Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,149 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
@horizontally-opposed
Pete, thanks for evaluating this. I think the white filament will work for the front turnsignals with white PCB. I can get silver or gray filament for the rear lights. |
drem914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California ![]() ![]() |
I'm updating the Euro front turnsignals to add more white LEDs. Recently I did a brake light for an MG. It was a tiny board and I jammed 48 LEDs on to it. That got me thinking about the 914 Euro front turnsignals. Spoke,The current design has 21 white LEDs and the board is designed for both Euro with 21 white and 48 amber LEDs as well as the US configuration with all amber LEDs. I wanted to jam as many white LEDs as possible where they would all shine through the clear part of the Euro lens. The first design is V7 below with 33 white LEDs. This design is completely routed and ready for the fab house. Upon further review, I wanted to jam even more white LEDs on the board. One thing I noticed about the board and the Euro lens, was that I could see the first row of amber LEDs through the clear portion of the lens. That means I could add another row of white LEDs and they would shine through the clear part of the lens. This design is shown below as V8 and has 42 white LEDs. Twice as many as the current design. Even though the V7 design is ready for fabrication, I think I want to do the V8 design with more LEDs. Still need to do the final layout for this board. @rmital Ray, this means your front turnsignals will be delayed until I finish the layout, get the board fabricated and assembled. Sorry to make you wait but it should be well worth it. V7 - 33 White LEDs V8 - 42 White LEDs Thanks for your work on the LED lights! The brake light boards are GREAT--as the others said, they provide a huge improvement in visibility and safety. Is the latest version of the front Euro turn signals (V8 w/42 white LEDs?) available yet? I've got a tax return burning a hole in my pocket (IMG:style_emoticons/default/biggrin.gif) Thanks! Steve A- @Spoke Just checking in to see if the V8 front Euro lights are getting close. When they are, I'll have a pair of V7 Euros with black PCB available for someone else at a discount. |
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,769 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
Just checking in to see if the V8 front Euro lights are getting close. When they are, I'll have a pair of V7 Euros with black PCB available for someone else at a discount. Same here, I use them as marker lights when driving for more visibility (IMG:style_emoticons/default/beerchug.gif) |
Spoke |
Just checking in to see if the V8 front Euro lights are getting close. When they are, I'll have a pair of V7 Euros with black PCB available for someone else at a discount. @drem914 Thanks for the reminder. Yes, I have the new Euro front lights with 42 white LEDs in black and white. The price is the same as before. I have 2 sets of white Euro front lights with 21 white LEDs which I will put on the Discount Corner page. The price for these 2 sets will be $125. Now that I have brake and rear turnsignal boards in white, I'm adding reverse LED boards in white as well. Attached thumbnail(s) ![]() |
drem914 |
@Spoke
So orders placed on your site for the euro front turn signals set up will be V8 and not v7 correct? FYI order placed. |
Spoke |
Mike&Shelley |
Newbie ![]() Group: Members Posts: 1 Joined: 10-May 19 From: 4722905066 Member No.: 23,110 Region Association: Upper MidWest ![]() |
Please count me in on the Euro w/blanking
I would like to have both front turn and rear turn and brake. Looking forward to receiving these for my build. Thank you. 72' 914 project. Mike& Shelley |
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,680 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Welcome to 914 world Mike!
(another Central Iowa region member!) |
anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,736 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
eric9144 |
Order for v8 boards placed also (IMG:style_emoticons/default/first.gif) |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,407 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Hi Jerry,
Would you happen to have a comparison picture between the two versions of the Euro fronts? I have a set of the older ones but may upgrade to V8 . |
Spoke |
Hi Jerry, Would you happen to have a comparison picture between the two versions of the Euro fronts? I have a set of the older ones but may upgrade to V8 . Eric, I'll take some better pictures this weekend. Here's what the difference will look like. The old boards had white lines and the new boards have a solid white appearance. The light output is about 50% more intensity. ![]() ![]() |
rgolia |
GeoJoe ![]() ![]() ![]() Group: Members Posts: 718 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States ![]() ![]() |
@spoke - those look good.....may need to upgrade from the early version I have.
drem914 |
Are those on a white or black board?
Luke M |
Hi Jerry, Would you happen to have a comparison picture between the two versions of the Euro fronts? I have a set of the older ones but may upgrade to V8 . Eric, I'll take some better pictures this weekend. Here's what the difference will look like. The old boards had white lines and the new boards have a solid white appearance. The light output is about 50% more intensity. ![]() ![]() Yup I want the V8 now. I'll pm you later. Thanks, |
Spoke |
Are those on a white or black board? @drem914 The new white/amber front turnsignals come in both white or black. Instead of making one PCB that can be white/amber or all amber I've made 2 separate boards that are white/amber and all amber. This makes both boards simpler to assemble and the white/amber have twice as many (42 vs 21) white LEDs. The new boards are the same price as the old boards. The old 21 white LED boards have been taken out of circulation although I built 2 sets of the 21 white LED boards. These two board sets are on the Discount Corner now. I've had a couple of folks who purchased the older boards with 21 white LEDs step up to the new 42 white LED boards. They should be able to sell their old boards for a good price. I will honor any warranty or damages to these boards to the new owners for their piece of mind. I've had so few boards come back for issues that I will repair/replace any boards that folks purchased for free regardless of when they were purchased. |
anderssj |
A small box arrived in the mail today (THANKS Jerry!) (IMG:style_emoticons/default/piratenanner.gif)
Version 8 of the front boards from Spokeworks.com. Installation is easy-peasy--to the point I thought pictures unnecessary. The most difficult part was getting my big mitt into the front housing to install the base. That said, here's a picture showing the new LED parking light (passenger side) compared to the old incandescent parking light (driver side): ![]() And yes, they're both "on." Best mod since I've done since installing Jerry's brake light boards! (IMG:style_emoticons/default/biggrin.gif) |
eric9144 |
@anderssj wow what a difference!
I live off a country highway so visibility of my 914 to other drivers is a big thing, got my little box too and updated my older version to the newer boards, check out the density of the white LEDs compared to the previous iteration, the pics do not do them justice: ![]() ![]() Bravo @Spoke another winning setup! The white 3D printed parts are also a good move, makes the board even more seamless under the lens (IMG:style_emoticons/default/beerchug.gif) |
drem914 |
My box showed up today also and will swap out the old for new on Friday. (IMG:style_emoticons/default/piratenanner.gif)
BENBRO02 |
Member ![]() ![]() Group: Members Posts: 485 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region ![]() ![]() |
I installed my Spokeworksled.com tail/brake lights tonight. Easy to install and much more visible. I felt like I was risking my life every time I drove in the rain before the upgrade. Great product!
Lo-Fi Version | Time is now: 20th April 2025 - 02:37 AM |
