Gustl |
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,536 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria ![]() ![]() |
(IMG:style_emoticons/default/confused24.gif) please forgive my naïveté, but what exactly are you meaning here with "sporto" Wolfgang? Is that a car? A type or brand of seat? ...and actuating the clutch when your leg touches the shifter...?? I'm missing your meaning on this altogether and am curious. Sporto is short for Sportomatic that's an optional transmission type that sold very very rarely with the 914-6 only 16 cars are documented by the factory it's a manual 4-speed transmission with torque converter and a manually actuated clutch - without clutch pedal when you touch the shift stick, it opens the clutch and you could change the gear manually if you're more interested in the Sportomatic, check out this page (German): http://sportomatic.net/sportomatic/sportomatic.php At any rate, can you estimate how much space is gained by using this hub? 1cm? 2cm? 3cm?? I use the hub from "Mittelmotor" - it's 30 mm |
Lo-Fi Version | Time is now: 24th June 2024 - 06:31 AM |
