Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,145 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
This is a group buy for front turnsignal bucket LED boards, rear tail/brake light LED boards, and rear turnsignal LED boards.
Please respond to this thread if you are interested. Purchase requests will be handled in order as they are recieved in this thread. The only thing group buy of these boards are the bare PCBs. The boards are hand assembled one by one, tested and delivered as they are finished. I will not request payment until your PCBs are to be assembled. Time between payment and shipping should be about 2 weeks. This group buy will last several months so please be patient. I will PM you when I am prepared to assemble your boards. If I PM you and your plans have changed, please let me know. Front LED and rear LED boards will be shipped separately. Shipping for CONUS for front or rear LED boards is $10. @@@@@@@@@ Now is a good time to seal up the front and rear buckets to protect your LED board investments. I am very pleased to be able to offer bundle pricing for front and rear bucket and rear lens seals by 914Rubber for anyone purchasing front or rear LED boards. Prices: Front bucket seals: $12.50 savings of 24% over retail Rear housing seals: $16.00 savings of 33% over retail Rear lens beads: $5.00 savings of $28% over retail Front Bucket Seal Rear Housing Seal Rear Lens Bead |
Spoke |
The rear LED board is available in 3 different configurations:
1) Brake Light: RED LEDs: Price: $90/pair 2) Turnsignal: RED LEDs: Price: $90/pair 3) Turnsignal: AMBER LEDs: Price: $90/pair Shipping: CONUS: $10 Outside CONUS: Determined at purchase. CONUS payment examples: Brake LED only: $90 + $10 = $100 Brake LED and RED/AMBER Turnsignal LED: $180 + $10 = $190 Each pair includes: o 2 PCBs o Brake/Taillights: 56 RED LEDs o Turnsignals:56 AMBER (Euro) or RED (US) LEDs - Rearward facing; 8 side-facing LEDs to replace the small side running light. Side LEDs are AMBER (Euro) or RED (US) to match taillight lens. Electrical Connection: o Brake: Pigtail with 1157 base to plug directly into existing bulb socket. o Turnsignal: Pigtail with 1156 base (turnsignal) and 5007 base (small side light) 6 clips for each pair to mount the boards to existing taillight housing for plug-n-play installation. 6 screws per PCB pair for clips + 1 extra 1 piggyback spade connector per turnsignal PCB pair in case existing turnsignal flasher is replaced by EP36 LED flasher from your FLAPS. 1 year guarantee Electrical Characteristics: Brake/Turnsignal: 0.35A @ 14V (4.9 Watt) each PCB Taillight: 0.06A @ 14V (0.8 Watt) each PCB Example boards shown with early prototype brass clips. Clips are plastic for these boards. Attached image(s) ![]() |
Spoke |
The front bucket LED board is available in 3 different configurations:
1) US Version: All AMBER LEDs: $120/pair 2) Euro Version - No Blanking: WHITE LEDs in clear of lens; Rest AMBER LEDs: Price: $130/pair 3) Euro Version - w/Blanking: WHITE LEDs in clear of lens; Rest AMBER LEDs: Price: $140/pair Shipping: CONUS: $10 Outside CONUS: Determined at purchase. CONUS payment examples: US Version: $120 + $10 = $130 Euro Version - No Blanking: $130 + $10 = $140 Euro Version - w/Blanking: $140 + $10 = $150 Each pair includes: o 2 PCBs o US Version: 69 AMBER LEDs. o Euro Versions: 21 WHITE LEDS (Running lights) and 48 AMBER LEDs (Turnsignal). Euro Version with optional blanking will turn off WHITE LEDs when turnsignal is engaged. Pigtail with 1157 base to plug directly into existing bulb socket. 4 clips for each pair to mount the boards to existing front bucket housing for plug-n-play installation. 4 screws for clips + 1 extra 1 piggyback spade connector if existing turnsignal flasher is replaced by EP36 LED flasher from your FLAPS. 1 year guarantee Electrical Characteristics US version: Turnsignal: 0.39A @ 14V (5 Watt) each PCB Running light: 0.07A @ 14V (1 Watt) each PCB Example front LED board shown with only tools needed: large Philips screwdriver for lens screws and smaller Philips screwdriver for PCB mounting screw. ![]() |
Spoke |
Installation of the rear LED boards.
