9 Pages V « < 2 3 4 5 6 > »
> BUILD-OFF CHALLENGE: Eisberg rustoration, Need some input...
mbseto
post Aug 21 2016, 10:23 AM
Post #61
Now the car is mounted on 4 points again and I can adjust to get those points level. But the two halves are tilted away from each other. I can adjust the door braces to fix that, but I need to know how much.
I made a couple little metal tabs with a hole, and clamped them to the corners of the wheel wells, front and back.
Now I can see if the bottom edges of the quarter panels line up or not...
Then I can crank on the door braces to tilt the halves until they line up...
Looks better:
Now I'm sure someone is thinking, what about door gaps? I haven't forgotten...
The door braces have to be adjusted in tandem to get the gaps right and also the alignment. That said, getting this right is probably the thing I am most worried about.
And a little postscript... Took a hint from Jeff Hail's thread and got myself one of these little monkeys. I've seen them for as much as $30 at industrial and car places... Home Dep has them for $8 and change.
jmitro
post Aug 29 2016, 11:10 AM
Post #62
Very nice work. i'm impressed with your forethought and creativity.
Reading this is making me think I need to redo my longitudinal restoration.
mbseto
post Aug 29 2016, 09:21 PM
Post #63
Continuing work on fabricating the inner long. Need to cut the aft hole for the heater tube. Made some templates..
Put the heater tube in position and slid the templates together and taped them.
Removed the heater tube, leaving the templates in place...
...put the long in place and taped the templates to the long.
Trace out the hole and cut.
Et voila.
mbseto
post Aug 29 2016, 09:33 PM
Post #64
Puzzled over how to match up the inner long to the wheelhouse long, decided on a similar process. What you will not see in this series is me levelling the car across the little ledge in the firewall and constantly measuring the door gaps. I'm checking these at intervals as I go.
Made a template to represent the inner long. It's taped to the body. I've mode some witness marks on it so that I can remove it and then put it back in the same place.
Put the wheelhouse long in place...
...and traced the edge on the template.
Removed the wheelhouse long.
The template is then removed, cut on the traced line, and then replaced using the witness marks.
Then I put the inner long in place over the template.
Taped the template to the inner long.
Traced it and cut. Cut outside the line a bit so I have a little room for adjustment.
mbseto
post Aug 29 2016, 09:40 PM
Post #65
Test fitting the heater tube.
Going to need a little adjustment work to get all this fitting together.
I just like this picture.
I'd be lying if I said I wasn't a little excited to see all this healthy metal so close to being in the car. A good strong backbone again.
914forme
post Aug 30 2016, 06:00 AM
Post #66
(IMG:style_emoticons/default/drooley.gif) Loving the work, We all know how frustrating this stuff can be. Your doing a great job. And the attention to detail is phenomenal.
If I could make a suggestion. I would get my pieces aligned, then add a scab plate to the inside over the joints. Jeff shows this in his thread also. larger the plate the better. Just remember to coat it between the plates.
mbseto
post Aug 30 2016, 11:43 AM
Post #67
Thank you!
I definitely plan to sleeve that joint. Truth is I'm still a ways from welding this all together- that wheelhouse long looks like it was made to attach to whatever is left of the long that was cut out, not extend to the trunk wall. Well, I cut mine out completely so I need to make some tabs to bridge that gap. I'll post photos of that process. Then get that butt joint lined up which will require squeezing the one side so the walls are at right angles and tapering the other to match the height of the section. Then I'll make a sleeve. Finally some primer, and I think I'll be close to welding.
mbseto
post Aug 31 2016, 10:43 AM
Post #68
Acquired a mascot:
mbseto
post Jan 2 2017, 05:00 PM
Post #69
Getting behind on my updates. Got the long sleeved before Christmas...
Made it in three pieces from 12g steel (because the long was already fabricated in 12g...) EDIT: sleeve is 14g:
Checking the fit:
Clamped in place to tack together:
All tacked up:
Welded those seams up solid. Did a little trimming, also sprayed on some weld-thru primer to both pieces before the final weld up.
In situ:
914forme
post Jan 2 2017, 07:00 PM
Post #70
Matthew, working it 12 ga. is a little (IMG:style_emoticons/default/screwy.gif) I like crazy so keep up the great work. (IMG:style_emoticons/default/aktion035.gif)
SixerJ
post Jan 4 2017, 02:03 AM
Post #71
Region Association: England
How did I miss this great thread before now, subscribed! (IMG:style_emoticons/default/popcorn[1].gif)
amfab
post Jan 4 2017, 10:18 PM
Post #72
I am about a month behind you...
http://www.914world.com/bbs2/index.php?showtopic=301894
I hope my fabrications look this good.
Subscribed
-Andrew
mbseto
post Jan 5 2017, 05:06 PM
Post #73
QUOTE(914forme @ Jan 2 2017, 08:00 PM) *
Well, that got me thinking... Had to go back and measure. The sleeve is 14 gauge, as is the upper long from RD- only the inner long is 12, bent by a local shop.
mbseto
post Jan 5 2017, 05:14 PM
Post #74
Building a motor mount.
Making a pattern...
Cutting out the pieces...
Hammer time...
mbseto
post Jan 5 2017, 05:22 PM
Post #75
All the bits... These are actually the bits from the light gauge practice piece I made. Can't find a picture of the 14g stuff. Anyway, on to welding...
Welded together. I used weld through primer where there are flanges here. The bottom piece is just bolted to the main part of the bracket, I need to fit it to the long and to my dolly/jig and some bends may need a little tweaking.
914forme
post Jan 5 2017, 05:40 PM
Post #76
Nice work there (IMG:style_emoticons/default/smash.gif)
JoeDees
post Jan 5 2017, 06:10 PM
Post #77
That...is...awesome!!!!
amfab
post Jan 5 2017, 10:12 PM
Post #78
Man, that is great
Matthew you have similar spots that I uncovered.
Having this thread has helped my anxiety about taking on too big a project.
Are you learning as you go or have you worked in sheetmetal before?
mbseto
post Jan 6 2017, 08:00 AM
Post #79
QUOTE(amfab @ Jan 5 2017, 11:12 PM) *
Before I started on this car I would have said, oh yeah I've worked with sheet metal before. What I knew then feels pretty small compared to what I've been learning. So, yes, I am absolutely learning as I go. It's fun for me, and it's why I took on this project.
I often make a piece in a lighter gauge first, just to see how the metal is going to behave when I try to make that shape. I also spend some time on sheet metal forums, where they tend to show more about the actual making of a piece, whereas here most people just show the finished piece and then how it is patched in to the car.
Cairo94507
post Jan 6 2017, 08:19 AM
Post #80
Michael
Wow! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/popcorn[1].gif)
- Lo-Fi Version Time is now: 3rd April 2025 - 01:12 AM
