2.0 Oil Leak - Taco Plate area - Advice Please |
mikedsilva |
Apr 27 2015, 01:40 PM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
Being new to these cars, (about 2 months in now) I am slowly getting to know them and work my way through the issues.
One of them, is that there is a pool of oil after the car is left sitting. Mostly, it only leaks after a drive.. when the oil is hot. I pinpointed the leak to the taco plate area.. I don't have a oil temp sender so I am not sure what is under the plate... But there is some sealant around the plate area. The sealant feels very stiff.. almost like JB Weld but I don't think it since it flexes a bit when I press on it.. I found that the leak was a pinhole in the sealant.. Should I be trying to remove all the sealant to see what is under there? Or should I just put a "patch" over it and keep an eye on it? https://www.youtube.com/watch?v=8kOhdj88D_E |
Spoke |
Apr 27 2015, 01:52 PM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
There is a gasket there plus a couple of aluminum seal rings around the bolts.
Best bet is to buy a new gasket and rings and replace them when you change oil. You will want to check the fitment of the plate and the opening to make sure everything is lined up. |
stugray |
Apr 27 2015, 01:54 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
How close are you to your next oil change?
You will need to drain all the oil to try to fix that area. My experience is that you can never "fix" a leak in Silicone by applying new silicone over it. |
saigon71 |
Apr 27 2015, 02:12 PM
Advanced Member Group: Members Posts: 2,007 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
How close are you to your next oil change? You will need to drain all the oil to try to fix that area. My experience is that you can never "fix" a leak in Silicone by applying new silicone over it. (IMG:style_emoticons/default/agree.gif) Order all new seals & gaskets or the taco plate area. Clean everything up and re-seal it at your next oil change. This area is a PITA to seal up. I've tried twice now and still have a small drip. I'm driving it as is until the next oil change. |
type47 |
Apr 27 2015, 02:35 PM
And watch the torque on the mounting bolts, you don't want the problems from stripping the threads in the aluminum case. Torque is probably in the 7-9 ft lb range but check factory value to be sure.
Apr 27 2015, 07:46 PM
914 Idiot Group: Members Posts: 15,075 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A big O-ring, plus a paper gasket, plus two sealing washers are needed. Plus cleaning out all of the old crap.
Another thing to check, though, is the pulley for the thermostat flaps. It threads into the case on the left side, and the hole is actually a through-hole. If the pulley and bolt are removed, it will leak out when you drive the car around corners. --DD |
mikedsilva |
Apr 27 2015, 08:03 PM
A big O-ring, plus a paper gasket, plus two sealing washers are needed. Plus cleaning out all of the old crap. Another thing to check, though, is the pulley for the thermostat flaps. It threads into the case on the left side, and the hole is actually a through-hole. If the pulley and bolt are removed, it will leak out when you drive the car around corners. --DD Thanks for the reply Dave.. I have ordered the bits from my local porsche shop but they will take 10 days to come from Germany... so will update at that time. I'm just hoping that under all the sealant, there isn't a cracked case flange or something waiting for me... |
Old Yella |
Apr 27 2015, 09:33 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Think you may be rooted mate.
The case is aluminium and can be welded but you would probably need to remove the engine drain it clean it, flip it and grind all the JB pox out. Then get a good welder to build up the damaged metal and use a dremil to re make the proper profile. broken front engine mounts probably allowed the block to regularly bounce off the engine mounting bar. that's my theory. Cheers |
mikedsilva |
Apr 28 2015, 03:16 AM
I think you may be right.. but will dig it all out and have a look at some point...
mikedsilva |
Jul 1 2015, 04:48 AM
update...
i drained the oil, and removed the sealant.... The flange has been broken off, but the base where the o ring seats is fully in tact. I'm thinking about 2 options.. clean it up and build up with JB Weld.. Or... get an aluminium billet plate which will seat with the flange much better and use sealant. Thoughts?? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747796.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747796.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747797.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747797.4.jpg) |
SLITS |
Jul 1 2015, 06:09 AM
Instead of bolts, I put studs in to avoid the possibility of breaking the case or stripping the threads. Allows for better clamping capability.
Also, lay the sensor plate on a flat plate to make sure it is not warped. |
02loftsmoor |
Jul 2 2015, 12:55 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
update... i drained the oil, and removed the sealant.... The flange has been broken off, but the base where the o ring seats is fully in tact. I'm thinking about 2 options.. clean it up and build up with JB Weld.. Or... get an aluminium billet plate which will seat with the flange much better and use sealant. Thoughts?? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747796.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747796.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747797.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1435747797.4.jpg) WOW they did you no favors there!! |
914Sixer |
Jul 2 2015, 03:12 PM
914 Guru Group: Members Posts: 9,043 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I found that that had an even bigger piece missing out of my case. I just got another case and I a going to do a quick rebuild.
Lo-Fi Version | Time is now: 15th January 2025 - 01:21 AM |
