Cutting Tool, What is the best tool for cutting laierd sheetmetal/no torch |
xperu |
Dec 11 2014, 03:10 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I have a small area I want to cut out which is like two ply metal. Is a metal cutter best or jigsaw. I will have to buy whichever one, so I thought I'd ask. Thanks Mike
76-914 |
Dec 11 2014, 03:22 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
madmax914 |
Dec 11 2014, 03:38 PM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
If its in an open area an mostly flat I'd use a jig saw with a metal blade. If its tight and uneven I'd use a 4-1/2" cut off wheel on a grinder. If you're cutting out an area and not starting on the edge you'll need the cut off wheel to cut through the metal so you can use the jig saw.
stugray |
Dec 11 2014, 03:54 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
If you have the room to get in there, my first choice would be a rotary cutoff tool.
The pneumatic ones from HF work great and they come in different orientationsof the disk wrt the handle. Only about $10 if you have compressor. http://www.harborfreight.com/air-tools/spe...tool-69473.html |
Mark Henry |
Dec 11 2014, 05:35 PM
A small angle grinder with a razor blade grinding wheel does a nice job.
barefoot |
Dec 11 2014, 07:21 PM
Senior Member Group: Members Posts: 1,337 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I've used a multi-tool. HF sells one and has lots of cutting wheels/saws.
It's a fast oscillating tool, so differs from a cut-off wheel pneumatic tool. But you can start in the middle and not at an edge. |
Amphicar770 |
Dec 11 2014, 08:19 PM
Senior Member Group: Members Posts: 1,214 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
http://www.eastwood.com/air-body-saw.html Easier to maneuver than a jigsaw.
A cutoff wheel makes some clean, straight cuts as well. |
Lo-Fi Version | Time is now: 15th January 2025 - 02:48 AM |