For the brake/tailight PCB, 2 long straight clips go toward the inside of the car, one short clip on the outside of the car. Screw in screws so the clips are loose. ![]() ![]() After removing the bulb and securing the LED bulb base, gently press in the board evenly side to side. ![]() Once the board is seated, gently tighten screws until tight. Try not to overtighten. ![]() For the turnsignal PCBs, screw in the 2 long clips with a bend on the side of the board with 2 holes. The side with one hole uses the largest clip mounted on the bottom of the board as shown. You can gently tighten the clips before mounting. ![]() ![]() After removing the bulb and securing the LED bulb base, gently press in the board evenly side to side. ![]() The clearance of the lens and the clips between the brake and turnsignal is very tight. Make sure the lens does not get caught on the clips. It should fit right between the clips. ![]() |
Spoke |
Installation of the front turnsignal bucket LED boards.
There are 2 clips for each board. The small one goes in front the the long one on the rear. ![]() Screw in the rear clip. ![]() The small front clip mounts on the top of the board. These will be screwed in when I build the board. The bottom of the board will contact the bucket base to keep the board straight. ![]() Here's the board ready for installation with the bulb base connected. ![]() When installing the board, make sure the pigtail does not interfere with the rear clip. ![]() Gently slide the board in. There are slots on either side of the board to clear the guides on the sides of the bucket. ![]() Ready for the lens. The lens will hold the board in place. If you need to reposition the board, do not grab the LEDs as they will move. Use a paper clip or similar wire to pull the board out. ![]() |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
I'll take a full set!
front: Brake Light: RED LEDs + Turnsignal: AMBER LEDs rear: Euro Version - w/Blanking Thanks! -Steve |
Firstcar |
Obsessive amateur mechanic ![]() ![]() Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States ![]() |
Jerry,
I'll take a set of the front bucket LED board Euro Version - w/Blanking and a piggyback spade connector for the new relay! Thanks -Scott |
A&P Mech |
Member ![]() ![]() Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains ![]() |
I am in for a full set. I would like the US version for the front buckets as well as the rear brake light and turn signals.
Thanks, Ray |
griffindoug |
Newbie ![]() Group: Members Posts: 45 Joined: 24-June 14 From: Austin TX Member No.: 17,539 Region Association: Southwest Region ![]() |
Spoke,
I would like a set of the rear Red Brake, and amber turns with shipping for 190.00 Thanks Doug |
peteyd |
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada ![]() |
Please put me down for a front bucket LED board in the US Version
Thank you, Pete |
chads74 |
Member ![]() ![]() Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States ![]() |
I am in for a front set option 3) Euro Version - w/Blanking: WHITE LEDs in clear of lens; Rest AMBER LEDs:
I remember seeing something about needing something additional to make the blinkers work if you have front and rear LEDs installed. Am I remembering correctly? |
Steve Snyder |
Member ![]() ![]() Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States ![]() |
I would like a set of rear brake boards (just the brakes: $90 + shipping) and a set of front Euro turn signal boards with no blanking ($130 + shipping).
I do not need any seals, but thank you for making that option available. |
Zimms |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest ![]() ![]() |
I am in for front turn signals, euro, non blanking
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Cool. Very Cool. (IMG:style_emoticons/default/aktion035.gif)
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,832 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
I'm in for the following:
Front: Euro Version - w/Blanking: $140 + $10 = $150 |
R_u_dd |
Member ![]() ![]() Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest ![]() |
I am interested in the Euro Front amber/white, so that I may use the front light as a white running light and turn signal. I have no side turn signals up front, so I need the blinking capability. Is that what blanking is? Please explain. So, yes put me down for a front end Euro configuration. Thanks
GermermanCarGuy |
GermanCarGuy ![]() ![]() Group: Members Posts: 81 Joined: 13-May 14 From: Rapid City, SD Member No.: 17,346 Region Association: Upper MidWest ![]() |
Still in for:
Rear Brakes Lights (pr) Rear Amber Turn Signals (pr) and Front Euro w/blanking (pr) Very excited. (IMG:style_emoticons/default/piratenanner.gif) Please bundle with complete seal package (f/r) as advertised in your Posted Feb 5 2015, 08:59 PM post. Still excited. (IMG:style_emoticons/default/piratenanner.gif)(IMG:style_emoticons/default/piratenanner.gif) |
rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,670 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
Sign me up for a pair of the us front turn signals! I love my rears!
-Ross |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,321 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
I'm in for a set. Front Euro's....
75-914 |
Newbie ![]() Group: Members Posts: 7 Joined: 4-March 14 From: Prattville, AL Member No.: 17,073 Region Association: None ![]() |
Count me in for front/ rear euro type
Lo-Fi Version | Time is now: 2nd April 2025 - 11:37 PM |
