12 Pages V « < 7 8 9 10 > »
> LED Front Turnsignal And Rear Brake/Taillight/Turnsignals
Steve
post Dec 3 2015, 05:58 PM
Post #144
I installed the euro ones front and rear. The fronts have the blanking circuits. They work great and the light output is night and day better. My flasher relay works fine, but the dash light stopped flashing. At this point I do not know if it's related to the led lights. I have done a lot rewiring with the new gauges. Hopefully I will have time to play with it this weekend.
SKL1
post Dec 3 2015, 06:23 PM
Post #145
Have the euro fronts on the '73 and love how they work with the top blinker and bottom running lights. SO much better than those cheap "kits" to make the euro lenses work appropriately.
Rear euro lights with brake lights also work great with much better output than stock on my '71.
Just need the US rear sets for the '73 when Spoke starts his new run. Didn't order them in time with his last run...
Spoke
post Dec 3 2015, 07:50 PM
Post #146
Jerry
QUOTE(Steve @ Dec 3 2015, 06:58 PM) *
You have a single L/R dash indicator, correct?
Your stock flasher still flashes with LED turnsignals because the flasher does a dual purpose: Flash the turnsignals and flash the brake indicator.
See the diagram below for 74+ 914's with the single turnsignal dash indicator. Notice the coil and relay contacts next to the 49A and C pins on the flasher. This secondary relay allows the brake indicator to flash the small, low current bulb in the dash without flashing the L/R indicator.
When the very heavy load turnsignal bulbs are connected when either the turnsignal stalk is active or the 4-way flasher pulled, this secondary relay will close and flash the L/R indicator. With LED turnsignals which are a very light load are active, there is not enough current to pull in the secondary relay and the L/R indicator does not flash.
Question: does the L/R indicator flash when the 4-way flasher.
There's not a plug-in replacement for this flasher with the secondary relay. Thank Porsche for that little feature. There is an EP26 flasher available with 4 pins like the original. Unfortunately the K/C/C2 pin on EP26 is not connected to anything. I did modify an EP26 to power the K/C/C2 pin for one guy.
Personally I'm not a fan of the single L/R indicator. I think it's stupid. On my '74 914, I purchased an early tach, removed the guts and installed the guts from my '74. This way I had dedicated L and R indicators.
StratPlayer
post Dec 3 2015, 07:54 PM
Post #147
StratPlayer
I'm having the same problem,, turn signals work fine dash light doesn't work. Late model single L/R dash indicator.
Spoke
post Dec 3 2015, 08:18 PM
Post #148
Jerry
QUOTE(StratPlayer @ Dec 3 2015, 08:54 PM) *
There are 2 solutions to this:
1) Buy an early tach and use it with separate L and R indicators. I did this with my '74.
2) Buy an EP26 and modify it. I've hesitated offering to provide modified EP26's just because it's a pain in the ass. Had to pop the lid off, unsolder the relay and modify the PCB and put it back together. It bums me out that folks lose their dash indicator when switching to LED turnsignals.
Would you be interested in purchasing a modified EP26 from me? Being up front, the EP26 is $15 at our FLAPS, $20 to do the mod and test, and $5 shipping (CONUS); $40 total.
One caveat to the modified EP26: When the e-brake or MC failure lights are on, the turnsignal dash indicator would also flash. EP26 does not have the secondary relay to prevent the turnsignal dash indicator from flashing with brake stuff.
Steve
post Dec 3 2015, 08:20 PM
Post #149
QUOTE(Spoke @ Dec 3 2015, 05:50 PM) *
The tach is a six tach, but I just use one bulb in it.
I'll check the flasher and bulb this weekend.
Spoke
post Dec 3 2015, 08:32 PM
Post #150
Jerry
QUOTE(Steve @ Dec 3 2015, 09:20 PM) *
So the tach has L and R bulbs but you just use one to be consistent with your flasher?
If it were me, I would put L and R indicator bulbs in, wire a contact from each bulb to ground, and the other sides of the bulbs right to the turnsignal wires at the 4-way flasher where all the exterior turnsignal wires converge. Did this on my '74 when I rewired for an early tach with separate L and R indicators.
