More shift linkage R&D at Tangerine Racing, Precision adjusters for all! Tailshift 4 & 6 prototypes shown |
ChrisFoley |
Mar 10 2015, 09:18 AM
I am Tangerine Racing Group: Members Posts: 7,976 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm expanding the application of my newest design to include all tailshift and 915 transmissions.
A precision adjuster will be available soon for these 914 applications: 914-4 tailshift 914-6 tailshift WEVO 915 Vellios 915 916 trans. This is what the adjuster unit for a 915 setup looks like. The rear connection will need to be different for 901 tailshift applications. |
luskesq |
Mar 10 2015, 09:41 AM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Chris,
Look forward to seeing your new application for stock tailshifter. Please advise when it is ready. Very happy with your ss fuel line kit and other goodies I got from you. Keith Keith |
ChrisFoley |
Mar 25 2015, 10:48 AM
ChrisFoley |
Mar 26 2015, 09:11 AM
914-6 Prototype
Steve |
Mar 26 2015, 05:32 PM
914 Guru Group: Members Posts: 5,797 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
How about one for the Martin Bott 916 trans? I am using a PMS shifter rod and firewall bearing and still need the piece from the firewall to the trans.
Alphaogre |
Mar 27 2015, 12:01 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Nice! The sooner the better! (IMG:style_emoticons/default/driving.gif)
ChrisFoley |
Mar 27 2015, 06:25 AM
How about one for the Martin Bott 916 trans? I am using a PMS shifter rod and firewall bearing and still need the piece from the firewall to the trans. The first one shown is for all 915 versions. I can make the rod diameter for a standard bushing or a PMS firewall bearing. The PMS shifter rod has a major shortcoming - the front cone screw hole is a straight bore, not a tapered bore. That rod would need modification to be used with the precision adjuster anyway so... My recommended setup uses either a sideshift rod turned around or a tailshift rod shortened a couple inches. I can make the rod under the engine, but I would need a measurement to determine the correct length. |
ChrisFoley |
Mar 27 2015, 06:29 AM
duplicate post
euro911 |
Mar 30 2015, 11:40 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Chris, Look forward to seeing your new application for stock tailshifter. Please advise when it is ready ... Keith (IMG:style_emoticons/default/agree.gif) |
ChrisFoley |
Mar 30 2015, 12:52 PM
The arm is removable since the part will have to be installed from the front side.
euro911 |
Mar 30 2015, 01:20 PM
The arm is removable since the part will have to be installed from the front side. Chris, let me see if I have this right - this part installs at the front of the forward shift rod (in the tunnel), at the shift lever?Is there any cutting/welding required, or is it plug-n-play? |
ChrisFoley |
Mar 30 2015, 02:33 PM
Chris, let me see if I have this right - this part installs at the front of the forward shift rod (in the tunnel), at the shift lever? Is there any cutting/welding required, or is it plug-n-play? No. It replaces the short rod at the back of the tunnel that goes thru the firewall. It is plug & play. |
euro911 |
Mar 30 2015, 05:42 PM
No. It replaces the short rod at the back of the tunnel that goes thru the firewall. It is plug & play. … (IMG:style_emoticons/default/smile.gif) |
db9146 |
Apr 30 2015, 11:58 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
When is this going to be available for a 914-6/901?
ChrisFoley |
Apr 30 2015, 12:15 PM
Steve |
May 31 2015, 04:30 PM
I'm expanding the application of my newest design to include all tailshift and 915 transmissions. A precision adjuster will be available soon for these 914 applications: 914-4 tailshift 914-6 tailshift WEVO 915 Vellios 915 916 trans. This is what the adjuster unit for a 915 setup looks like. The rear connection will need to be different for 901 tailshift applications. This is a picture of the 915 CFR adjuster installed in my car. Shifter is in neutral. I am using an early stock 914 shift rod and a Rennshift. I am using this setup with my Martin Bott 916 kit. Makes adjustments night and day easier, versus the trial and error method under the car. |
euro911 |
May 31 2015, 09:06 PM
How's the -4 tail shifter model working out, Chris?
Lo-Fi Version | Time is now: 5th February 2025 - 08:04 AM |
