dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Looking spectacular.
Keep up the great work. |
dlee6204 |
I tore into the long tonight. I first braced the door opening before making any cuts. In total I had to cut out about a 14 inch section of inner long.
![]() ![]() The rest of the upper long doesn't look bad from the inside. The whole long will be treated with Ospho and painted before closing it up. ![]() When cutting out the outer long I made sure to leave a section of "inner" material to tie into later for added strength. ![]() |
dlee6204 |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Way to go, Doug. You don't let anything slow you down! Keep on keeping on! (IMG:style_emoticons/default/beerchug.gif)
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Looks good Doug!
dlee6204 |
Been working on some small stuff.
First, got one side of the engine done with P/Cs and head. ![]() I also coated the inside of the upper long on passenger side. I first treated it with two coats of Ospho and then some internal frame coating. The outer section has already been fitted now I just need to weld it on. Pics to come. ![]() Finally I started prepping for the floorpan. Its currently held in with some self-tapping screws. There are a few areas around the lower firewall that I have to repair before I install the pan but its getting close! Those seat brackets will also be modified to fit the non-adjustable passenger seat. ![]() |
dlee6204 |
Got the upper part of the long installed and the jackpoint. I have a few welds to do in the "hell hole" and then I can install the battery support and tray. (IMG:style_emoticons/default/piratenanner.gif)
![]() ![]() No more hell hole ![]() |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
really nice work. (IMG:style_emoticons/default/beerchug.gif)
gives me a good idea of what I'm up against in the next few weeks/months |
Claus Graf |
Member ![]() ![]() Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None ![]() |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,542 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
dlee6204 |
I've been busy working on my other 914 but I did manage to get the other side of the motor together.
(IMG:style_emoticons/default/smile.gif) ![]() |
dlee6204 |
dlee6204 |
dlee6204 |
I just took advantage of the sale happening at Restoration Design and ordered the remaining sheet metal I will need to finish the car...
Rear trunk Rear trunk reinforcement Right inner rocker Right sill The end is near (IMG:style_emoticons/default/shades.gif) |
dlee6204 |
Got the interior floorpan complete with crossmember and seat mounts. (IMG:style_emoticons/default/smile.gif)
trojanhorsepower |
Way to go!
dlee6204 |
I started digging into the rear trunk area. I discovered the rear has been hit at some point. There was also some previous sketchy rust repair done to one corner. In the end I decided it was best to make some big changes.
Notice there is a scotch brite pad under the bondo. (IMG:style_emoticons/default/icon8.gif) ![]() Notice the bump ![]() (IMG:style_emoticons/default/w00t.gif) ![]() |
dlee6204 |
dlee6204 |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:12 AM |
