Washer nozzles won't come out..., How to remove black washer nozzles |
jack20 |
Feb 2 2015, 04:36 PM
Member Group: Members Posts: 413 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I am in the process stripping my 74 for paint. I can't seem to evenly compress the tabs under the cowl at the washer base to get them out. I've used a number of different pliers.
Any hints would be appreciated. Thanks, Jack |
jim_hoyland |
Feb 2 2015, 05:52 PM
Get that VIN ? Group: Members Posts: 9,564 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Be carefully: you may loosen the paint around the hole. Been there. If it's really tight try getting som PB Blaster under it and into the hole. The blaster sometimes take time to do it's magig, so let it sit overnight.
914Sixer |
Feb 2 2015, 05:53 PM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Take a pair of side cutters (diagonal pliers) and cut off the ears or the hole base. New squirters are only about $8.
lsintampa |
Feb 2 2015, 07:40 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
Take a pair of side cutters (diagonal pliers) and cut off the ears or the hole base. New squirters are only about $8. (IMG:style_emoticons/default/agree.gif) |
jack20 |
Feb 2 2015, 08:05 PM
Take a pair of side cutters (diagonal pliers) and cut off the ears or the hole base. New squirters are only about $8. (IMG:style_emoticons/default/agree.gif) Once again you guys have come through. Thanks very much! Jack |
Lo-Fi Version | Time is now: 2nd January 2025 - 07:13 PM |
