pedal boxes, 911, 912, 914 |
Harpo |
Dec 20 2014, 10:48 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good morning everyone
Are all of the pedal boxes the same between the 911, 912 & 914? For all years? Thanks David |
914Sixer |
Dec 20 2014, 11:30 AM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Short answer is NO. Up to 73 the boxes are the same. After 74 and later 911's added extra components for the different transmissions and power brakes.
bdstone914 |
Dec 20 2014, 01:52 PM
bdstone914 Group: Members Posts: 4,741 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Good morning everyone Are all of the pedal boxes the same between the 911, 912 & 914? For all years? Thanks David SWB cars did not have a bracket for the brake switch on the housing. 69-73 are almost the same. The upper clutch pedal on 911 912 are straight and 914 are offset. Some other parts are different but functionally interchangeable. |
GeorgeRud |
Dec 20 2014, 03:33 PM
The length of the clutch release lever is also different. Only a concern if you're installing a 915 transmission as you need more cable travel to properly release the clutch while shifting. Other minor differences, but easily modified as needed.
Harpo |
Dec 20 2014, 06:13 PM
Thanks guys
Lo-Fi Version | Time is now: 2nd January 2025 - 04:34 PM |
