in the crank or the pilot bearing will move into the crank when you install the engine to the tranny.
PanelBilly
post Dec 10 2014, 11:46 AM
I think I'm Ben more confused now.
PanelBilly
post Dec 10 2014, 12:08 PM
So does the bearing slide onto the tranny shaft? and what about the felt washer?
wndsnd
post Dec 10 2014, 12:17 PM
You wanted a horse, but got a goat. Nobody wants a goat....
QUOTE(PanelBilly @ Dec 10 2014, 01:08 PM) *
See Andy's post #5.......
rjames
post Dec 10 2014, 01:23 PM
I'm made of metal
Both go in the flywheel. The felt washer towards the tail end of the car. Put a small amount of grease on the tranny shaft when installing. I would think that the grease in the pilot bearings should keep it from permanently impaling itself on the tranny shaft.
#5 is the bearing
#3 is the felt washer
McMark
post Dec 10 2014, 06:29 PM
914 Freak!
Okay, install the pilot bearing in the flywheel. Recess it 3.2mm (or so). You have to leave room for the felt washer. Drop the felt washer into place, and the 'lock plate' goes over everything.
sixnotfour
post Dec 10 2014, 06:56 PM
early 3.0 the bearing is in the flywheel, later 3.0's have an adapter that bolts to the crank with 3 bolts........really depends on what conversion flywheel you have....the bearing is common for all,,,,
You really need to provide more info... (IMG:style_emoticons/default/beer3.gif)
Jon H.
post Dec 11 2014, 05:49 AM
I always read that you when you replace the fly that the felt needs to be replaced but why does nobody ever mention the the o-ring thats in the flywheel- #6 in the diagram? I have replaced them before.
Jon H.
Cap'n Krusty
post Dec 11 2014, 08:27 AM
Cap'n Krusty
QUOTE(McMark @ Dec 10 2014, 12:06 AM) *
The 914 crankshaft has the machined socket for the bearing, and I've seen clueless folks install them there. I've also seen cars with pilot bearings installed in BOTH locations.
The Cap'n
post Dec 11 2014, 08:28 AM
Oh it gets mentioned. Usually by the guy that forgets to install it. (IMG:style_emoticons/default/happy11.gif)
Cap'n Krusty
post Dec 11 2014, 08:30 AM
Cap'n Krusty
QUOTE(Bleyseng @ Dec 10 2014, 06:27 AM) *
In forty plus years of wrenching, I've never seen a pilot bearing fit loose enough in the flywheel to allow that to happen.
The Cap'n
- Lo-Fi Version Time is now: 2nd January 2025 - 10:32 AM
