> MSD gremlin, can't shut off ignition
Trekkor
post Feb 27 2005, 12:34 AM
I do things...
I turn off the key but the engine keeps running.
This is a new problem after adding the MSD.
Key turns off the power, I know, because I can hear the fuel pump turn off.
It eventually shuts off after turning the key off/on/off/on or revving the motor with the key off.
What should I do?
Performance is spectacular, except gremlins are tenants. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
KT
Aaron Cox
post Feb 27 2005, 12:36 AM
Professional Lawn Dart
t dog
i know the answer....i have the hyfire thing right here....
brb with an answer.... i think you need the diode.... lemme check
redshift
post Feb 27 2005, 12:37 AM
Bless the Hell out of you!
Sounds like power is getting somewhere later than expected. Have you used any old wire, from say... the late 1800s?
Sorry, best I can do.
M
Aaron Cox
yep.... you need the diode! inline....
Aaron Cox
post Feb 27 2005, 12:39 AM
install diode/resistor in line with SWITCHED positve lead from msd box to igniton switch!
Trekkor
post Feb 27 2005, 12:41 AM
I do things...
What diode?
Where me find?...grunt
KT
Aaron Cox
post Feb 27 2005, 12:42 AM
QUOTE (trekkor @ Feb 26 2005, 11:41 PM)
What diode?
KT
hmmm... you need a diode (lets current only flow one way)....
my cdi came with it.... hyfires are better (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Trekkor
post Feb 27 2005, 01:08 AM
I do things...
When all else fails, read instructions.
And, MSD includes the diode in their parts bag.
KT
Trekkor
post Feb 27 2005, 01:12 AM
I do things...
If anyone has done this *fix*, please guide me through it.
MSD is kinda muscle car and not Porsche specific.( surprised? )
KT
Joe Ricard
post Feb 27 2005, 06:31 AM
CUMONIWANNARACEU
My Hyfire did this last night. Only it was ANDY induced. I needed a switched power. So I figured I could use Andy's version of providing power from fuel pump. So I hooked up the jumper wire from the 4 prong FI to ground bingo 12V. However the dang thing wouldn't shut off.
So I moved the 12v source to share the black purple that used to go to the coil positive with the Compufire unit. Works great. Dark and rainy here today so I will clean up the engine compartment wiring and
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) oh yea my tach don't either. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) So I need one of them adapters. Wife is going to take the plastic pretty soon so I better get it quick.
Joe Bob
post Feb 27 2005, 08:34 AM
I'm having the same problem,,,,,looks as if the diode goes on the D+ line that goes to the bulb in the charging circuit.....at least that's my answer....everything works AND shuts down when I pull THAT wire. Just no charging....
post Feb 27 2005, 08:59 AM
Mike,
I'm not too experience with the electrical stuff,
Can you please explain with a diagram?
Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Joe Bob
post Feb 27 2005, 09:12 AM
An internally regulated alternator has three wires....one to engine or chasis ground, one BIG RED one that goes to battery, then the D+ wire.....this is also known as the exciter, I think (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) .....it has to go thru a powered bulb in the dash.
He, heh, big red one,,,,,exciter....heh, heh....sounds like a cheap porn movie dialogue....
This is one of TWO idjut lights....the other being the oil pressure light. When the ignition is turned on, lights are one.....when engine runs, the lights go out....
NOW, since the fuel pump and a few other items are on the +15 side of the ignition switch....there is a power feed back from the alternator that keeps the ignition switch open....it looks like the D+ line needs a little resistor to stop the feedback.
post Feb 27 2005, 09:19 AM
Mike,
Thanks for the reponse.
I was concern that my Electromotive would still be running
when I tried to kill the motor.
I have installed a toggle / kill switch - hot from the battery to the coil packs.
I should not experience any concerns right?
Have not started it yet, that's the reason for the last question.
Thank you (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Joe Bob
post Feb 27 2005, 09:21 AM
An on/off kill switch will work....but the diode will also work w/o having to do an extra step to switch anything off....
post Feb 27 2005, 09:24 AM
Mike,
Thank you
When your in LA , let me know, I owe you a COLD one (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Joe Bob
post Feb 27 2005, 09:28 AM
QUOTE (0396 @ Feb 27 2005, 07:24 AM)
Mike,
Thank you
Let's hope it works....kind of funny how more than a few of us have the same problem to deal with on the same weekend.....
I had some input from Captain Krusty and some others on the little winky board.....just gotta find a place that has a diode on a Sunday......or else wait.....
Joe Bob
post Feb 27 2005, 09:30 AM
Another comment from the 911 board....Rich Herzog...he posts here too...
a diode...
the alternator charging current is powering the ignition, IIRC you
need a diode in the "switched +12" line. i don't recall which
direction it needs to point, but one way will work, and the other
won't...
a standard 1W epoxy rectifier diode from Radio Snack should do the
trick (this is not a critical application.
a diode is a check valve for electricity - flows only one way.
this is covered in MSD's instruction sheets, which are available
online in PDF form. i'll go dig up my 911 ignition folder if i need
to, but IIRC it's pretty easy to find the section where they talk
about the diode and how it's installed
iamchappy
post Feb 27 2005, 10:12 AM
It all happens so fast!
The easiest place to put it is spliced into the alt. idiot light wire. or the red wire on the three plug connector from the altenator to the relay board.
Radio shack has them.
Joe Bob
post Feb 27 2005, 10:24 AM
Since most of the Radio Crap guys are computer geeks w/o auto experience....what diode and what rating?
Trekkor has one but hasn't answered my email yet....prolly still in the rack after a hearty party last night.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
- Lo-Fi Version Time is now: 15th January 2025 - 05:22 AM
