Socalandy |
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California ![]() ![]() |
After Amilia it was off to Chattanooga to pick up Kents -6
pictures of the engine showed what we thought was 5400 on the engine but once I got in close read 5409 with my phone ringing... it was Porsche calling to confirm/deny if 5400 was a match so it was perfect timing and got the confirmation it's a match For 5409 (IMG:style_emoticons/default/aktion035.gif) Loaded it up and hit the road Attached image(s) ![]() |
banananose914 |
Member ![]() ![]() Group: Members Posts: 235 Joined: 20-November 13 From: california Member No.: 16,681 Region Association: None ![]() ![]() |
Hurry home so I can see that Bitch. No, not you Andy.
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 962 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
Here is my 6 (1937) going to the same shop that just painted the AA 916.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
BK911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None ![]() |
Why can't I find a six like this.... I want a project 6 if anyone knows of one... I have a project six. Not a 914 but a '71 911E. Plenty of TN rust too! Matching numbers per COA Have most/all the missing parts. Not really for sale, but I would entertain unreasonable offers. (IMG:style_emoticons/default/biggrin.gif) ![]() |
Socalandy |
Anyone know what this is??? Looks like a vacuum device, thks Two more questions in that picture. Why is there an ignition condenser attached to the fan shroud ? Does the engine turn ? Don't know and we will see if we can turn the motor in a few hours when we get to the shop. Here's a shot from Flagstaff. Almost done with the cross country round trip Attached image(s) ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,517 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Well done. Bet your glad to be back.
Socalandy |
Finally home and got the car unloaded and inside. The -6 was parked after a carb fire since they were not rebuild-able so it was a running driving car at that point. Engine does turn over but we lost the suspension console on the Pass. side along the way but Kent has replaced one before on my project.
More pictures later today... |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Engine does turn over but we lost the suspension console on the Pass. side along the way. Wow ... you didn't turn around and retrieve it? It's a REAL SIX console and probably worth at least $20K. Replacement means it won't be a real six anymore. "Red is gray and yellow white But we decide which is right and which is an Illusion" |
tnchris |
Newbie ![]() Group: Members Posts: 9 Joined: 25-July 07 From: Chattanooga,TN Member No.: 7,946 ![]() |
Finally home and got the car unloaded and inside. The -6 was parked after a carb fire since they were not rebuild-able so it was a running driving car at that point. Engine does turn over but we lost the suspension console on the Pass. side along the way but Kent has replaced one before on my project. More pictures later today... This is Drew, the seller of the car (this is my brother's account). Glad to see you guys made it across the country alright. I'm ready to see this thing torn down and built back up. |
SLITS |
Engine does turn over but we lost the suspension console on the Pass. side along the way. Wow ... you didn't turn around and retrieve it? It's a REAL SIX console and probably worth at least $20K. Replacement means it won't be a real six anymore. "Red is gray and yellow white But we decide which is right and which is an Illusion" Put the joint down, turn off the Moody Blues ........................ |
KELTY360 |
Engine does turn over but we lost the suspension console on the Pass. side along the way. Wow ... you didn't turn around and retrieve it? It's a REAL SIX console and probably worth at least $20K. Replacement means it won't be a real six anymore. "Red is gray and yellow white But we decide which is right and which is an Illusion" Put the joint down, turn off the Moody Blues ........................ Harshin' my buzz dude... (IMG:style_emoticons/default/smoke.gif) |
SLITS |
Engine does turn over but we lost the suspension console on the Pass. side along the way. Wow ... you didn't turn around and retrieve it? It's a REAL SIX console and probably worth at least $20K. Replacement means it won't be a real six anymore. "Red is gray and yellow white But we decide which is right and which is an Illusion" Put the joint down, turn off the Moody Blues ........................ Harshin' my buzz dude... (IMG:style_emoticons/default/smoke.gif) I just don't understand how you keep them lit in the Soggy PNW. Oh yea... uh ... water vapor won't hurt you (IMG:style_emoticons/default/smoke.gif) |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
Engine does turn over but we lost the suspension console on the Pass. side along the way. Wow ... you didn't turn around and retrieve it? It's a REAL SIX console and probably worth at least $20K. Replacement means it won't be a real six anymore. .....oooooh...uuugh,What I was thinking?? (IMG:style_emoticons/default/idea.gif) (any way to go back?) |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
glad you made it back o.k. I assume you were singing one liners alone ? (IMG:style_emoticons/default/confused24.gif)
914350 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 548 Joined: 21-April 14 From: Torrance Ca. Member No.: 17,275 Region Association: Southern California ![]() |
Finally home and got the car unloaded and inside. The -6 was parked after a carb fire since they were not rebuild-able so it was a running driving car at that point. Engine does turn over but we lost the suspension console on the Pass. side along the way but Kent has replaced one before on my project. More pictures later today... This is Drew, the seller of the car (this is my brother's account). Glad to see you guys made it across the country alright. I'm ready to see this thing torn down and built back up. Hey Drew, thanks for making everything go so smooth in this long distance transaction and all your help and extras. Quite an adventure. I can't wait to get started on this one but first I will be focused on Jim's 6. I finally own a 6 and I plan on restoring it dead stock. It's rusty yes but cool to see all the rare and original 6 parts that are there. I just picked up some rear calipers for it and there in good hands with Eric at PMB. I plan on rounding up parts for now and hopefully start on it by the end of the year. |
KELTY360 |
Engine does turn over but we lost the suspension console on the Pass. side along the way. Wow ... you didn't turn around and retrieve it? It's a REAL SIX console and probably worth at least $20K. Replacement means it won't be a real six anymore. "Red is gray and yellow white But we decide which is right and which is an Illusion" Put the joint down, turn off the Moody Blues ........................ Harshin' my buzz dude... (IMG:style_emoticons/default/smoke.gif) I just don't understand how you keep them lit in the Soggy PNW. Oh yea... uh ... water vapor won't hurt you (IMG:style_emoticons/default/smoke.gif) ![]() |
Socalandy |
glad you made it back o.k. I assume you were singing one liners alone ? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/av-943.gif) Singing maybe... One liners... NO You had to be there to understand guy's. Scotty may be able to describe it best!!! 5,727miles round trip (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/chowtime.gif) (IMG:style_emoticons/default/yellowsleep[1].gif) and what a blast Attached image(s) ![]() ![]() ![]() ![]() |
914350 |
Andy! Thanks for everything! I don't know if I'm as cool as you. I don't know if I would be as easy going and lend myself and vehical to help tow a car back for someone else. You could have easily just headed home and skipped the extra work. Thanks!
Andy called me and said that he could grab the 6 I bought on the way back from his trip to Amelia Island so the next day I called him and said I would fly out and meet him in Tennessee. Everything went perfectly. I flew out Sunday night and was in Chattanooga TN. about 30 minutes before Andy. He picked me up at the airport and we headed to a Uhaul about 20 minutes away, where I had reserved a trailer. after we got the trailer, Drew's place was about a 20 minute drive from there. We loaded the car and parts and headed to a hotel for the night. We woke up at 6 the next morning and hit the road. We were home by Thursday night. Couldn't have gone any better. Thanks again Andy, your too fricken cool. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,853 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Wow! That was a serious rated trip. Glad you and the car made it home safely. Let the fun begin. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 12:42 AM |
