naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
Let me see if I can get my hands on a boxster tranny and get that settled because I am tired of waiting for someone to do it for us. (IMG:style_emoticons/default/smile.gif) rich Someone has...and it cost a fortune. That's why I decided not to do it. The guys at Powertech did it for a customer a few years back. I have a copy of the receipt/work order and I talked to Keith over there. He said it was much harder than even they thought....when you see a line item that says "Discount.....$15,100" you can only imagine what the total bill was.... (IMG:style_emoticons/default/barf.gif) |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
I've wondered for a long time how one could possibly make a driveshaft go through the engine like Audi but never come up with a good economical solution (IMG:style_emoticons/default/smile.gif) |
Andyrew |
Because I am cheap. I don't think there will be a cheap way to do this. If we can't figure out a simple/cheap way to mate a manual Boxster trans to an air cooled engine, I can't even imagine how much more complicated this would be. The PDK type trans is fully integrated with the engine management system, which is fully integrated with the engine (obviously). They work as a unit, not individually, so I'm not even sure it would be possible without doing both. Honestly, the cheapest option would be to buy a very cheap Boxster Tiptronic (which can be had for under $10k) and use all of engine/trans/wiring/ECU for it. A few things.... I am looking for a rear engine solution, but if a boxster tranny is available for a setup, I will design and figure out what needs to be done to bolt it to our motor. Its a bell housing that needs to be swapped over and a clutch/pressure plate we need to use that works with the motor.... For the PDK, yes, its integrated with the car, but it has its own computer and its reading throttle body, speed, and a few other sensors that could all be setup using a different interface. Again, I am NOT looking for the porsche PDK tranny...I am looking for something cheaper like a subaru/toyota/whatever to be able to create a solution that will actually work.... I know I could buy a PDK and at that point it makes sense to buy a late model 911 and call it a day... That defeats the purpose. Let me see if I can get my hands on a boxster tranny and get that settled because I am tired of waiting for someone to do it for us. (IMG:style_emoticons/default/smile.gif) rich Rear engine solution? Grab a FWD setup and flip the diff... A3's used a DSG IIRC. |
Andyrew |
Why dual clutch? Paddle shifters are becoming a standard on FWD sports sedans and some RWD. From Hyundai RWD used on 3.8 and 5.0L motors: "TRANSMISSIONS The automatic transmissions for both engines have 8-speeds, with an enhanced paddle-shifter design for the SHIFTRONIC® manual-shifting capability. In addition, the 8-speed automatic now precisely rev-matches engine RPM to the exact selected-gear speed, for smooth downshifts into corners and superb dynamic balance. Both engines are mated to standard six-speed manual transmissions that feature new carbon synchronizer rings for smoother shift action and enhanced synchronizer durability. Each transmission has been specifically tuned to match its engine’s unique power and torque curve characteristics. In addition to the steering wheel-mounted paddle shifters, each automatic offers shift capability via the shift lever according to individual driver preference. A clear LCD readout on the instrument panel shows the selected gear at all times for the driver." Looks like paddle shift options are growing yearly. My wife's Genesis coupe is a 2.0T 8 speed auto with this paddle shifter. Nothing close to a DSG in terms of shifting speed, and its got horrible tech (Wont hold a gear, cant tune it or make it shift harder). But its a wonderful trani that can hold a LOT of power.. But its a RWD trani, Nothing that can be used in a mid or rear application. |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Because I am cheap. I don't think there will be a cheap way to do this. If we can't figure out a simple/cheap way to mate a manual Boxster trans to an air cooled engine, I can't even imagine how much more complicated this would be. The PDK type trans is fully integrated with the engine management system, which is fully integrated with the engine (obviously). They work as a unit, not individually, so I'm not even sure it would be possible without doing both. Honestly, the cheapest option would be to buy a very cheap Boxster Tiptronic (which can be had for under $10k) and use all of engine/trans/wiring/ECU for it. A few things.... I am looking for a rear engine solution, but if a boxster tranny is available for a setup, I will design and figure out what needs to be done to bolt it to our motor. Its a bell housing that needs to be swapped over and a clutch/pressure plate we need to use that works with the motor.... For the PDK, yes, its integrated with the car, but it has its own computer and its reading throttle body, speed, and a few other sensors that could all be setup using a different interface. Again, I am NOT looking for the porsche PDK tranny...I am looking for something cheaper like a subaru/toyota/whatever to be able to create a solution that will actually work.... I know I could buy a PDK and at that point it makes sense to buy a late model 911 and call it a day... That defeats the purpose. Let me see if I can get my hands on a boxster tranny and get that settled because I am tired of waiting for someone to do it for us. (IMG:style_emoticons/default/smile.gif) rich Rear engine solution? Grab a FWD setup and flip the diff... A3's used a DSG IIRC. That's the same one the GTI has. That thing is AMAZING. 6 speed. The A4 has a similar 7 speed. I'd totally re-swap my setup for that gearbox, that's how good it is. The engine's not bad either... (IMG:style_emoticons/default/biggrin.gif) . Sounds like it might be above my technical skill level... |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
034 Motorsport told me they could build a DSG that would fit in my 914. I'm not sure of the cost but I bet it would be North of $5k.
Andyrew |
A DSG would be great for a big turbo application, but I have heard issues with the trans holding high HP levels..
I think the electronics there are above my mental capacity.... |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I wonder how the PDK or others like it modulate taking off from a stop ? Surely some kind of PWM electronic setup. Just saying unless I just don't have the PDK operation
understood. With my car an auto with 5 or 6 gears would free me up to drive the car. Things happen fast and these days I'm a bit slower (IMG:style_emoticons/default/blink.gif) People always talk about the HP/torque eating up the transmissions (auto) but in newer 911 models pack plenty of power and seem to do well. |
Mike Bellis |
I wonder how the PDK or others like it modulate taking off from a stop ? Surely some kind of PWM electronic setup. Just saying unless I just don't have the PDK operation understood. With my car an auto with 5 or 6 gears would free me up to drive the car. Things happen fast and these days I'm a bit slower (IMG:style_emoticons/default/blink.gif) People always talk about the HP/torque eating up the transmissions (auto) but in newer 911 models pack plenty of power and seem to do well. I drove a 2015 Cayman S with a PDK it was FUCHING awesome! (IMG:style_emoticons/default/driving.gif) Put it in Auto and it shifts for you. It hung on to the shift points a little and was quite sporty. Throw it in manual and you paddle through the gears. Gear to gear shift is very quick. when you come to a stop, it shifts into first automatically similar to any other manual shifting automatic. I don't really understand you modulate question. What ever the PDK does is seamless. I would absolutely buy one if given the chance. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Let me see if I can get my hands on a boxster tranny and get that settled because I am tired of waiting for someone to do it for us. (IMG:style_emoticons/default/smile.gif) rich I found the Boxster drawing, ....edit...found some 3D models of some Porsche air-cooled transmissions. 3D model of a G50 Is is safe to say that a G50 would bolt up to a Type IV? Boxster dims below ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 09:14 PM |
