Kennedy adapter plate & flywheel question |
got914? |
Mar 30 2015, 05:08 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Does the KEP flywheel bolt directly to the crankshaft or does the old ring gear go in between like a spacer ?
bulitt |
Mar 30 2015, 05:30 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
got914? |
Mar 30 2015, 05:38 PM
I was just wondering because obviously the KEP setup is much smaller than a stock ring gear which means the starter needs to be moved. On a SBC it wouldn't be a big deal but on a northstar where the starter is under the intake im not sure how you would start that. HMMM maybe an email to KEP is in order.
PS. I haven't ordered my adapter yet was just brainstorming. PPS. NICE BLING ! EDIT ; OK guess i wasnt very clear. With a 915 obviously you wouldnt have much issue. IM more referring to with a 6 speed boxster s which has an engine mounted starter. |
Mar 30 2015, 06:08 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Flywheel to crank, ring-gear to flywheel ...
(IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1182813958.jpg) |
Mueller |
Mar 30 2015, 09:01 PM
I was just wondering because obviously the KEP setup is much smaller than a stock ring gear which means the starter needs to be moved. On a SBC it wouldn't be a big deal but on a northstar where the starter is under the intake im not sure how you would start that. HMMM maybe an email to KEP is in order. PS. I haven't ordered my adapter yet was just brainstorming. PPS. NICE BLING ! EDIT ; OK guess i wasnt very clear. With a 915 obviously you wouldnt have much issue. IM more referring to with a 6 speed boxster s which has an engine mounted starter. I don't see a listing on KEP for a Boxster transmission. For the Northstar motor the starter is mounted to the stock location for the 901/914 transmission. |
Mar 30 2015, 11:02 PM
I don't see a listing on KEP for a Boxster transmission. Most of their stuff is not listed on the website. You need to call or email them. I got a "custom" Stage 3 pressure plate and clutch from them for my 3.6L. All i had to do was ask ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:21 AM |
