Ansbacher |
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 ![]() |
Now that I am experiencing my first summer here in Florida with my 914 ('74 2.0L Dual Dellorto Carbs), I am running into episodes of vapor lock on hot days (like most days here). I have been reading that even carbureted 914s can benefit from a return fuel line that goes back to the tank, as it keeps the fuel cooler as it recirculates. My question is how to I plumb and route a return line. The old FI return line is present and capped off at the firewall. So, If I add line to that existing line and bring it up into the engine compartment, where do I tap into the existing fuel system? What I have now is: main feed line- a brass "T"- line to the right carb- line to the left carb (with pressure gauge). I am not running a fuel pressure regulator as my pressure never seems to exceed 3PSI anyway. Can a low pressure system use that old FI return that terminates at the BOTTOM of the fuel tank or does it have to enter the tank ABOVE the max fuel level?
Hoping for some answers as it is only getting hotter here by the day. Thanks all. Ansbacher |
Lo-Fi Version | Time is now: 26th June 2024 - 05:55 AM |
