6 Pages V « < 2 3 4 5 6 >
> 914-Flat-8, Porsche 914 with a 908 3li engine
r_towle
post Feb 8 2005, 07:47 PM
Post #61
Custom Member
First off !!!!See it will fit!!!
Secondly, I think from what I can see the cam towers are driven from the middle of the engine by a gear, this gear seem to be attached to a maller drive shaft that is connected to the cams....
I could not find the 907 link....you linked to the 914gt page
Rich
michel richard
post Feb 8 2005, 07:55 PM
Post #62
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
See the gears in the middle of the bank
http://www.pbase.com/917carl/image/21933262
http://www.pbase.com/917carl/image/21933259
sixnotfour
post Feb 8 2005, 08:02 PM
Post #63
http://www.pbase.com/9146gt/factory_racing...parts_907engine
michel richard
post Feb 8 2005, 08:05 PM
Post #64
Do I see right, in the first pictures, at the beginning of this thread, the engine compartment seems to be alot longer i.e. the panel between the engine compartment and the rear trunk is behind the strut towers !
Michel
r_towle
post Feb 8 2005, 08:24 PM
Post #65
Custom Member
QUOTE (michel richard @ Feb 8 2005, 09:05 PM)
Michel
It still fits!!!
rick 918-S
post Feb 8 2005, 08:40 PM
Post #66
Hey nice rack! -Celette
Cool, If the rear trunk panel is moved back for the longer 8 cylinder motor, then the transaxle is also moved back! I think.. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Quilmes, You Rock! If I ever get to Florida I want you to photo me ride! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
swood
post Feb 8 2005, 10:27 PM
Post #67
Yeah Quilmes, you rock! You're a great addition to the group. You've been posting some great photos and great information.
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
michel richard
post Feb 9 2005, 07:18 AM
Post #68
Been thinking about this one a little more.
Does anybody know how wide the 8 cyl engine is ? with its double overhead cams and all.
It may be that with the double overhead cams it's a little wider than the regular 6 cyl, and that it may not fit between the ears of the inner rear suspension mounts, which means the engine may have to be inserted/extracted from above, which could explain the change in the configuration of the engine compartment / trunk area.
All speculation, of course, but I would be curious to know the width of the engine.
Michel
BigD9146gt
post Feb 9 2005, 11:11 AM
Post #69
OCD member
Region Association: Australia and New Zealand
Guys, thanks for the input... but please take a closer look at the 908 engine....
The cam gears on the 917 engine are in the middle, that is obvious. But what is also obvious is the gap allowing those gears to be between the cylinders and the cam covers also reviel a raised section for gears.
Now look at the 907 engine, no gap is obvious... the intake stacks are evenly spaced, and very close to eachother. Nothing at the ends of the motor either except what looks like oil lines.
It isn't chain driven because the top cam covers and the bottom cam covers don't have a bridge covering between the two.
Michel, i don't think the 908 engine is all that much wider than the 911 engine. Even if it was, the 911 engine still has about an inch on either side in the 914 engine bay. I too would like to know the dimensions of those engines.
Quilmes
post Feb 9 2005, 11:39 AM
Post #70
Torino 380 W
QUOTE (michel richard @ Feb 8 2005, 06:05 PM)
Michel
Here are some technical drawings of the 914-8 from Porsche. I got these from the Grosse VW-Porsche Buch from Michael von Klodt. Great book !!!
( I can hear the phone ringing from Germany Wavt in die Hell are you duuing chairing my drawings wit die 914club) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I looked over the drawing and the dimension of the wheel base from the 914 and 914-8 are the same 2450.5mm, the trans does sit back more and the half shafts operate at a angle like the V8 conversions.
I guess one of us will just have to go out there and do a super underneath photo shoot of the engine and from all angles. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
Porsche 914-103 the rear trunk and engine cover seem to be one, I do not know if this was change later on for the 914-8???
Also some wood and clay pre-914 models included.
Quilmes
post Feb 9 2005, 11:41 AM
Post #71
Torino 380 W
Tech drawing 914-8 side view:
notice on the top view from the before picture, the gear shaft placed infront of the pass seat.
Quilmes
post Feb 9 2005, 11:42 AM
Post #72
Torino 380 W
One piece engine and trunk.
Quilmes
post Feb 9 2005, 11:43 AM
Post #73
Torino 380 W
914 Clay model pre model
Quilmes
post Feb 9 2005, 11:44 AM
Post #74
Torino 380 W
Dual headlight drawings
sixnotfour
Post #75
Could you convince him to do an English version of this Book. That would be awesome. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Quilmes
post Feb 9 2005, 11:45 AM
Post #76
Torino 380 W
Actual dual headlights
Quilmes
post Feb 9 2005, 11:47 AM
Post #77
Torino 380 W
914 with dual light set up current and dual lights set up.
Quilmes
post Feb 9 2005, 11:49 AM
Post #78
Torino 380 W
Wood 914 work,
Quilmes
post Feb 9 2005, 11:52 AM
Post #79
Torino 380 W
Wood 914 work 2.
I do not know if these photos have been posted up on this site before, If so I apologize if not I hope that you enjoy them. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Quilmes
Reiche
post Feb 9 2005, 11:54 AM
Post #80
QUOTE (BigD9146gt @ Feb 9 2005, 09:11 AM)
So is it run with a bevel gear system like the older 4-cams?
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 08:53 PM
