dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
dlee6204 |
I haven't made as much progress as I would like as of lately because I have been working on my side project... I have been building myself a media blast cabinet. Cabinet is made out of galvanized steel and is approximately '2x2'x4'. I have a few small items to complete on it before its ready for blasting but so far I am very pleased with how it turned out.
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Wow nice work on that blast cabinet
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,542 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Really enjoying your resto! I have to replace my rear panel so I'm following closely. Keep it going! (IMG:style_emoticons/default/popcorn[1].gif)
dlee6204 |
I reached a milestone tonight and finished all welding underneath the car! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/welder.gif) No more molten balls of lava falling on me while I work. I installed the rear jacking triangles and completed the last few areas of welding on the floorpan.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Well, now that your out from under it I should tell you HF has leather welders aprons for < $10. Great progress! (IMG:style_emoticons/default/beerchug.gif)
dlee6204 |
I had a very productive weekend. I set out to complete the very last structural repair and replace the passenger inner rocker.
After drilling spot welds, the rocker came off quite easily. There was no shortage of nuts and acorns that came out once off. Luckily the entire inner long was solid and I had to do no additional repairs. Just wire wheel, paint, and install the new one. ![]() ![]() This onion has many layers. ![]() ![]() |
dlee6204 |
dlee6204 |
This was the perfect opportunity to try out Eastwood's two part Epoxy in a can. I coated inside the long and the back side of a few parts that I still have to install. Overall its a pretty decent product. It sprayed well and it had more in the can than I thought. It was great for a smaller area. When I paint other areas of the car though, I will use regular spray gun epoxy.
dlee6204 |
Ready for install. ![]() (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) ![]() ![]() ![]() |
dlee6204 |
Sill plate welded on. (IMG:style_emoticons/default/welder.gif)
![]() Ground down all my welds up top. Also Removed my door opening brace. ![]() Removed brace and reinstalled door. Gaps are still perfect! Awesome! (IMG:style_emoticons/default/thumb3d.gif) ![]() Also installed the battery tray. I coated the backside with epoxy of both pieces before installing. ![]() |
dlee6204 |
JoeDees |
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None ![]() |
This build has become a freight train rolling unstopably along! I love it!
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Looks great Doug!
Glad your blaster is working. If you are able to get a new compressor I would recommend a two stage unit. Quincy has a nice unit. Kinda high, but will give you enough air to run your whole shop, forever. |
dlee6204 |
Got the rear trunk, reinforcement, and heat shield welded in. Hopefully the back will go on tomorrow. (IMG:style_emoticons/default/shades.gif)
dlee6204 |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Doug Dude.....you are a one man wrecking crew....in the best sense of that term.
Well done. Really making a lot of serious progress on your project. Keep up the great work and keep those pics coming.... |
dlee6204 |
dlee6204 |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,781 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Very enjoyable reading,great work appears you aren't dawned by a bit of rust,keep it up and good luck getting to paint stage.
Lo-Fi Version | Time is now: 3rd April 2025 - 01:12 AM |
