Exhaust stud woes, What's the next step? |
Jan 31 2015, 07:11 PM
914-6 GT in waiting Group: Members Posts: 19,592 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
"New" exhaust nuts? Good luck finding those. I may have one or two used ones left; I keep finding them as we go through the stuff in the barn. They're Helicoiled on the inside, and should be fine for reuse. ALL the replacement nuts sold by almost everyone are of the locking variety, which were NEVER intended for use in this application. The Cap'n Cap'n - What's the proper nut to use and procedure for reinstallation? |
914Mike |
Jan 31 2015, 11:22 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I've used brass nuts, never had one get stuck or come loose. Some of the VW exhaust nuts used to have brass threads inside the steel nut, sort of a helicoil, or timesert nut, that's what gave me the idea.
My one remaining type 4 engine has the stock nuts in it with plenty of anti-seize applied during assembly. Wish me luck with the removal that's due because of a copper ring seal leak... |
Bartlett 914 |
Feb 1 2015, 12:21 PM
"New" exhaust nuts? Good luck finding those. I may have one or two used ones left; I keep finding them as we go through the stuff in the barn. They're Helicoiled on the inside, and should be fine for reuse. ALL the replacement nuts sold by almost everyone are of the locking variety, which were NEVER intended for use in this application. The Cap'n Would you mind showing a pic of the proper nuts? May these can be produced. What about SS nuts |
stugray |
Feb 1 2015, 01:49 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Would you mind showing a pic of the proper nuts? May these can be produced. What about SS nuts Last time I installed mine I used 8mm "Jis Nuts" from Ace Hardware. They have a smaller OD so that you can use a smaller socket. My aftermarket headers dont fit as nice as the stock, so I needed the extra room. Once I torqued them to spec, I double nutted them. Oh! ANd excellent job on drilling the stud out. You clearly DO have the patience and forethought to do it right. You should keep that drill guide kit handy and offer it to others as this happens to them. |
relentless |
Feb 1 2015, 01:57 PM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
Nice job! I picked up some 8mm copper exhaust flange nuts from Pelican last fall. They were originally for a BMW, but fit fine and were a lot cheaper (.75) than OEM Porsche. I was hooked up by Dave Darling (thanks Dave!):
P/N 18-30-7-620-549-M58 |
pilothyer |
Feb 1 2015, 02:26 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
These should work Helicoil Flange Nuts
ClayPerrine |
Feb 1 2015, 06:25 PM
Life's been good to me so far..... Group: Admin Posts: 15,901 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I use a Mercedes Benz exhaust manifold nut.
Mercedes part number 6159900050. They are pre-coated with anti-seize and use a 12mm shouldered construction similar to JIS nuts. Ever since I started using them, I have not had an issue with seizing to the exhaust studs. Mercedes Exhaust Nut |
ThePaintedMan |
Feb 2 2015, 08:00 AM
This is one of the most well-thought out and brightest ideas I've seen here for a long time. An example of what can be done with some ingenuity and plenty of forethought and patience. Congratulations on a great job!
Two things: 1) Can we make this a classic thread? 2) Hopefully no one else ever needs to go through the trouble that you did, but just in case, PLEASE hold onto that jig you made up! Someone else might be able to use it someday, or at least copy it for their own use. |
Oct 1 2015, 04:06 PM
Stomski makes a tool in a kit with all different adapters to remove broken studs
Attached thumbnail(s) |
Harpo |
Oct 1 2015, 06:15 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
This supplier is one of mine. I will inquire about some samples. |
wndsnd |
Oct 1 2015, 07:39 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I am impressed. It sucks working on your back with oil dripping in your eyes.
913B |
Oct 2 2015, 02:43 PM
Senior Member Group: Members Posts: 853 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Dang you the MAN, I like your persistence and not give up.
I am subscribing to this thread for future reference. BTW, how thick was that drill jig have to be ? Drill bits, was there special drill bits you use/recommend for this job ? I take it harbor freight ones would NOT do. Great job ! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) Ted |
saigon71 |
Oct 3 2015, 04:17 PM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Stomski makes a tool in a kit with all different adapters to remove broken studs The Stomski tool is the bomb. Will it work on 914 heads with oval exhaust port though? http://www.stomskiracing.com/products/exha...stud-repair-kit |
saigon71 |
Oct 3 2015, 04:22 PM
Dang you the MAN, I like your persistence and not give up. I am subscribing to this thread for future reference. BTW, how thick was that drill jig have to be ? Drill bits, was there special drill bits you use/recommend for this job ? I take it harbor freight ones would NOT do. Great job ! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) Ted Thanks Ted. Necessity is the mother of invention. (IMG:style_emoticons/default/dry.gif) My drill jigs are about 3/8" thick. I used a set of Dewalt pilot point drill bits (set was about $20), purchased at Lowes and plenty of lube. |
Oct 3 2015, 04:25 PM
I would think so since there are many different size bushings to space the tool. I just saw this for the first time the other day or I would have given you a heads up sooner. Get it, heads up (IMG:style_emoticons/default/lol-2.gif)
Stomski stopped by the shop the other day. Good guy and sure knows his stuff. |
ctc911ctc |
Apr 7 2020, 12:26 PM
Senior Member Group: Members Posts: 933 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I started replacing all of my studs with the engine in.
After reading this thread (and trying with no luck to remove one) I am going to use the existing studs and the new copper nuts I purchased. This is an engine out head off job. QUESTION: Exhaust leaks I took the exhaust apart because of leaks, here are two pictures of Cylinder 3 and Cylinder 4 exhaust ports Cylinder 3 And Cylinder 4 Seems that 3 is running a bit lean and that 4 is running a bit rich. Also, do the colors on the copper gaskets (new, ran them perhaps 2-3 hours) indicate that they are leaking? |
Bleyseng |
Apr 7 2020, 03:42 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I started replacing all of my studs with the engine in. After reading this thread (and trying with no luck to remove one) I am going to use the existing studs and the new copper nuts I purchased. This is an engine out head off job. QUESTION: Exhaust leaks I took the exhaust apart because of leaks, here are two pictures of Cylinder 3 and Cylinder 4 exhaust ports Cylinder 3 And Cylinder 4 Seems that 3 is running a bit lean and that 4 is running a bit rich. Also, do the colors on the copper gaskets (new, ran them perhaps 2-3 hours) indicate that they are leaking? Boy now there is a "shelter in place" project waiting to get done. That oil cooler looks plugged and so much dirt on the heads. Drop the engine and tranny and take it apart to clean up everything so it runs cooler as its a air cooled engine. |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:03 PM |
