is an LS1 too much power ? |
got914? |
Dec 14 2014, 11:50 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Anyone who has owned does own or driven an LS1 or similar power.
IM asking if this is too much power ? Is traction too hard to acquire ? I dont really want a burnout queen, if ya know what i mean |
Mike Bellis |
Dec 15 2014, 12:07 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
It depends on how the chassis is setup. Don't expect to drop an LS1 into a stock 914 and expect it to handle well.
arkitect |
Dec 15 2014, 12:34 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
ChrisFoley |
Dec 15 2014, 08:14 AM
I am Tangerine Racing Group: Members Posts: 7,967 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Too much power?
Depends on how the car is set up and what you're trying to do with it. |
GeorgeRud |
Dec 15 2014, 09:11 AM
As the late Mark Donahue stated, "only if you can spin the tires in top gear at the end of the straight". (IMG:style_emoticons/default/wink.gif)
DBCooper |
Dec 15 2014, 09:13 AM
There's no such thing as too much power. No one says you have to use every horse that's back there, so as long as it's you pressing the gas pedal you always get exactly what you need, as long as it's there. Never too much, just some extra you maybe aren't using. Now on the other hand it's really easy to have NOT ENOUGH power, when you're pressing your foot through the damned floor but nothing more is happening. That's much worse, not having enough when you need it, because there's nothing you can do about it. You're not catching that guy, you're stuck and you're gonna lose.
Just be aware that the car will need to be upgraded so the chassis and all the other systems are equal to any new power you put back there. That's a different question. |
Andyrew |
Dec 15 2014, 09:50 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
350 hp/tq LS1?
I would say its just right. Its also EXTREMELY linear, you can always back off of the throttle a little bit in 2nd and 3rd (You wont use first) until you get traction. You would need decent tires and decent suspension/brakes to make it feel right. Where your going to light the tires up is under ~ 40mph. Since it has a perfectly flat torque band it will light the tires up (Depending on compound and width) if you simply mash on the gas. However if you learn to roll on it, it'll be just fine. You could always just put a stop behind the gas pedal so you only use as much power as you want.. say 75% of it.. |
Rand |
Dec 15 2014, 12:09 PM
Too much power? Depends on the driver. There's this thing called a throttle. If you use it wisely, there's never enough. Yeah, dump the clutch off the starting line, vs passing someone on a track at 100mph. I guess if you have to ask, then yes, it's too much.
andys |
Dec 15 2014, 12:22 PM
There's a gas pedal to modulate the power, so it comes down to how you drive it. At 340HP, or so, it's not over-powered, in my opinion. Gobs of torque; yes....Fast; yes. I took my LS1 car to The Streets of Willow Springs for the sole purpose of adjusting and characterizing the chassis handling. I had no misconceptions of what I was looking for; a street car with predictable handling at its limits, and not a race car. It's a compromise, of course, but I like how surprisingly smooth the car rides after my suspension's final setup. I can, however, feel the increased rear CG, which does tend to upset the handling a bit.
All that said, it's not "too much power," but then it depends on what you're used to along with the understanding of how not to get yourself into trouble because of it. Andys. |
CptTripps |
Dec 15 2014, 01:01 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Power to go forward is one thing...power to STOP reasonably is almost more important.
Don't put an LS1 in, and expect the stock brakes to be able to take you from 100 to 0 in reasonable distance. The car will be quite a bit heavier and have a different center of gravity. |
pdlightning |
Dec 15 2014, 04:24 PM
Pdlightning Group: Members Posts: 208 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
350 hp/tq LS1? I would say its just right. Its also EXTREMELY linear, you can always back off of the throttle a little bit in 2nd and 3rd (You wont use first) until you get traction. You would need decent tires and decent suspension/brakes to make it feel right. Where your going to light the tires up is under ~ 40mph. Since it has a perfectly flat torque band it will light the tires up (Depending on compound and width) if you simply mash on the gas. However if you learn to roll on it, it'll be just fine. You could always just put a stop behind the gas pedal so you only use as much power as you want.. say 75% of it.. Why not employ a parachute while you drive or deploy an anchor, like I am going to do? I am using a higher/ R/P in my 915 trans, so I can use all 5 speeds without always frying the tires! BUT, I like the block behind the throttle! (IMG:style_emoticons/default/smile.gif) AndyS, put it exactly! |
Dec 15 2014, 06:01 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Heck, sometimes a stock four-banger is too much power for me!!!
--DD |
EdwardBlume |
Dec 15 2014, 07:42 PM
JRust |
Dec 15 2014, 08:01 PM
914 Guru Group: Members Posts: 6,310 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I have driven an LS1 in Jerry Mahoney's beautiful 914. While the clutch was slipping for the 3 hour trip. It kept me very tame as if I gave it much gas it would slip. Having said that that motor is absolutely sweet. Even milking the throttle it was still fast. I bring this up because while it has a lot of power when you want it. It can drive extremely tame if you like. It is so smooth it is a joy to drive. You can still get mid 20's mpg gallon very easily. I would recommend a Boxtser S 6 speed tranny though rather than a 901. I did drive it with a 901 & it was fine. It is tough to beat a nice new transmission with cable shift though. I would have zero reservations about putting an LS1 in my car. I happen to really love the suby setups though. So I am not looking to do an LS1 (IMG:style_emoticons/default/confused24.gif) At least not today (IMG:style_emoticons/default/evilgrin.gif)
timothy_nd28 |
Dec 15 2014, 08:13 PM
Hey since we are on the topic with LS motors, my winter project is retrofiting a LS4 into my 914. I will build a engine cradle that will bolt to the original engine mounts. I was planning on using 2" square tubing, would I be okay with using 1/8" square tubing or would it be better with 1/4" tubing? (IMG:style_emoticons/default/welder.gif)
messix |
Dec 15 2014, 08:29 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
when the chassis is being torn apart then you have too much power.
everything up to that is almost enough. |
Rand |
Dec 15 2014, 09:05 PM
I just don't get the guys who ask about power. The throttle isn't an on/off switch. Learn how to use it. I guess the answer is, if you have to ask, then it's too much.
messix |
Dec 15 2014, 09:44 PM
I just don't get the guys who ask about power. The throttle isn't an on/off switch. Learn how to use it. I guess the answer is, if you have to ask, then it's too much. yea... you just don't get the too much power thing... throttle aside there is a point where there isn't any more use for more power, think 1/4 throttle and boiling tires. |
Rand |
Dec 15 2014, 11:44 PM
I just don't get the guys who ask about power. The throttle isn't an on/off switch. Learn how to use it. I guess the answer is, if you have to ask, then it's too much. yea... you just don't get the too much power thing... throttle aside there is a point where there isn't any more use for more power, think 1/4 throttle and boiling tires. I totally do. Factor in speed. Boil the tires at 10mph, or pass a string of cars at 110mph. Yes you can have too much power if you don't know how to use it. But at some point you are going fast enough that it doesn't boil tires any more. This thread is about an LS engine, not 10000hp. And like I said, if you have to ask, then it's too much power for you. |
rnellums |
Dec 16 2014, 06:37 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I'd love to see someone develop a speed-based variable drive by wire where full pedal travel gives you zero throttle to loss of traction, regardless of speed.
Lo-Fi Version | Time is now: 21st December 2024 - 06:14 AM |
