Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Mine are still in, but will be going soon.
I like to live dangerously. |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
I replaced all of mine with Tangerine Racing SS lines. The only ones that were still good were the black ones from 75, seems as though that is the year the lines were subject to operating pressure from the front mounted pump and going through the tunnel and Porsche decided to upgrade the lines..... All the others were gravity fed through the tunnel.............but why take the chance..........all the early lines were as brittle as glass, so it's a no brainer.
hcdmueller |
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England ![]() ![]() |
My 76 still had the original lines when I bought it. They seemed like they were the same plastic CIS injection lines were made from. They were in outstanding condition and still as flexible as can be expected from thick plastic. I had already bought stainless lines, so they were replaced.
7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
One line now. Bye bye brittle tubes and gas smell.
jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
I upgraded to the SS lines, but I gotta say, the OEM plastic lines were NOT brittle. In fact, they were tough as hell. I was probably fine with them, seeing that I run carbs, with the pump in the engine compartment, and so was not putting much pressure on them. That said, I love the SS lines, and it was actually pretty easy to install them.
jeffdon |
Cuda911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California ![]() |
I have the original lines in my '73 and '74. I know I should go stainless, but just haven't gotten around to it yet. Let me know how the upgrade works out, Lawrence. Not sure what all is involved to change them out.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Replaced mine on the 75 FI. Purchased it from member here and got few rubber lines from Napa. Buying another set for the 71.
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
When I had my rebuild done a couple years ago TranslogGT replace the Fuel line with Stainless. It's a Carb car so we replaced only the Fuel line with Stainless and left the Plastic return line in the tunnel disconnected. Return lines are not needed on Carb cars. Also the flexible lines in the engine compartment were replaced with new Ethanol (Alcohol) Proof Lines. The old plastic lines between age and the effects on Ethanol Fuel will crack.
patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
I replaced my original lines last year and was really surprised how durable and solid they were. Saw nothing that showed degradation. But no doubt it should still be something that is done to all cars.
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I have the original style lines in my car. Not sure if they are the same pieces of plastic that were in the car when it left the factory, but they are certainly the same kind of line.
I did replace the two lines that go up through the engine shelf with SS a couple of years back. Those plastic lines had gotten brittle. The center tunnel lines have not yet.... They probably will at some point, though. Then it's stainless time. --DD |
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
The lines in my '75 broke into 3 pieces each when I pulled them out. I replaced them with Rotary'14 kit, which I am extremely happy with. His thread even has a video showing just how easy it is to do the swap with the engine in the car.
http://www.914world.com/bbs2/index.php?showtopic=110158 |
1TRICK6 |
Newbie ![]() Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California ![]() |
Bought mine from forum member, Robert, (Rotary'14) also. Need another set for my other car soon, next time I see him.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
My 76 still had the original lines when I bought it. They seemed like they were the same plastic CIS injection lines were made from. They were in outstanding condition and still as flexible as can be expected from thick plastic. I had already bought stainless lines, so they were replaced. Same here. |
flylarry |
Newbie ![]() Group: Members Posts: 38 Joined: 22-November 05 From: Carlsbad, CA Member No.: 5,170 ![]() |
I still have mine, you want-em? Free!
Big Len |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region ![]() |
I'm afraid changing the fuel lines to s/s will hurt the originality.
oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
I still have the original hard lines in the tunnel. While I'm not overly concerned about them I will get to replacing them one day. All of the rubber/cloth lines get replaced every few years. I've never heard about a fire starting from a leak in the center tunnel. Seems like they are all from the soft lines in the engine bay. As a newly elected Councilman in a small rural central California city, I was asked by to bring my '76 teener to drive in the annual city Christmas parade through town. I pulled into the parade line and began slowly idling down the main street route with another Councilman in the passenger seat. We hadn't gone far when a man on the sidewalk approached the side of our little yellow ride and told us we were "leaking water under the car real bad". That's an interesting comment since there is no water onboard a 914 to leak! I opened my door and leaned out to look under the car, only to see gasoline spraying down mid tunnel and rapidly pooling under the car! I quickly told my Council colleague to get out of the car fast! Then I franticly waved to onlookers to create an opening among the sidewalk crowd of people, and slowly drove the still running 914 to a dirt field and finally shut it off. I had left a trail of gasoline on the ground behind the car that was at least a foot wide as I idled towards that open field! After having my 914 towed to my mechanic, as you probably already guessed, the fuel line, under high pressure from tank in front to the engine in the rear, decided to split after 30 years, at that inopportune moment during the parade. I had the fuel line repaired, my car was returned to me and all was fine. I was invited to the city Christmas parade again the following year. When I pulled up in my teener to get in the parade line this time, my Council colleagues were standing nearby on the curb with lighters, flicking them repeatedly and saying they were "ready for me this year!" That's how you know who your friends are in politics!!!! After reading all the posts about fuel line fires and my parade experience, I think I will make an appointment with my mechanic to replace all the rest of the fuel lines now. If I was smarter, I would have done them all then. Thanks to my fellow teeners here for the additional motivation to finally get them all done now! Attached thumbnail(s) ![]() ![]() |
oakdalecurtis |
When I get the rest of the lines replaced, besides the fuel filter, anything else I should replace?
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
yup
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
Got rid of mine last year. No need to loose sleep wondering when they are going to start leaking !
Lo-Fi Version | Time is now: 26th June 2024 - 12:53 AM |
