LukeD |
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None ![]() |
Should have the engine compartment cleaned out today to inspect the area more thoroughly. But I did get the rocker panels off, had to drill out the rivets and muscle the lower screws that were a bit rusty. Both sides were full of dirt but cleaned up nicely. Hoping the hell hole is in similar condition Attached image(s) ![]() ![]() ![]() |
LukeD |
Passenger front and rear brakes, driver side looks the same
I'll be ordering rebuild kits and rubber lines from PMBPerformance and then flush the system. Should I attempt to save the rotors and have them lightly turned or just replace? Attached image(s) ![]() ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Passenger front and rear brakes, driver side looks the same I'll be ordering rebuild kits and rubber lines from PMBPerformance and then flush the system. Should I attempt to save the rotors and have them lightly turned or just replace? Depends on how they mike out, but for everything else you're doing it makes sense to replace. They are not very expensive. Looks like you've found a good one. I'm betting there is a lot of shine hiding under that oxidation. |
billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Those longs look great... (IMG:style_emoticons/default/beer.gif)
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
Is that the definition of "run flats"? (IMG:style_emoticons/default/laugh.gif) Bet that paint will be WAY soft cooking in CA sun so go easy with the buffer. |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
That's a great looking set up longs.
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) That right there makes it worth buying.
72914wrx |
Member ![]() ![]() Group: Members Posts: 87 Joined: 5-January 15 From: Fresno Member No.: 18,298 Region Association: None ![]() ![]() |
Had the chance to meet Luke today really nice guy I dropped off parts for him and took him for a ride in the 914wrx put a smile on his face . Luke can't wait for you to get the that car running . I was really surprised by the condition of the car and the lack of rust really clean Central Valley car .
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Your longs look great! (IMG:style_emoticons/default/beerchug.gif)
LukeD |
Had the chance to meet Luke today really nice guy I dropped off parts for him and took him for a ride in the 914wrx put a smile on his face . Luke can't wait for you to get the that car running . I was really surprised by the condition of the car and the lack of rust really clean Central Valley car . Thanks again Kevin, it was awesome! I could hardly sleep last night thinking about all the little details to get this one back on the road. |
LukeD |
It's rusty under there (can't have everything right?), I really poked around and made a few holes, I guess once I have the engine out I'll determine if I want to cut away the areas and weld in new (famous last words) Rear trunk is crusty also, although I couldn't make any holes with a screw driver Attached image(s) ![]() ![]() |
LukeD |
let the cylinders soak a couple days in some marvel mystery oil, changed the engine oil and filter
This doesn't look like 20+ year old oil but then again I haven't seen 20+ year old oil before Hooked up a battery and it turned over, put a compression tester on each cylinder and got around 140 psi on #1,2,4 and a little over 130 psi on #3 shipped my injectors to Mr Injector and getting ready to order all new fuel system components including; SS tunnel and engine compartment lines, rubber hose, injector upper/lower seals, relocate new 2 port fuel pump up front. Pulled the tank to drop off to radiator shop to get cleaned. Who knows, maybe late next week she'll run! (IMG:style_emoticons/default/beerchug.gif) Attached image(s) ![]() ![]() |
Phoenix914 |
Member ![]() ![]() Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States ![]() ![]() |
That oil looks like it was never run.
jeeperjohn56 |
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None ![]() |
Great looking car, at least the longs are in good shape, good luck on your project.
LukeD |
Thought I'd update the thread
After a crap ton of work this little guy is back on the road, (IMG:style_emoticons/default/driving.gif) to work tomorrow Terrible pic more to come Attached thumbnail(s) ![]() |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Wow, you really scored!! That thing looks good. Doing carpet is easy too!
Just take your time. New carpet makes a big difference. |
Phoenix914 |
Congrats on getting your car on the road so quickly. That's the hardest part! (IMG:style_emoticons/default/smilie_pokal.gif)
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
incredible find! Very nice work (IMG:style_emoticons/default/beerchug.gif)
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,517 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Very nice save! More photos when you get a chance. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 29th June 2024 - 10:25 AM |