Steve
post Dec 4 2015, 12:43 AM
Post #151
QUOTE(Spoke @ Dec 3 2015, 06:32 PM) *
That makes sense and easy to do.
Thanks!!
rgolia
post Dec 4 2015, 02:01 PM
Post #152
GeoJoe
Spoke - I have the same issue. I think going for the tach swap out is the way to go. So I will now go looking for a tach. How is the new group buy coming along? I previously noted that I am in for a set of US tail lights.
Spoke
post Dec 4 2015, 08:21 PM
Post #153
Jerry
QUOTE(rgolia @ Dec 4 2015, 03:01 PM) *
The rear PCBs are in the fab now. Expect them back in less than 2 weeks. I'll start a group buy thread in a couple of days to get things going.
We're going to start with rear PCBs then add front turnsignals just to keep the workload at a manageable level.
Spoke
post Dec 16 2015, 08:18 PM
Post #154
Jerry
Rear boards are back from the fab. Look for a new GB thread in a couple of days. We should be able to start shipping after the new year.
whitetwinturbo
post Mar 23 2016, 12:46 PM
Post #155
Just got and installed front LED's .... NICE. (IMG:style_emoticons/default/piratenanner.gif)
Left from front picture shows LED and right/driver from the front shows stock bulb. Note bottom section of stock is much less bright.
db9146
post Apr 7 2016, 02:49 PM
Post #156
Spoke, I have a question.
If I mask off the LEDs, can I paint the PWB beneath? On the previous version Euro front set, the green can be seen somewhat through the Euro lens (particularly the clear bottom portion) and I was wondering about a way to cover that up.
Thanks.
Luke M
post Aug 11 2016, 05:16 AM
Post #157
(IMG:style_emoticons/default/icon_bump.gif) for a great product...
I installed Spoke's LED kit in the front and rear housings.
It didn't take too long and it was pretty easy to do.
I'd say best upgrade and money well spent on this.
Also thanks to 914rubber for making the seals used to finish sealing these up.
Thanks again for offering these products..
jim_hoyland
post Apr 19 2019, 08:24 PM
Post #158
Get that VIN ?
Fantastic product, just finished converting the rear brakes lights, backup lights, and turnsignsls. Each board is made to fit like a glove and the connectors are high quality: not likely to corrode.
Next: gonna do the fronts
jim_hoyland
post May 14 2019, 06:10 PM
Post #159
Get that VIN ?
The front Euro lights need to be upgraded now. Here's a pic of my set up. It's a little different; I made a custom separate white light holder for the lower portion.
The Amber part has a dual filiment bulb for running and turn signal; the White part is a single filiment bulb. The wire that connects the White bulb has a female connector on the end.
I will remove the lower bulb support/holder so to make room for the new board
Will PM too
Spoke
post May 14 2019, 06:26 PM
Post #160
Jerry
QUOTE(jim_hoyland @ May 14 2019, 08:10 PM) *
Will PM too
Jim,
Just to confirm, does the bulb for the turnsignal also light up dimly for just running lights? Is the bulb socket still like OEM for a 1157 bulb?
Also does the amber part of the lens light gently for running lights with the white light on?
jim_hoyland
post May 14 2019, 06:52 PM
Post #161
Get that VIN ?
QUOTE(Spoke @ May 14 2019, 05:26 PM) *
Will PM too
Jim,
YES
YES
petza914
post Oct 25 2019, 08:25 AM
Post #162
Finally got around to installing the full spokeworks exterior LED kit into my 914 that I got last Christmas. Much brighter, lower power consumption, and some cool features like the front white lights turn off when the amber turn signals are activated. Linked instructions were very good, fit was very good.
Very happy with the results
I have some led bulbs for the front headlights yet to install behind my H4 lenses to complete the job.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
ValcoOscar
post Oct 25 2019, 08:30 AM
Post #163
Garage Life
Spoke's LED lights are one of my favorite mods. Keeps our cars a bit more visible out on the road. Thank you!!!
I hope to buy some more soon...
Oscar
- Lo-Fi Version Time is now: 19th April 2025 - 05:49 PM
